    1.1k Posts 159 Posters 241.0k Views 151 Watching
    • ADHDMonkeyA Offline
      ADHDMonkey Bronze Member
      The S9 is a very solid platform in my humble opinion, and aside from these recent very irritating let-downs it could be a great watch.
      If I had any say I would take a step back and give a ‘minimalist’ option for those of us who value reliability over ‘gimmicks’. Even better would be to give users a bit more freedom - Similar to what Garmin does with the open source stuff. I bet there would be way better face options - to mention just one example - if that was the case.
        freeheeler @ADHDMonkey
        @ADHDMonkey
        reducing “gimmicks” and adding more faces is contradictory, no? 🤔
        some users have downgraded the firmware to the previous one and achieved more stability. maybe that would be an option while we wait for a further update?
        ADHDMonkeyA 1 Reply Last reply Reply Quote 1
          ADHDMonkey Bronze Member @freeheeler
          @freeheeler I did not say ‘more’ faces, I said ‘better’ faces. An improved and modern interface is not a gimmick in my book.
          What do I find contradictory is having to DOWNGRADE the FW to get better performance (I can’t even type that without giggling to myself 😆 ).
          Can you point me to official Suunto documentation that states that it is ok for users to downgrade the FW please?
          I’ve read on this forum that some people have had negative experiences with that and I don’t want to make things even worse.
          • BulkanB Offline
            Bulkan Moderator @ADHDMonkey
            @ADHDMonkey Downgrading is not supported.
            • Soft reset.
            • Factory reset.
            • Customer service to repair.
            I think these are the obvious steps.
              Is there any particular reason why there’s no option to select GPS+Glonass+Galileo?
                isazi Moderator @ADHDMonkey
                @ADHDMonkey yes, the chipset only supports GPS+X, newer chipsets support different configurations, such as using all GNSS systems at the same time.
                StorzS 1 Reply Last reply Reply Quote 3
                • StorzS Offline
                  Storz @isazi
                  Still hoping for a simple flash light triggered by a long press of one of the hard buttons. Turn the face all white, brightness 100%
                  Elementum Terra
                  Vertical Titanium Solar
                  Mitch9M 1 Reply Last reply Reply Quote 5
                  • Mitch9M Offline
                    Mitch9 @Storz
                    @Storz said in Future S9 firmware wishlist summary:
                    Simple but nice idea!
                    SA: Android (beta)
                    HRS: Polar H10
                    • EzioAuditoreE Offline
                      EzioAuditore Gold Members @Mitch9
                      I would like for the VO2Max algorithm to take into account the height difference or other environmental changes. For example I ocationally visit my grandparents village +1200m height from the place I live and the first days to week or more my VO2max drops a couple of points and fluctuates a lot until it stabilizes.
                        Brad_Olwin Moderator @EzioAuditore
                        @Hristijan-Petreski I work at 1700m and over or at 3000m almost every weekend if I am home. My VO2Max is reported about 5-8 ml/kg/min lower on the watch than on a test. Not terribly bad.
                        • MdzOttM Offline
                          MdzOtt
                          I think this was mentioned (and discussed in the past), but I would like to see an option to display all of the available parameters/values that the watch knows about (sunset/sunrise, altitude, temperature, HR, number of steps, etc.). All of them are available on some of the screens, but I don’t think any watch faces includes all of them (and rightly so).
                          I would make it accessible from the Settings or Shortcuts menu.
                          S9 Baro
                          SA on Android
                          Ambit 3 Peak
                          Ambit 2 Sapphire
                          • MiniForkliftM Offline
                            MiniForklift Platinum Member
                            It’s probably been asked for at some point but it would be great if the amount of screens you can add and configure for an activity would be higher. I also have a Garmin Enduro and that doesn’t have a maximum number of screens, you can setup as few or as many as you want; I’d really like to have the option of having more than only 2 or 3 available
                            SV Titanium Solar Forest
                            • Łukasz SzmigielŁ Offline
                              Łukasz Szmigiel @MiniForklift
                              @MiniForklift going this way - I’d like to be able to disable the vertical navigation as I very rarely use it and have an option to disable an S+ screen. This sounds weird but when using certain S+ apps like ie Burner I see no need to have the data displayed during the run. I’d rather have less screens to cycle as there’s no way to cycle back, only forward.
                              S9PP 2.44.52
                                I use the Dual time function as I travel quite a bit, so I’ll often alternate between a few different time zones/countries 🌇
                                Any possibility of having the city that it’s set to displayed rather than the ‘Dual time’ that’s currently shown? Seems like only a small change but it would be much more helpful 👍
                                sartoricS MdzOttM 2 Replies Last reply Reply Quote 1
                                  sartoric Moderator @MiniForklift
                                  @MiniForklift
                                  The “old” Spartan firmware shows the zone.
                                  I’m using it too since always 🙂 but also as digits representation of the current time
                                  Suunto App Android 6.3.3 beta
                                  • MdzOttM Offline
                                    MdzOtt @MiniForklift
                                    @MiniForklift On S9B it shows a “globe” as indication of the “world time”. The city idea went away a few firmware updates ago and it was replaced by the UTC +/- offset. I liked the “city” idea better, because it kept track of various daylight changes in different zones. Now you have to know when the time changes in the other time zone and adjust it manually.
                                    S9 Baro
                                    SA on Android
                                    Ambit 3 Peak
                                    Ambit 2 Sapphire
                                    • vio112V Offline
                                      vio112 Bronze Member
                                      https://forum.suunto.com/topic/7782/s9b-lock-screen-option-again/12
                                      So I compare new Suunto Vertical watch vs Suunto 9 Baro and SVertical has option “Touch screen lock” (see pic) and it has also only 3 buttons. Then I would like to really kindly ask for option “Touch screen lock” in time mode please 🙏
                                      flucaF 1 Reply Last reply Reply Quote 3
                                      • flucaF Offline
                                        fluca Silver Members @vio112
                                        @vio112 I think @freeheeler will appreciate that in a way or another if I am not mistaken
                                          This must be a mistake, the Vertical does not have a lock button outside of activity.
                                            freeheeler @fluca
                                            @fluca
                                            I wanted to say the same as @isazi
                                            I have seen this sheet before but don’t know the source.
                                            there’s nothing like a lock in watch mode, and it is not necessary IMO.
                                            surfboomerangS OktanO 2 Replies Last reply Reply Quote 0
