    Vertical in 2026: thoughts and experiences?
    6 Posts 6 Posters 248 Views 7 Watching
      flatduck
      Suunto have a sale on in my country where I can grab the Vertical Solar (Stainless Steel) for 399 EUR, or the titanium for 499.
      My main priority is a watch that can last a very long time, especially in dual-band GPS mode (“Performance” mode as Suunto call it). The absolute most I can spend on a watch is 500 EUR so both fit in my budget.
      I plan on using the watch for hiking, running, and a small bit of cycling (but it’s less important for me). I’m aware the HR monitor on the Vertical is a bit crap, but I have a chest HRM so that’s not a concern.
      In 2026, does the original Vertical still hold up? The only other watch I could find that has similar battery is the Garmin Enduro 3 and that’s wayyyyyy out of my budget. So the Vertical seems like a good deal to me on paper.
      What are your thoughts, experiences with the Vertical? Does it hold up today? Are Suunto likely to keep updating the software even with bug fixes/security fixes?
        Tieutieu Platinum Member @flatduck
        @flatduck I use the SV titanium solar since the first day it was launched. 3 years later it’s still the best suunto I ever had. Reliable, very long lasting battery, awewome look on SV version.
        Now it’s comes to it’s limit on updates side. But so far I don’t miss a lot (only last suunto climb guidance update and sleep phases but for that I use my SRs ; I hope I could arrive in a future/last update ?).
        Screen could be bigger compared to last generations.
        For the rest it still worth the price IMHO.
        Suunto Wing & Spark
          elbee
          Tbh, it really doesn’t matter that much whether you use a brand new type or an older type watch. I’ve had several watches with an optical sensor and none work for me. It’s more person dependent than hardware. My advice, never buy a watch because marketing promise the best heart rate sensor ever. If the old one didn’t work for you, the new one will neither.
          If it meets your criteria (long battery life and dual freqeuncy gps) it’s fine. (Personally I think dual frequency gps is a bit overhyped. I did follow gpx routes with an ancient suunto ambit 3 run and never got lost)
          If I look around at my athletics club I see quite a few very good athletes using watches way older than a vertical.
          If you like the watch, and it’s in your budget and don’t have fomo, you will have a watch which lasts many years.
            Egika Platinum Member
            regarding TI or steel, it comes down to the weight.
            light weight helps the wrist heart rate detection.
            I love wearing a lighter watch (and the difference is clearly noticeable).
            While, if this is not priority for you, the steel models do the same.
            • CroSharkC Offline
              CroShark
              I’m a proud owner of the Vertical Solar Steel since the start of 2025.
              The watch has been amazing for me.
              The battery life is virtually unlimited for my training and daily use.
              Like it was stated the OHR on the watch is just plain bad, pretty much useless for running ad similar “bumpy” activities, so an external heart sensor is a must (I use Polar Verity Sense and Suunto Smart Sensor.).
              The GPS/GNSS performance is good, but to be honest with watches I usually get about 1 - 5 meters precision in challenging conditions (trees and nearby cliffs, and urban area). Which is good enough for following a trail on the map or imported route (most of the routes on OSM are less precise then the watch).
              So far it held up great, despite many bumps with the rocks during climbing.
              Definitely would buy it today for a good price.
              Suunto D4
              Suunto Ambit 3 Peak
              Suunto 9 Baro
              Suunto Vertical Solar Steel
              • VoiGASV Offline
                VoiGAS Gold Members
                Great choice for your activities. The display is great in the sun. Especially for your activities it has a unique feature:
                If you want to use the maps, with the Vertical 1 MIP Display the map is always on. AMOLED watches switch into a harder to read kind of reduced mode. You have to activate it by raising your hand which doesn’t work to well if mounted to a bike…
                Its kind of heavy, I have the Titanium version and thats the maximum I would carry on the wrist. But thats highly individual
                Battery just seems to last forever, so that shouldn’t be a concern
                Vertical Titanium Solar
