Using Movescount web and Suunto app simultaneously
 @flypg said in Using Movescount web and Suunto app simultaneously: I can do this because I not use Notifications on my watch, not need that the apps run continusly, and with this I can select when I like run the app and what app (MC or SA). In case that need that one of these apps it runs continuously, I can easily change this setting. Now I can edit from MC web my sport mode settings again
 After this I sync with the MC app to my watch.Hello,
 After use both apps for some months, and mainly after the last update of the SA I decided to use only the SA as the โappโ.
 I ฬm not 100% convinced, but I ฬm very close. My doubts are:1)- I need any procedure to do to delete my moves, info and other data from MC?
 2)- All MC related settings, even from web, are not in relation anymore with my watch if I use only SA and SLink to update? right?Thanks!
 @flypg you dont need those settings per se. Also perhaps you want to keep your account there , just in case , perhaps MC does not go away
 @Dimitrios-Kanellopoulos
 if that would be the case will there be a way to load SA activities to MC?
 @TELE-HO said in Using Movescount web and Suunto app simultaneously: @Dimitrios-Kanellopoulos
 if that would be the case will there be a way to load SA activities to MC?You will wake up the Devil with this proposal  I must admit that SA as it is now, and still progressing, and MC upload (with correct metrics I must admit that SA as it is now, and still progressing, and MC upload (with correct metrics ) must be a killer solution (for me at least) ) must be a killer solution (for me at least)
 @TELE-HO nope
 Oh, manโฆ Keeping MC web around would make my day and my whole month!
 @TELE-HO a very good idea
 if that would be the case will there be a way to load SA activities to MC?If it were true that MC web will still be around, I believe it will work more in a way that it โreadsโ activities from Suunto Appโs/Sports Tracker database, therefore allowing Suunto to wind down the MC web backend (nor frontend).
 @Mff73
 dimitrios says itโs impossible to wake up the devil I was just curious as I am 100% on SA with my new s9b at the moment and my a3p is more or less compatible with MC AND SAโฆ
 itโs strange to use two watches from one company with two systems
 @TELE-HO said in Using Movescount web and Suunto app simultaneously: @Mff73
 dimitrios says itโs impossible to wake up the devil Forbidden fruit is sweetest
 I did not say anything      Lets wait for Start Of Nov
 Devil is awake
 @Dimitrios-Kanellopoulos said in Using Movescount web and Suunto app simultaneously: THANK YOU! Also perhaps you want to keep your account there , just in case , perhaps MC does not go away  @Mff73 said in Using Movescount web and Suunto app simultaneously:
 Actually I did not use so much MC app, for my experience, MC is the WEB INTERFACE.
 @zhang965 said in Using Movescount web and Suunto app simultaneously: Actually I did not use so much MC app, for my experience, MC is the WEB INTERFACE. I use MC app ONLY for its hability to link watch and MC web. MC app is nothing more than a working โsuuntolink mobileโ when normal suuntolink functionnality is blocked by SA customization. If we have a way to export activity from โโโโSAโโโโ" database (and not sportracker export) to MC, i delete definitively MCapp.
 Exporting ST data to MC with Syncmytrack or equivalent, creates bad things in MC for me (wrong activity type for example).
 @TELE-HO If you are on an iPhone you can sync between them using RunGap!
 @Brad_Olwin
 Does Rungap make proper sync between Sporttracker and Movescount ? No discrepencies (like trail running becoming running, or some activities becoming โOtherโ ).
 It happens with Syncmytracks (for me) on Android.
 @Brad_Olwin
 โunfortunatelyโ Iโm on android.
 but Iโll wait for November and see what it brings.
 my personal top favourite would be having SA on the phone and MC as web endโฆ it would be the best of both worlds
 I use Movescount web for add itinerary with Waypoints on my Ambit3 Peak. I use Movescount app for add structured intervals training on my Ambit3 Peak. I use Suunto app with my S9. On November 2, i have a 80km Trail running race with waypoints. Do you think this feature come on S9 with SA before my race?
 I have A3P. I never used SA, but Iโm curious to test it.
 Currently, after an activity, I use MC app or MC web.
 If I want to use also SA, should I first use MC app or MC web, close them and then use SA?
 Thanks,
 Meir.
