    Problem of cumulative elevation gain
    58 Posts 17 Posters 6.2k Views 18 Watching
    • suzzloS Offline
      suzzlo Moderator @Guest
      @silentvoyager ehh,m you were the guy that proposed new algo https://forum.suunto.com/topic/3078/let-s-talk-about-elevation-gain-counting-on-suunto-watches!!!
      Garmin: FR745, Edge 530
      SA topics:
        freeheeler @suzzlo
        @suzzlo
        yep and i was happy that suunto does not count the meter when i adjust a skiboot buckle or something similar… but the truth or the target for good ascent calculation is somewhere between these 3m and bending down to pickup a snack out of the backpack on the ground 👍
        • MarynM Offline
          Maryn Silver Members @Guest
          @silentvoyager I also did notice same behaviour
            A Former User @freeheeler
            @TELE-HO said in Problem of cumulative elevation gain:
            @suzzlo
            @TELE-HO, read the post linked above. I don’t advocate for removing the threshold. Bending to tie laces isn’t a big deal. The real issue is windy weather. Even with the threshold wind gusts may produce a lot of false elevation changes. But the algorithm could be improved to more accurately track the changes once the threshold is exceeded.
              freeheeler @Guest
              @silentvoyager
              how its solved will be up to the developers i guess… last week i thought of maybe letting fusedalti check more often or filter too fast climbs? maybe not for paragliding…!
                Brad_Olwin Moderator @PatBess
                @PatBess Suunto is aware of issues with altitude but it is a difficult one as arm movements for example need to be filtered out of the altitude gains. My altitude has been fairly reliable with the S9b, most of the time FusedAlti is activated and my gains/losses are close to those I have obtained with other watches.
                  A Former User @Brad_Olwin
                  @Brad_Olwin It isn’t a difficult issue at all. I’ve described the algorithm in details in my post (linked above) and it can be described in just a few sentences. By the way, I am a developer in a very well known software company myself.
                  Brad_OlwinB stromdiddilyS 2 Replies Last reply Reply Quote 0
                    Brad_Olwin Moderator @Guest
                    @silentvoyager said in Problem of cumulative elevation gain:
                    I know you are and I am not a software developer so definitely out of my league here. I agree that the averaging may be overly conservative as you posted below. However, if less conservative do you believe it would then be more accurate? I know enough about the testing to suspect that different averaging approaches were likely attempted.
                    Typically I watch total gain and elevation on long climbs that are not very fast so I do not see the delay in averaging. In non-baro watches the situation is much worse. Unless I am doing a big climb the elevation gain/loss is typically well below the actual value.
                    • stromdiddilyS Online
                      stromdiddily Gold Members @Guest
                      @silentvoyager can you walk me through how your proposal would handle a point to point route of 3m up, 2m down every 10m over 100m run?
                      Unless I’m reading it wrong, you’re suggesting that the “going down” calculation doesn’t kick in until you’ve triggered the min threshold from your “recent high” reading. Wouldn’t this end up with 0m descent over my example run?
                        A Former User @stromdiddily
                        @stromdiddily Do you think the current algorithm would produce non zero descent? It would be good to try but I doubt the result would be any different.
                          A Former User @Guest
                          @stromdiddily Just to give you one specific example - not exactly what you are asking for but something that I’ve actually done. I once had hill repeats on a very small hill where I went up and down about 5 and half meters - that was the difference between the high and the low points based on the elevation profile. I didn’t have any better hills in that area. I went up and down 30 times. My Suunto 9 counted only 90 meters of total ascent and 90 meters of total descent.
                            freeheeler @Guest
                            @silentvoyager
                            I’m not a software developer either, pure mechanics… but would it be possible to count every meter, store it and smooth the graph later with doublecheck of the independently stored gps alti graph?
                            • Fiox89F Offline
                              Fiox89 Bronze Member
                              On a recent excursion I noticed that the watch (suunto spartan) correctly records the right total elevation, but when it goes to synchronize the track on the application this is different. Also, the track log on the watch shows a different measurement, once the activity is interrupted, the same as the app.
                              From what I understand, the problem occurs when the recording of the activity is interrupted, so it is in the post processing of the data. Can anyone confirm?
                              Suunto Spartan Sport
                              FW: 2.8.24
                              SA: 4.17.7 beta
                                Dimitrios Kanellopoulos Community Manager @Fiox89
                                @Fiox89 no post processing of data is done at all
                                  freeheeler @Dimitrios Kanellopoulos
                                  @Dimitrios-Kanellopoulos
                                  then smoothing the graph isn’t possible either as I understand…
                                  there will be different options.
                                  Suunto teams will solve that, I’m sure 👍
                                  • FredMtF Offline
                                    FredMt Bronze Member @Guest
                                    @silentvoyager
                                    Yes i think your right, i practise running stairs. I have stop using elevation by suunto 9 baro because it was permantly under the reality. I used to do it by myself on movescount web site…, but now with Suunto app, it s impossible, elevation fields are not accessible in modification…
                                      Also I suspect that on Suunto 9 FusedAlti makes the total ascent and descent less accurate. I think that when FusedAlti kicks in and adjusts the altitude, that isn’t properly reflected in ascent and descent calculations and may artificially increase or reduce ascent / descent numbers.
                                      There is one run near my home that I tend to do a lot. That is a short 3.2 mile loop (just over 5 km). I ran it over 50 times - with Suunto 9 and earlier with A3P.
                                      Looking at Suunto 9 Ascent / Descent numbers I see that the ranges or ascent and descent are greater and the difference between ascent and descent for any particular run is also greater.
                                      More specifically ascent ranges from 188 to 246 ft, descent ranges from 184 to 259 ft, and the largest difference between ascent and descent in the same run is 50 ft (~ 17 meters).
                                      The explanation that I’ve heard before is that due to the weather change.
                                      However when I looked at earlier runs with A3P I’ve never seen a difference between ascent and descent for runs on this route greater than 10 ft (~ 3 meters).
                                      The values in general seem to be distributed more tightly (with fewer outliers) and over slightly smaller ranges: ascent - 197 to 236 ft and descent - 197 to 246 ft.
                                        freeheeler @Guest
                                        @silentvoyager
                                        and the question is: will Suunto be able to improve this?
                                        • Nick VlahandreasN Offline
                                          Nick Vlahandreas
                                          I’ve just posted about a similar issue. My issue kicked in around the same time as these posts and still we have had no response from Suunto on a fix.
                                          • BulkanB Offline
                                            Bulkan Moderator @Nick Vlahandreas
                                            @Nick-Vlahandreas said in Problem of cumulative elevation gain:
                                            Where did you post it? Did you get any response from Suunto?
                                            If you posted here I see your are getting responses and help. And you had one watch replacement.
                                            Please, let’s write about truth and don’t let the emotions write thing like: still we have had no response from Suunto on a fix.
