    Suunto ambit3 peak cant found gps signal for an hour. Did any tips to help ?
    13 Posts 6 Posters 1.4k Views 6 Watching
    • Tang Chean ChoongT Offline
      Tang Chean Choong
      Suunto ambit 3 peak cant found gps signal more than an hour.1564662365498369185120105133123.jpg
      • Saketo NemoS Offline
        Saketo Nemo Moderator
        have you done the syncing with the app in last days?
          @Saketo-Nemo said in Suunto ambit3 peak cant found gps signal for an hour. Did any tips to help ?:
          and … Did you try a soft reset ?
          Suunto App Android 6.2.2 beta
            Tang Chean Choong
            Yes…i tried aoft reset couple time , but still not received signal gps
              than, you synced via cable or mobile app?
              Tang Chean ChoongT 1 Reply Last reply Reply Quote 0
              • mario_bM Offline
                mario_b
                press back+lap for 12 seconds. -> Info -> GPS sgee look if the date is old. if so. sync the watch via usb-cable with the computer.
                try searching gps under clear sky and point a antenna up. (the plastic bulk) without holding the antenna. should get a signal within around 5 minutes.
                thailonT 1 Reply Last reply Reply Quote 0
                  Tang Chean Choong @Saketo Nemo
                  @Saketo-Nemo will try by later
                  • thailonT Offline
                    thailon Bronze Member @mario_b
                    @mario_b nothing is happening after 12 sec of holding that lap+back button on my Ambit3 Peak (last firmware installed)
                    T3c, Quest, Ambit3 Peak, 9PP, Vertical
                      margusl @thailon
                      @thailon , should have been 2 upper buttons, back/lap + start/stop
                      And under service menu there’s also Action -> GPS Reset , might be worth to try this as well.
                      thailonT 1 Reply Last reply Reply Quote 3
                      • thailonT Offline
                        thailon Bronze Member @margusl
                        @margusl thank you, this combination does work.
                        • mario_bM Offline
                          mario_b @thailon
                          @thailon sorry, my fault. @margusl said the right thing. (Forgot start) 🤦‍♂️
                          Here you can see how old the gps infos are on your watch. If you sync over the cable gps position data will be updated. And you will find a quicker gps fix.
                          • thailonT Offline
                            @mario_b @margusl thank you, I just wanted to know this combination. Just for information. Thbere is the other guy having a problem with connection.
                              margusl @thailon
                              @thailon said in Suunto ambit3 peak cant found gps signal for an hour. Did any tips to help ?:
                              A3 user guide is quite complete and, among other bits that might not be too obvious, covers the service menu - https://www.suunto.com/Support/Product-support/suunto_ambit3_peak/suunto_ambit3_peak/features/service-menu/
