    1.1k Posts 159 Posters 241.1k Views 151 Watching
      freeheeler @surfboomerang
      @surfboomerang said in Future S9 firmware wishlist summary:
      my custom snowboard profile has disappeared
      no issues on my side with snowboarding this time
      • vio112V Offline
        vio112 Bronze Member
        Please I am really begging for option to enable/disable touch screen in time mode šŸ™ link text
          freeheeler @vio112
          @vio112
          but touch is always disabled until you press a button. only then touch is enabled, isn’t it?
          vio112V 1 Reply Last reply Reply Quote 0
          • vio112V Offline
            vio112 Bronze Member @freeheeler
            @freeheeler
            Well actually that is not true…it also activates when you get notification…for example I was on bike, I came home I went into the shower and then I get notification about daily calories, something like ā€œcongrats you’ve done your daily targetā€, so my S9B has been activated and it started scrolling up and down and it also accidentally run stopwatch and it goes just crazy…and of course as I said before you can not even use stopwatch in the water so for example I can not even measure breath hold of my buddy. Therefore I would like to have option to disable the touch screen in shortcut menu like ā€œMedia controlsā€ā€¦ this is sooo big disappointment for me and I really fighting with it 😄
            isaziI freeheelerF 2 Replies Last reply Reply Quote 2
              isazi Moderator @vio112
              @vio112 true, if there is a notification you can interact with the touch is enabled for few seconds. Would not be useful otherwise. If you get a system notification (one you cannot interact with), then touch is not enabled.
              Jamie BGJ 1 Reply Last reply Reply Quote 2
                freeheeler @vio112
                @vio112
                I see… mainly with stop watch in water is a bigger issue than I thought!
                and the one with the shower… it’s annoying and it gives the impression as if someone stopped racing 10m before the finish line šŸ™„
                vio112V 1 Reply Last reply Reply Quote 1
                • vio112V Offline
                  @freeheeler @isazi
                  Therefore guys let’s start to push up this topic please šŸ™
                  Let’s get as many VOTES as we can get for option to enable/disable the touch screen in shortcut menu like ā€œMedia controls"
                  Please VOTE for this bug fix šŸ™šŸ™šŸ™šŸ™šŸ™šŸ™
                  • MiniForkliftM Offline
                    MiniForklift Platinum Member @Egika
                    @egika That’s great. just tried it and that is the case for me. Having the watch remember that you don’t use HR was something I’ve asked for a few times so really cool to see that it’s been implemented. Nice job šŸ”ŗ
                    Just wondering if you change anything else such as battery performance; for your next workout does it recall all of the previous settings that were applied, or is it only for HR?
                    SV Titanium Solar Forest
                      stuba81 @surfboomerang
                      @surfboomerang @isazi I might give it a go. I did use custom sports modes early when S9 was release. I remember they were all reseted after updates so I did not bother to update them after few tries. Great if this is better now.
                        Jamie BG Bronze Member @isazi
                        Its been a while since I last used it, but I am pretty sure I remember the S7 having a hotkey lock screen/button option.
                        Surely S9 could have the same options…
                        I do like how Garmin have implemented theirs on the Epix/F7 - you have an option to lock touch screen and an option to lock buttons & touch screen in the control wheel, plus you can set them as hotkey and your get the option to enable/disable touchscreen for system navigation, activities and or sleep; and then you get the ability to set this for individual activities to by going into the activity and changing the default setting. i.e. I have touch off for activities, but for strength training I have gone into the activity and changed the setting for it to be on (find it easier to adjust rep count, set count etc using touch screen); and have done the same for hiking for maps, but running for example its off, and if I need touch screen for the maps I just press my hotkey combo and hey presto can now pan/zoom in maps using touch.
                          freeheeler @Jamie BG
                          @jamie-bg
                          sounds like Garmin almost made the perfect watch, if they would have added the option to have touch enabled while buttons locked šŸ˜‰
                          …I know, I’m pretty demanding!
                          but only because S7 has a lock function, does not mean S9 will ever receive this function.
                          It’s too long since the first serious request for it. Simple things are normally either done soon or never šŸ˜‰
                          Brad_OlwinB Jamie BGJ 2 Replies Last reply Reply Quote 2
                            @freeheeler said in Future S9 firmware wishlist summary:
                            @jamie-bg
                            They did not, I have a hate/like relationship with my Epix 2, more the former than the latter. Overall, I do not think the compromises are worth changing for. But, my opinion and others will vary. You can indeed lock the watch down. Fortunately, I did not have the accidental button press issues with the S9baro, nor do my friends that have the watch. However, I get it and think it would be good to implement.
                              freeheeler @Brad_Olwin
                              @brad_olwin
                              don’t worry, a lock function only won’t drag me away from Suunto šŸ˜‰
                              • K Offline
                                krakra Bronze Member
                                When we will get option to have usable maps on suunto app ios when there is no signal. I understood that this is working fine on android phone.
                                  freeheeler @krakra
                                  @krakra
                                  maybe not completely offline, but it seems to cache the area of your last zoom in the map
                                    Jamie BG Bronze Member @freeheeler
                                    @freeheeler no button lock with touch free unfortunately - the only combo they missed.
                                    MiniForkliftM 1 Reply Last reply Reply Quote 2
                                    • K Offline
                                      kamarasm Bronze Member
                                      With the last firmware update we got the SuuntoPlus Guides, which is a longtime waited function I think. The implementation is really elegant and straightforward.
                                      For daily use I don’t allow sound just vibration, but for the Guides it would be better with sound, especially in cold or raining weather while I’m wearing jacket.
                                      I really like to have a possibility like switch in sport mode, I can allow sound for sport mode or Guides. It would be easier then going in Shortcuts, Settings, General, Tones, General, Tones.
                                      isaziI 1 Reply Last reply Reply Quote 4
                                        isazi Moderator @kamarasm
                                        @kamarasm I am totally with you. My preference is vibration only in daily mode, but vibration and sound during activity.
                                          I’d still like an hourly alarm, just a simple beep would be nice 😊
                                            MiniForklift Platinum Member @Jamie BG
                                            @jamie-bg +1 from me. I was never really looking for that feature but after recently purchasing a Wahoo Elemnt Rival that has it I can attest to it being very useful!
