    Metric to Imperial Setting
    metricimperial
    7 Posts 5 Posters 1.3k Views 5 Watching
    • C Offline
      Captbrad
      Every time I change my setting from metric to imperial… it goes keeps going back to metric.
      Does anyone know how to keep it from switching?
        Brad_Olwin Moderator @Captbrad
        @Captbrad It sounds like you have metric set with a sync service, are you using SA alone? Is the app set to Imperial in settings as well as the watch? The watch is in General/Settings/Language/Unit System.
        • C Offline
          Captbrad
          Yes its set to imperial on the watch (suunto 9). After I close the app on my phone it the app switches back to metric on the app.
            Hi @Captbrad we had yesterday a service maintenance.
            That is affecting the settings sync from watch to the app.
            Please stand by, this should be fixed server side within this week.
            Sorry for the inconvenience.
            • C Offline
              Captbrad @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos thanks
                s5columbia
                I have the same problem. S5 with measurement units on the watch set to imperial. Every time I open the SA, the measurement units are in metric and must be changed in the settings menu. Also, the altitude source field is set by default to Barometer, but the S5 does not have a barometer. I have to change the altitude source setting to GPS every time I open the app.
                  freeheeler @s5columbia
                  @s5columbia
                  the altitude source in SA is only for recordings with your phone.
