    Vertical 2 and Stages Dual Powermeter - wrong Power readings
    1 Posts 1 Posters 46 Views 1 Watching
      johann.fuehrer Silver Members
      I use a Stages power meter together with my Suunto V2 and a Wahoo ELMNT BOLT. The power meter is dual sided.
      In the V2 I see BOTH PMs (left and right side) even though they are linked together. And I am not able to connect both, It’s either the one or the other side. On the BOLT I see (ANT+ connected) only one, which is OK. So I took that what is usually the primary side (which is the ANT+ ID sie I see on the BOLT)
      The BOLT readings are OK and show correct power, on the Suunto the power reading is exactly the half of the expected and shown value of the BOLT. Thus results also in wrong metrics over all (TSS completely crap, about 58 instead of nearly 290 on the Wahoo)
      I deleted the Suunto recording and imported the Wahoo one, but then I’m loosing the Suunto specific metrics in the activity record 😞
      Has anyone ever made a dualsided Stages PW work correct on a Suunto watch?
      "Trail running is the answer. Who cares what the question is …"
