    Charging of battery
    11 Posts 9 Posters 648 Views 7 Watching
      Danny
      I cannot charge my Suunto Vertical at all; I connect the cable, but the screen stays off. No charging icon appears. Any help?
      OutdoorManO snow*S 2 Replies Last reply Reply Quote 0
        OutdoorMan Silver Members @Danny
        @Danny can you try perhaps multiple USB ports or outlets to rule out a defective charger?
          Danny @OutdoorMan
          @OutdoorMan
          Thanks for your answer. I tried, different ports and even different PC. No results.
          mickywickyftwM 1 Reply Last reply Reply Quote 0
          • snow*S Offline
            snow* @Danny
            @Danny If you have a multimeter, you could measure the voltage between the two contacts – around 5V DC – to check if the cable is ok
            Race S Ti.
            • mickywickyftwM Offline
              mickywickyftw Bronze Member @Danny
              @Danny also try powering down the watch completely. On one occasion about 2 years ago, it fixed the issue for me.
              BrunoHB 1 Reply Last reply Reply Quote 0
              • BrunoHB Offline
                BrunoH Gold Members @mickywickyftw
                I had a similar problem with my daughter’s Huawei Band. The battery was next to empty, but refused to start charging. One internet trick was to put the device in the freezer for 30 mins. That shock treatment did something and it miraculously started charging again.
                Compasses: M-311, A-10, SK-7
                  Squirrel Silver Members @BrunoH
                  @BrunoH said in Charging of battery:
                  Just be careful and do not charge while the battery temperature is below 0°C (32°F).
                  From https://www.batteryuniversity.com/article/bu-410-charging-at-high-and-low-temperatures/
                  Many battery users are unaware that consumer-grade lithium-ion batteries cannot be charged below 0°C (32°F). Although the pack appears to be charging normally, plating of metallic lithium occurs on the anode during a sub-freezing charge that leads to a permanent degradation in performance and safety.
                  2 1 Reply Last reply Reply Quote 2
                    2b2bff Silver Members @Squirrel
                    @Squirrel good point, as from the specs:
                    Recommended charging temperature 0° C to +45° C / +32° F to +113° F
                    • Stoke80S Offline
                      Stoke80
                      Something different, but it fits the thread title:
                      Can I charge the watch during an acivity? It is a Race 2.
                      I will be doing a 24h Road bike ride at the end of June and just want to know if I have this opportunity or not.
                      Thank you.
                      Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S / Suunto Race 2
                        Egika Platinum Member @Stoke80
                        @Stoke80 said in Charging of battery:
                        Thank you.
                        Yes, this is possible. From the specs the watch should last 55h with highest accuracy. 24h should be no issue when you start with a full battery.
                        Stoke80S 1 Reply Last reply Reply Quote 0
                        • Stoke80S Offline
                          Stoke80 @Egika
                          @Egika
                          Thank you.
