    Suddenly while bike riding Connection HR Belt broken
    8 Posts 6 Posters 426 Views 6 Watching
      GiPFELKiND Silver Members
      As mentioned in the title, I went on a 45km gravel ride today. I replaced the battery in my Suunto heart rate chest strap before the ride. After 2.5 hours, the heart rate field on the watch only showed “–”. See the attached screenshot. Detaching and reattaching the sensor from the strap didn’t change anything. It’s a real pain that the next step in this kind of problem isn’t for the heart rate monitor to automatically take over the measurement! This is a new strap that I ordered because the same problem occurred with my two-year-old strap. So I thought it was due to the age of my old strap. But it doesn’t seem to be the strap. I also have the problem that before starting an activity, the strap is displayed as active and then suddenly disappears. My watch model is Vertical 2. Is anyone else having problems with this watch and heart rate strap?
      The problem is that the heart rate monitor is only there at the beginning of the activity and then suddenly disappears, and I can reproduce this almost daily. I suspect there’s something wrong with the connection. It’s incredibly frustrating. I mean, you do a 4-hour training ride and keep an eye on your heart rate, and then for the last hour, your log is full of garbage because the heart rate isn’t being displayed anymore. Suunto, what kind of bad joke is this? I’m open to any information and solutions. And no, I’m not exchanging the Vertical 2 with customer service; I might end up getting a model with a crooked display.
      2 F 2 Replies Last reply Reply Quote 1
        2b2bff Silver Members @GiPFELKiND
        @GiPFELKiND seems like it recorded some heart rate, though. Like it stuck with one heart rate and didn’t recover… At least the diagram shows not nothing…
        Garmin Epix Pro
        D 1 Reply Last reply Reply Quote -1
          duffman19 @2b2bff
          @2b2bff I think that’s just what it does when it loses an HR signal. It takes the last read HR and continues writing it until it recovers rather than writing zeros. At least that’s been my experience when losing connection to an external HR. The watch will still show “–” though.
          GiPFELKiNDG Olaf GottschalkO 2 Replies Last reply Reply Quote 1
            GiPFELKiND Silver Members @duffman19
            @duffman19 i understand you. But why should the hr Monitor signal get lost? New battery, new Sensor…
            • SuperFlo75S Offline
              I have some trouble with the HR belt and my SV1… it looses connection and reconnects a while ago… I talked about it some weeks ago in the November Rain Thread… I have this issue since I updated to the actual firmware
              Suunto Spartan Ultra
              SA iOS 3.7.2 (21451)
              Instagram @superflo75
                duffman19 @GiPFELKiND
                @GiPFELKiND said in Suddenly while bike riding Connection HR Belt broken:
                I have no idea. I was just responding to @2b2bff’s comment about the HR graph.
                I will say that I have also been experiencing external HR drops on both the 9PP and V1 running the latest firmware. But usually it just drops for a few seconds at most, and never completely loses connection like it seems yours did. I’ve also been wearing an original 9P running super old firmware (2.26.8) and have not experienced any external sensor drops on it. So I’d guess it’s firmware related and hope that it gets fixed with the Q4 update.
                • Olaf GottschalkO Offline
                  Olaf Gottschalk Bronze Member @duffman19
                  @duffman19 said in Suddenly while bike riding Connection HR Belt broken:
                  Yes, you are right. Same things happen when connection to power pedals are lost during activity: the last measured value is held throughout the rest of the activity.
                  It is such a bad joke as the last value is probably the worst you can record. If this situation occurs, no value would be better than that value because every other reading’s average now gets destroyed.
                  The only “correct” way is to record that you don’t have the information and as such, no other calculated reading should be affected in the stats.
                    Freezer Bronze Member @GiPFELKiND
                    @GiPFELKiND I am having the exact same problem with Vertical 2 and external HRM
                    https://forum.suunto.com/post/185907
