    Suunto 9 Peak Pro / SuuntoPlus Editor 1.42 — secure BLE bonding and GAP Peripheral capabilities? (Bosch eBike integration)
    2 Posts 2 Posters 278 Views 2 Watching
    • M
      Manuel Mendonça 0
      Hello SuuntoPlus developers,
      I am building a SuuntoPlus sports app for a Suunto 9 Peak Pro and a Bosch Performance Line CX Smart System e-bike (eBike Flow). The goal is to display e-bike battery state of charge (%) and rider power (W) directly on the watch, without a smartphone bridge or any additional hardware.
      The app already starts and renders its diagnostic screen in the SuuntoPlus simulator with the Suunto 9 Peak Pro / E-MTB profile. I inspected the local SuuntoPlus Editor v1.42.0 documentation (developer-doc/reference.html) and found appConn.connect(), appConn.regUuid(), appConn.readChar(), appConn.writeChar() and appConn.enaCharNotf(). These appear to describe a GAP Central / GATT Client workflow.
      The official Bosch Live Data Interface has an unusual BLE role arrangement: Bosch acts as GAP Central, while the accessory must act as a connectable GAP Peripheral and advertise the Bosch service solicitation UUID 0000eb20-eaa2-11e9-81b4-2a2ae2dbcce4. The connection requires secure bonding and an appropriate ATT MTU. I could not find SuuntoPlus APIs for advertising/Peripheral mode, pairing/bonding or MTU control.
      Could someone from the SuuntoPlus team clarify, specifically for the Suunto 9 Peak Pro firmware, whether:
      A SuuntoPlus device app can advertise a custom connectable BLE peripheral / service solicitation UUID and accept an incoming central connection.
      If not, a SuuntoPlus app using appConn.connect() can connect to a previously unpaired, secured BLE device, invoke OS-managed LE Secure Connections pairing/bonding, then subscribe to custom GATT notifications (similar to the BLE central connection used by the Bosch eBike Flow app).
      Device apps can reuse a Bluetooth bond created from the watch's standard Pair sensor menu with a custom GATT service, not just the supported Power POD profile.
      There are platform limitations for appConn bonding, connection concurrency and/or GATT MTU on the 9 Peak Pro.
      If unsupported, is a documented workaround, alternative SDK API, or Suunto-supported integration available that does not require a hardware bridge?
      I would especially appreciate a yes/no answer for the 9 Peak Pro, and a link to working SDK examples or the applicable API/firmware constraints. I do not want to attempt risky pairing and affect the user’s existing Bosch eBike Flow bond without a supported procedure.
      Thank you.
      Michele SellaM 1 Reply Last reply
      Reply Quote 0
      • Michele SellaM
        Michele Sella @Manuel Mendonça 0
        @Manuel-Mendonça-0 unfortunately i hit the same problem and made an hardware workaround with and esp32 powered from my ebike battery (connection with Bosch cable to the motor). If you want you can check it out there: https://forum.suunto.com/topic/15217/project-bosch-ebike-live-data-on-suunto-race-s-open-source-esp32-bridge-suuntoplus-app
        Project is almost all vibecoded. It works reliably and without issue for me, i use the power/cadence mode for acquiring data directly without the S+ app.
        1 Reply Last reply
        Reply Quote 0
