    Suunto 9 energy saver
    18 Posts 5 Posters 916 Views 5 Watching
    • karel loudaK Offline
      karel louda Bronze Member
      Hi all,
      when Suunto 9 is putting off without movements, the screen is black because of Energy saving. But why HR sensor still blinking in intervals, like it is wearing? It would be off too.
        Dimitrios Kanellopoulos Community Manager @karel louda
        @karel-louda it will light up promply (the sensor and screen) if there are vibrations eg from you walking in that room.
        karel loudaK 1 Reply Last reply Reply Quote 0
          karel louda Bronze Member @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos
          It isn’t so - When I’m lying on the bed and see they blinking, the Display is always black.
            @karel-louda
            Do you have 24/7 enabled ?
            SVTS - 2.40.38
            Suunto App Android 6.1.4 beta
            Suunto App IOs 3.2.0 (20370) beta on MBP M1
              @karel-louda aha ok did not know that it was bed time related. That is because the watch can turn off the display during monitoring sleep but still needs to measure HR.
                but when is the watch taking off and measures no HR (I hope, when is off the hand measures nothing), would be deactivate blinking too.
                  @karel-louda it will do that only in the sleep phase. 80% of the cases it will abort and will not measure HR. You can run off sleep tracking if you do not have it worn. That is only the edge case that it will enable HR if not worn.
                    karel louda Bronze Member @sartoric
                    @sartoric Yes, enabled.
                      Now i tried it with deactivated sleep tracking an it is the same… still blinking.
                        sartoric Moderator @karel louda
                        @karel-louda
                        Did you disable 24/7 too ?
                        SVTS - 2.40.38
                          @sartoric
                          Not. On the day, I want 24/7 HR and when sleep, I want saving the battery. What have I such exotic requirements?
                          sartoricS EgikaE 2 Replies Last reply Reply Quote 0
                            Again, do you move the watch or it gets vibrations from the floor ?
                              @karel-louda
                              Well 24/7 is self-explanatory 😄
                              SVTS - 2.40.38
                                no. The watch is lying on the ground and I very don`t believe it gets any vibrations from the floors. Would You can test it too?
                                  Egika Platinum Member @karel louda
                                  @karel-louda said in Suunto 9 energy saver:
                                  @sartoric
                                  You know, what 24/7 means?
                                    karel louda Bronze Member @Egika
                                    @Egika
                                    And do You know what means battery saver?
                                      I am quite sure it picks up vibrations. Mine 6 watches all do it. I have to really keep them somewhere not affected by waling etc.
                                      jthomiJ 1 Reply Last reply Reply Quote 0
                                      • jthomiJ Offline
                                        jthomi @Dimitrios Kanellopoulos
                                        Same here with my Suunto Spartan Sport, sometimes I am wondering why it is making any sounds out of the closet. 🙂
                                        @Dimitrios-Kanellopoulos said in Suunto 9 energy saver:
