    Suunto 5 and quiet alarm (Vibration)
    10 Posts 5 Posters 755 Views 5 Watching
    • Lukasz Gawlik 0L Offline
      Lukasz Gawlik 0
      is there any way to configure alarm on Suunto 5 to avoid audio signal and limit it only to vibrations?
        sartoric Moderator @Lukasz Gawlik 0
        @Lukasz-Gawlik-0
        Yes you can !
        Ask your best friend : https://www.suunto.com/en-gb/Support/Product-support/suunto_5/suunto_5/features/tones-and-vibration/
        ๐Ÿ˜
        SVTS - 2.40.38
        Suunto App Android 6.0.2 beta
        Suunto App IOs 3.0.0 (20152) beta on MBP M1
        Armin S.A 1 Reply Last reply Reply Quote 0
        • Armin S.A Offline
          Armin S. @sartoric
          @sartoric Unfortunately, the vibration is very very weak at S5 and not reliable to feel.
          Mff73M Brad_OlwinB 2 Replies Last reply Reply Quote 1
            Mff73 @Armin S.
            @Armin-S said in Suunto 5 and quiet alarm (Vibration):
            yep, but it is @Lukasz-Gawlik-0 request ๐Ÿ™‚
              Brad_Olwin Moderator @Armin S.
              @Armin-S The vibration alarm is fine for me. I use it to wake up. It will repeat at 10 min intervals if you do not dismiss.
              • Armin S.A Offline
                Armin S. @Brad_Olwin
                @Brad_Olwin Youโ€™re right - I tested it again. The vibration for alarm is neat, because it vibrates several times until I turn it off. What I meant and what is VERY BAD, that is the TIMER (for example for my breakfast eggs)! The timer vibrates ONLY ONCE very gently and very briefly and is easily overheard! He is practically useless in this way for me.
                One possibility would be to turn the sound on - only then will it beep on every incoming message - which I do not want.
                Sorry for the misunderstanding.
                  @Armin-S I agree, I leave the timer with sound. It is weak.
                  • Armin S.A Offline
                    @Brad_Olwin Okay - but then you have the sound also with every incoming message - right?
                      Lukasz Gawlik 0
                      Thank you for your help!
                        @Armin-S Yes, I just set DND when I am in a meeting, easy to do.
