    VO2MAX in cycling activities
    9 Posts 7 Posters 313 Views 7 Watching
    • Josef NilssonJ Offline
      Josef Nilsson
      Sorry if this have been asked before, but I just need to double check.
      Does the V2 support vo2max via cycling or is it only running?
      AudaxjoeA 1 Reply Last reply Reply Quote 1
      • AudaxjoeA Offline
        Audaxjoe @Josef Nilsson
        @Josef-Nilsson I get Vo2 max estimate and don’t run. I guess it is from the bike.
        I am not sure how accurate it is.
        Suunto 9 BARO
        Garmin Fenix 3, 5
        Suunto Vector
        VoiGASV D 2 Replies Last reply Reply Quote 0
        • VoiGASV Offline
          VoiGAS Silver Members @Audaxjoe
          @Audaxjoe Do you know how it works? Like running using GPS, Barometer and HR? Or do you use a Powermeter?
          • AudaxjoeA Offline
            Audaxjoe @VoiGAS
            @VoiGAS I do not have a power meter so my guess is Heart Rate.
            I have no idea if it is accurate. I have only had the V2 a few weeks, so this may skew the results but the results are quite a bit lower than the V1. But I also haven’t done any long rides.
            Suunto 9 BARO
            Garmin Fenix 3, 5
            Suunto Vector
              brave_dave Bronze Member @Audaxjoe
              @Audaxjoe there is no way to estimate Vo2max without correlating effort (HR) with performance (pace/speed or power). So if you do not use a power meter it can only do it on the bike by speed but that is highly inaccurate. Therefore, I really doubt that the vertical 2 does that and I also haven’t heard about Vo2max for cycling. Would be also really strange as Vo2max for running and cycling should be separated as it is not comparable. Probably your Vo2max comes from some hiking or walking activity that you have done some time
              • D Online
                dulko79 @Audaxjoe
                @Audaxjoe do you track walking?
                App: beta
                Phone: Iphone
                iOS
                • AudaxjoeA Offline
                  Audaxjoe @dulko79
                  @dulko79 yes, but I have done no walking since I had the V2 that got past zone 1 🤷🏻‍♂️ But it could very well be how it is tracked.
                  All I know is the watch gives me an estimate and I don’t run.
                  Suunto 9 BARO
                  Garmin Fenix 3, 5
                  Suunto Vector
                  • HonzaSH Online
                    HonzaS
                    I have V2. There is NO VO2 for cycling even with dual power meter. I got VO2 for walking and running activities. Surely walking activity can´t return good VO2 estimate…
                    • v.sacreV Online
                      v.sacre Silver Members
                      Indeed no VO2max for cycling even with power meter.
                      For walking activities, I use Hiking sport mode and do not have vo2max estimation which is fine to me. I préfère having it only for running.
                      For cycling I have vo2max estimation from my Garmin Edge unit.
                      Suunto App: Android Beta
