    Python Model using FIT files to model watch analysis and display
    1 Posts 1 Posters 309 Views 1 Watching
    • M
      matram Bronze Member
      When working on the Aerobic Guide it became clear that it would be difficult to verify the app solely through on-watch testing. To get better confidence and faster development I developed a Python model that could replay FIT files from older runs.
      The elements of the test bench are:
      • Top chart — models the watch HR chart
      • Dashboard strip at the bottom of the top chart — showing power, efficiency, and short-term decoupling as they appear on the watch
      • Bottom left chart — shows the HR data for the whole run; the highlighted area is what is currently shown on the watch
      • Bottom right chart — shows the 1-minute efficiency data (blue), full-run decoupling (yellow), and short-term decoupling (red), allowing visual comparison between the two decoupling approaches
      How the Python model was used
      Runs were selected from intervals.icu in three categories: good, middling, and bad. The FIT files were downloaded and converted to JSON.
      I first modelled the HR chart display strategy. A 5-point average was found to provide a sufficient time span (29 minutes) to evaluate drift, or short-term increases in HR due to a hill.
      For the dashboard strip the focus was on early indication of situations where you should slow down or stop. I found some runs where the HR chart by itself did not give a strong enough signal.
      A good example is a recent bad run of 80 minutes.
      Subjectively described:
      • Felt very weak from the start; was not sure I would be able to complete the run, and managed only through force of will
      What the model showed:
      • Continuous hyperbolic decline of efficiency, no plateau reached, late slope still negative
      • The HR chart showed only a modest excursion above Z2 — a situation that would not trigger concern on its own. The efficiency data told a different story: the body was not responding well and showed a continuous decline throughout.
      Other observations
      • All runs examined started with a high initial efficiency, around 1.4
      • Good runs were characterised by a rapid downward trend to about 1.2 within 5 minutes, followed by a stable state
      • Middling runs often had a longer decline to lower efficiency levels but still managed to reach a stable state
      • Bad runs never found a stable state
      • In bad runs the initial decline may last 20–40 minutes. A full-run decoupling figure is then dominated by that initial drop, making it misleading. Later stages may show zero decoupling or even an upward slope — this is why the standard full-run decoupling may provide the wrong indication.
      Conclusions
      From these tests the short-term decoupling metric was selected and implemented on the watch. I am still evaluating whether this approach provides the right early feedback.
      The Python model allowed faster iterations than testing on the watch alone, and is an approach I would recommend.
      1 Reply Last reply
      Reply Quote 3
