    Need help connecting to the watch on macOS
    13 Posts 8 Posters 1.5k Views 8 Watching
      shaupt
      Hi
      Having made my first app, I would like to deploy it but VsCode/SuuntoPlus extension cannot see the watch.
      I have tried both USB (computer cannot see the watch) and Bluetooth (computer cannot see the watch but with LightBlue I can connect the watch to the computer).
      What are the steps needed to connect?
      Computer is MacBookPro 14" M3 Max, OS is 26.3.1 (a), newest VsCode, newest SuuntoPlus extension.
      VsCode has been access to BlueTooth but macOS.
        shaupt @shaupt
        Watch has been unpaired from the phone and bluetooth has been turned off on the phone.
          Squirrel Silver Members @shaupt
          @shaupt On the watch
          Settings > Connectivity > Paired devices > MobileApp > Forget
            shaupt @Squirrel
            @Squirrel Thanks.
            I have done all this:
            Unpair in Suunto app
            Forget in iOS bluetooth settings
            Turned of Bluetooth
            Set watch discoverable
            Forget suunto app on watch
            Soft reset the watch
            ookO 1 Reply Last reply Reply Quote 0
            • ookO Offline
              ook @shaupt
              @shaupt did u do this
              To enable Bluetooth pairing in macOS, you also have to set at least a partial serial number of the watch to macOS Bluetooth Serial in SuuntoPlus Editor extension settings.
                shaupt @ook
                @ook Thanks, have also tried both full and partial serial numbers (removing digits at the end).
                I am doing this:
                1. Phone (iPhone 13, iOS version 26.3.x)
                2. Suunto App > Manage connection > Forget
                3. Terminated Suunto App
                4. Settings > Bluetooth > “Suunto Peak 9 Pro xxx” > Forget this device
                5. Settings > Bluetooth > Off
                6. On the watch (Suunto 9 Peak Pro)
                7. Connectivity > Paired Devices > Mobile App > Forget
                8. Connectivity > Discovery On (is usually off)
                9. On the computer (MacBook Pro, M3 Max, late 2023, macOS 26.3.x)
                10. Once:
                11. Given VsCode access to Bluetooth. macOS have asked that should approve, I have manually enabled it.
                12. In VsCode settings, supplied the serial number of the watch (both full and partial)
                13. Turned Bluetooth on (the watch has been paired with the computer but this only works when using LightBlue, bluetooth is usually off)
                14. In VsCode > Suunto Watch > Refresh, nothing is found
                  shaupt @shaupt
                  Hmmm, now it works.
                  Toggling automatic/manual connection changed something. However, if this is a permanent fix I do not yet know.
                  Ecki D.E 1 Reply Last reply Reply Quote 0
                  • Ecki D.E Offline
                    Ecki D. Bronze Member @shaupt
                    @shaupt intresting I didn’t get it to work, but I was trying on a much older MacBook Pro.
                    I could connect the watch with BlueLight app from Appstore in macOs as a Bluetooth device but VSCode didn’t see it no matter what I did. Will check again cause I don’t think its an Hardware Issue if the Mac can connect.
                    I did already switch between auto / manuell but that didn’t help. But didn’t test with the version number. I got it working on Win but thats not my dev setup for private projects.
                      shaupt @Ecki D.
                      @Ecki-D. I have tried many times and might have tried things in a different order.
                      In the bottom right corner of VsCode error message appear, do you get any of those?
                      • Raimo JärviR Online
                        Raimo Järvi
                        If you run “SuuntoPlus: Open Log Files” command in VS Code, you might get some useful information from the logs
                        Pragmatic Programmer
                          try also ble on off on the mac. I kinda remember having this issue long time ago or killing some process.
                          The @suuntopartnerteam maybe knows better ?
                          Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard or use mcp.
                            Starfish2045
                            Just registered to let you know that I believe this is an issue with how SDS (the server interfacing w/ the IDE extension and the watch’s protocols ?) is spawned by the Suuntoplus Editor.
                            I’m facing the exact same issue, only on a macbook w/ an M4 Pro chip instead of an M3 Max one.
                            Running the following command starts SDS, which after a few seconds picks up the watch and starts the pairing process.
                            SDS_MACOS_BLE_SCAN=1 ~/.vscode/extensions/suunto.suuntoplus-editor-1.42.0/node_modules/@suunto-internal/sds-as/macos/SDSApplicationServer.bin 9801
                            As a workaround, I tweaked my local version of Suuntoplus Editor to prevent it from starting SDS (via a coding agent, which worked surprisingly well from the first try), and I’m starting it manually in a terminal.
                            The relevant file is
                            ~/.vscode/extensions/suunto.suuntoplus-editor-1.42.0/node_modules/@suunto-internal/sds-as/dist/sds.js
                            The watch is then displayed in VSC, and could be loaded with my app without any issue.
                            I hope that this info will let you debug and patch the Suuntoplus Editor 🙂
                            As a side note, I was quite happy to see this editor being available free of charge and without any signup process 👍
                            • N Offline
                              Noam G @Starfish2045
                              @Starfish2045 Hi,
                              I Had a similar issue, getting an error inside VSC while trying to find the connected watch and found that manually running the SDSApplicationServer did work out, but after an update to the VSC Extension it stopped working because the extension closed the external instance i ran in the beginning.
                              Tried modifying the SDS.js with no success. Would you mind posting the change you’ve made?
