    Suunto Ocean – HR Sensor not working in Running Mode after firmware update 2.51.28
    2 Posts 2 Posters 38 Views 2 Watching
    • yassine besbesY Offline
      yassine besbes
      Re: Suunto Ocean update 2.51.28
      Hi everyone,
      I’ve been experiencing an issue with my Suunto Ocean (Model: DW223, Firmware: 2.51.28) since the latest update to version 2.51.
      Problem: My paired Suunto Smart Sensor (HR) no longer works when I start a Running activity. The sensor shows up correctly in the paired devices list, but no heart rate data is captured or displayed during the run.
      What I’ve already tried:
      • Factory reset of the watch (as suggested by Suunto support)
      • Re-pairing the Smart Sensor
      • The issue persists after all these steps
      Has anyone else encountered this after the 2.51 update? Any workaround would be greatly appreciated while waiting for a fix.
      Thanks!!
        Egika Platinum Member @yassine besbes
        @yassine-besbes If I remember correctly, the sensor indeed needs to be deleted from the watch and paired again.
        This came with the change in sensor management.
        Now I see that you have already tried to re-pair it. Have you deleted it before this?
        And then have you enabled the sensor in the exercise settings under “Sensor Data”?
