    Track run trace not aligned to lane
    11 Posts 6 Posters 692 Views 4 Watching
    • HonzaSH Offline
      HonzaS
      200m track. Length correctly set up in watch. Shouldn’t be the trace aligned to track lane? Or does it work only on 400m tracks? FW 2.50.26
      Suunto Vertical 2
        2b2bff Silver Members
        Has the track run gotten some functionality lately? I heard it was only kind of a placeholder as it has been introduced…
        Garmin Epix Pro
        HonzaSH SamuelPS 2 Replies Last reply Reply Quote -1
        • HonzaSH Offline
          HonzaS @2b2bff
          @2b2bff Hmmm, just looked at manual and there is no mention of track run activity. Only in manual for Suunto Run model.
          But according to this: https://www.dcrainmaker.com/2025/06/suunto-adds-track-running-mode-and-38-new-data-fields.html
          It only depends on the track run activity, which Vertical 2 has , also Race got this, so it should have this function 🤔.
          Suunto Vertical 2
          • SportsfreundS Offline
            Sportsfreund Bronze Member @HonzaS
            @HonzaS what is „track run“ ?
            Do you not have gps?
            • SamuelPS Offline
              SamuelP Silver Members @2b2bff
              @2b2bff more functionality was added in the 2.43.8 update
              https://forum.suunto.com/post/168805
              Vertical All Black
              • pavel.samokhaP Offline
                pavel.samokha
                Please try again, after that share logs to Suunto https://www.suunto.com/fi-fi/Tuki/faq-articles/suunto-app/how-to-send-diagnostic-logs-on-suunto-app/ and link to your workout
                E HonzaSH 2 Replies Last reply Reply Quote 0
                  elbee Bronze Member @pavel.samokha
                  Probably not a popular opinion but… who cares that their gpx trail is perfectly aligned with the track on strava?
                  I train weekly on a track at my athletics club and we usually do intervals between 200m and 800m. There are enough lines on a track to know the distance. You get a target time for each interval. Really all you need is a stopwatch.
                  Yeah, strava might say you dis 410m intervals, but I know I did 400m in1:35, so perfectly fine. (I might have run slightly more than 400m if I overtook someone in a bend)
                  How it looks on strava doesn’t influence the quality of your training/race. Nobody is going to judge you or tell you you did a bad job because the trail isn’t aligned.
                  But that’s probably just me…
                  Suunto t3c | Suunto Ambit | Tomtom runner 3 | Garmin forerunner 935 | Garmin forerunner 965 | Suunto race s
                  HonzaSH 1 Reply Last reply Reply Quote 6
                  • HonzaSH Offline
                    HonzaS @pavel.samokha
                    @pavel.samokha Thank You, I’ll try it later.
                    Suunto Vertical 2
                    • HonzaSH Offline
                      HonzaS @elbee
                      @elbee You’re right! I don’t need perfect track, also I’m just poor runner. 🙂 The reason why I’m trying to figure this out is, that this function was somehow claimed, I tried that and it doesn’t worked as it should. That’s all. If I get answer, that this is only for Run model or 400m track, I’ll be perfectly fine with that. But it seems it isn’t, so maybe I’ll help to improve future fw with sending my logs. 🤔
                      Suunto Vertical 2
                      E 1 Reply Last reply Reply Quote 2
                        elbee Bronze Member @HonzaS
                        @HonzaS I understand your “it should work as advertised “ and in general it should.
                        But…
                        I think trackmode is a useless addition to a sportwatch and I can come up with a dozen small improvements that make a watch better to use.(these include simple things as setting the alarm for only 4 chosen days of the week). Personally I would be more happy if developers spent time on those.
                        I do realize adding a new feature is way better marketing than fixing little things. Suunto is a commercial company and there is a quite large group out there that things more features is always better.
                        HonzaSH 1 Reply Last reply Reply Quote 1
                        • HonzaSH Offline
                          HonzaS @elbee
                          Fortunately, it’s not like Garmin, where they advertise a million unnecessary features and users get badges even for sleeping…😁
                          Suunto Vertical 2
