    Stryd Power vs Suunto Power
    3 Posts 3 Posters 253 Views 3 Watching
      Mortel
      Hi @all, my problem is that my Vertical 2 shows different power values during the run (Suundo stryd all vs. Suunto 3sPower) as well as after the run in the suunto app and in the stryd app. I assume that suunto use the internal accaleration sensor for the power and not the stryd power meter. Would be great if someone have a solution. Thank you
      Christoph Van LaethemC 1 Reply Last reply Reply Quote 2
      • Christoph Van LaethemC Offline
        Christoph Van Laethem @Mortel
        @Mortel
        I noticed the same, also when pairing the stryd pod, i always see that calibration is for bike and not for running. I have de Vertical V1, there is the problem also, just bought the Race 2 and also here i have the same problem. I contacted Suunto Support, but still no reply. I hoped i would be solved in the last software update.
        • R Offline
          runsgrun
          I have similar issues on my Race S several months ago an apparently fixed a couple of firmware update ago. In recent weeks I realized the problems popped up intermittently. I had been diligently sync-ing and exporting Stryd-only data for my runs and compare them to Suunto’s data. About half the time, the power numbers matched well, while the others will be off by 5 to 10w. And when the data got merged into Power Center, the Suunto’s numbers persisted, “compromising” the overall data quality. This is really frustrating.
          Suunto Race S | 9 Peak | Spartan Sport Wrist HR Baro | Ambit3 Run | Quest | M2
          Polar H10 | H9 | Verity Sense | Grit X | OH1
          Stryd Next Gen | Wind | Non-Wind
