    1.1k Posts 159 Posters 242.8k Views 151 Watching
    • Mff73M Online
      Mff73 @Guest
      @g287-sf said in Future S9 firmware wishlist summary:
      I’m asking myself (again 😂) i know the temperature on a BARO watch is given by a sensor in the watch who catch ambiant temp of the body is strap to your arm or if you let it 10-15min straped to your bag it will give you the ambiant temperature.
      I don’t know if it’s possible to sync “local” temp via GPS like this everytime we record and activities it sync temp to. And if it’s possibile to sync it via the Suunto App ?
      And maybe it’s able to show us 2 differents temp like “Body Temp/ Outdoor Temp”
      do you know what is GPS ? it is not internet 🙂
        A Former User @Mff73
        @mff73 you can know the level of humidity in the air true the gps signal because thz more there is humidity in the air, the longer time it takes to transmit a signal and they used this system for meteo so maybe it’s possible.
        At least it should be possible when you sync phone and watch.
        check this : https://support.garmin.com/fr-FR/?faq=Mxs4eRXzRdAYJ0h7yyWaj9
        So why we can’t do it ? it should have something to do. we can improve this watch, add interesting feature and more.
        ldxmsgL Mff73M 2 Replies Last reply Reply Quote 0
        • ldxmsgL Offline
          ldxmsg Bronze Member @Guest
          @g287-sf That link just shows that you can use GPS to pinpoint your location, which can then be used by other systems to locate your weather forecast. I think you’re asking for the watch to be able to do that, as opposed to using GPS to use the baro sensor on the watch itself to provide a temperature reading? These are very different things.
          • Mff73M Online
            Mff73 @Guest
            With watch to phone connexion, it is another story : phone locates by GPS, phone download meteo with internet (if there is network where you are) of estimated location, and transmit to watch. But GPS signal itself does not contain temperature.
              @mff73 maybe i’m not realy clear in english. i’m ok it can’t work all the time especially in the mountains.
              But a majority of the time we are in the city, at home or worst at work.
              So i think we can synchronise trough the app.
              One time per day offering a " bulletin meteo".
              When your phone have converge it can update temperature each time you synchronise with it ?
              Is my idea as bad as this ?
              • Mff73M Online
                Mff73 @Guest
                @g287-sf
                not bad idea, just with misundertanding at beginning 🙂 you said ‘sync local temp’ via GPS 😉
                Ok, clear now, not bad idea, just it is a nice smartwatch option.
                S7 should have this, and I really doubt S9 will have this. But dreams comes true sometimes.
                ? isaziI 2 Replies Last reply Reply Quote 1
                  @mff73 i haven’t talk english since few years even more technically 😅
                    isazi Moderator @Mff73
                    @mff73 said in Future S9 firmware wishlist summary:
                    Yes the S7 has a weather forecast tile, and can install some weather apps too.
                    • TheGuyFromTheSummitT Offline
                      TheGuyFromTheSummit Silver Members
                      I really could use a new watch face, simple but with height/ date/ time/ sunset-rise.
                      Like the outdoor one, but with 4-5 fields
                      TheGuyFromTheSummitT 1 Reply Last reply Reply Quote 6
                        TheGuyFromTheSummit Silver Members @TheGuyFromTheSummit
                        @theguyfromthesummit ahh I totally forgot:
                        One dedicated “slide” only for sunrise and sunset.
                        That these times are only shown by 1-2 watchfaces is annoying.
                        digs_D 1 Reply Last reply Reply Quote 0
                        • digs_D Offline
                          digs_ @TheGuyFromTheSummit
                          Emoji rendered correctly on watch notifications.
                            Frederic Bronze Member @Rob33
                            @rob33 said in Future S9 firmware wishlist summary:
                            A function claimed for a long time has been integrated at garmin (14.72): an ULTRARUN sport mode to manage stops or refueling stations without stopping the stopwatch (time continues to pass) but by stopping the GPS (distance).
                            Choice between the optional functions either “Lap + Rest” or “Rest only”: by choosing this mode, after pressing Lap, the total elapsed time and the time spent in “stop” are displayed on the screen (this allows you to control the duration of the shutdown).
                            Press Lap again and the normal display resumes with the total time and the GPS reactivated.
                            Extra! When at Suunto?
                            is that what you are referring to ? https://youtu.be/IV3Vi0MoQOc?t=305
                            That sounds good on paper but when I go up a steep pass and walk slowly, will that be considered rest time too ?
                            My Suunto Workflow
                            MyTourbook - First Steps
                            Questions or bugs ?
                              Brad_Olwin Moderator @Frederic
                              @frederic and I would always forget to hit the buttons. The last thing I am thinking about at aid stations is to make sure I hit my lap button.
                              MiniForkliftM 1 Reply Last reply Reply Quote 0
                              • MiniForkliftM Offline
                                MiniForklift Platinum Member @Brad_Olwin
                                @brad_olwin said in Future S9 firmware wishlist summary:
                                Usually the last thing I am wanting to during a race is hit any buttons!
                                SV Titanium Solar Forest
                                  isazi Moderator @Rob33
                                  @rob33 so according to DC Rainmaker it does not stop the recording, it is just a black screen with a timer while everything is still measured in the background. The advantage is that the time the black rest screen is on it will be classified as “rest” in Connect. It is more or less what happens with strength exercises.
                                    Brad_Olwin Moderator @MiniForklift
                                    @miniforklift said in Future S9 firmware wishlist summary:
                                    I typically lock the screen during a race. I have 2 screens for ultras, very simple as well as a loaded route and altitude profile. On my phone or on a laminated paper I have a couple sets of aid station times for two different finish times, my best if all goes well and the cut off times. I usually save these as a wallpaper for my phone so if I turn my phone on I can see the aid stations, elevation gain loss between each aid, pace and time between aid stations.
                                    I don’t pay much attention to the watch during the race, but typically look at where I could have done better after a couple of days.
                                    stromdiddilyS MiniForkliftM 2 Replies Last reply Reply Quote 4
                                    • stromdiddilyS Offline
                                      @brad_olwin what screens d
                                      The phone wallpaper is a great idea. Curious - what do you have on the two screens?
                                        Probably a stupid question but how do you do this Brad? Not a bad idea and something I might look to try, especially for those longer ultra’s
                                        • ink357I Offline
                                          ink357
                                          A nice feature would be the VO2 max for trail (like an another brand 😅) taking into account the D+ and temperature
                                          T Łukasz SzmigielŁ BulkanB 3 Replies Last reply Reply Quote 0
                                            The_77 Silver Members @ink357
                                            @ink357 that’s just licensing another firstbeat module surely? The S9 has picked up firstbeat features since launch (recovery/stress) so it’s not implausible?
                                            Now that firstbeat are in-bed in-house with Garmin, it might happen, but we can but guess.
                                            ink357I 1 Reply Last reply Reply Quote 0
