    Altimeter: issue with manual altitude setting
    1 Posts 1 Posters 110 Views 1 Watching
    • Hari SeldonH Offline
      Hari Seldon
      I waited a while before reporting this but, afaic, the last two firmware updates cause a problem when I manually set the altitude. It is a sporadic problem, so it is not easy to identify, and unfortunately, I have not yet figured out what circumstances trigger it.
      As you can see from the video, if I try to manually set a new altitude value (139m), as soon as I confirm and return to the widget, the altitude value reverts to the previous one (108m).
      I would also add that, even though I cannot correct the altitude, it keeps working correctly if I change position.
      A soft reset always fixes the issue.
      Suunto Run
