    1.1k Posts 159 Posters 241.2k Views 151 Watching
    • pilleusP Online
      pilleus @dombo
      @dombo thanks for SPM, another way to get the correct data.
      Even if I have intervals on the treadmill the Vertix 2 is spot on with the distance. May be it is because I am the average human being. But I don’t understand why there is no calibration on the S9B immediately after the workout to adjust the distance and to take this value (SPM and calibrated distance) for future trainings!?
      Suunto Vertical Black Lime
      Suunto 9 Peak Pro Black
      • W Offline
        wakarimasen Silver Members @pilleus
        @pilleus said in Future S9 firmware wishlist summary:
        After a mountain bike ride with navigation of a planned route I want to write my experience and the wish to change the popup screen … S9B mounted on the handle bar.
        While mountain biking I have not much time to look at the popup screen which announces a left or right turn. Just a second or two, especially in down hills.
        The screen looks like this …
        To the information in the upper black section should be added a white symbol , here an arrow pointing to the right side behind the text “Rechts/Right”, an arrow pointing to the left side in front of the text “Links/Left”. This information can be recognised in a second or even faster. The distance is okay, but it should count down while the screen stays on the display until the point is reached. The time is obsolete, because while biking there is always 00:00 or 00:01 as value. I think that the navigation on the Polar watches is the one which is the best for cycling.
        With the mountain bike or road bike I use the navigation screen to have the route displayed all the time. With the disadvantage that no other information is available (altitude, ascent, distance, speed).
        Thanks for reading and I hope that it is clear what I meant. 👍
        +1 for turn symbols rather than text, for us hikers with non 20-20 eyesight!!
        Suunto Race Titanium
        Suunto Ambit3 Peak
        Polar H10
        Polar OH1
        flucaF 1 Reply Last reply Reply Quote 7
          darguelles Bronze Member @freeheeler
          @freeheeler
          A feature similar to Garmin’s Virtual Run app to enable us to use the watch as a HR monitor when using Zwift or Wahoo. Currently there’s no way to use them without generating duplicate sessions.
          • flucaF Offline
            fluca Silver Members @wakarimasen
            @wakarimasen On this respect, I have seen the review of the you tube channel the run testers on the suunto 5 peak. I feel what they said about navigation is true. Unfortunately is not good, but is true. I strongly advice Suunto developers to have a look.
              Brad_Olwin Moderator @fluca
              @fluca said in Future S9 firmware wishlist summary:
              Link?
              • Fenr1rF Offline
                Fenr1r @Brad_Olwin
                @brad_olwin
                https://www.youtube.com/watch?v=-syDs3Tmrjk.
                flucaF DMytroD 2 Replies Last reply Reply Quote 1
                • flucaF Offline
                  fluca Silver Members @Fenr1r
                  @fenr1r thank you, Yes that’s the right one.
                    DMytro @Fenr1r
                    @fenr1r I think they might be a little too harsh. However, I agree with TbT criticism - I think it was kind of underdiscussed in the forum.
                    Overall, I’d say there are two-three major points, that were also mentioned by other reviewers and users and I’m confident suunto’s going to address them in the future.
                    • lexterm77L Offline
                      lexterm77 Bronze Member @DMytro
                      Just a thought.
                      Baro sensor filtering choice:
                      Baro off for crazy outings on 100kmh wind gusts
                      Baro filter high for mid crazy weather
                      Baro default filter (auto)
                      Baro filter off for very nice stable weather and accurate recording (works only when weather stable)
                      DMytroD freeheelerF 2 Replies Last reply Reply Quote 0
                        DMytro @lexterm77
                        @lexterm77 but your hands swing when you walk/run - it already creates both wind and altitude changes. If you move with e.g. 10kmh, the wind moves against the sensor hole with 10kmh. So I’m not sure if no filtering at all would be a good idea even in the nicest of weathers. But it may be interesting to have an option of changing the aggressiveness of the filter.
                        lexterm77L 1 Reply Last reply Reply Quote 2
                          @dmytro
                          I don’t swing them that fast, and when I swing them motion sensor does know it.
                          lexterm77L DMytroD 2 Replies Last reply Reply Quote 0
                            freeheeler @lexterm77
                            @lexterm77
                            is it that bad with wind effect?
                            I dare to say that I’ve never experienced that… and I also go outdoors when it’s not only sunshine and blue sky… the only issue I have is blocked holes on sweaty forearm or wet sleeves.
                            IMHO best solution S9P 👌
                            lexterm77L surfboomerangS 2 Replies Last reply Reply Quote 0
                              lexterm77 Bronze Member @lexterm77
                              It is also possible to share sensor data via BT multiple Suunto Watches with Baro, so you can have 3 watches is like having one watch with 3 sensors. If you want more accuracy, buy more watches 😁
                                lexterm77 Bronze Member @freeheeler
                                @freeheeler
                                I’ve posted before data when I had 90kmh gusts. With A3P on a bike it was much worse than S9B. But S9B was struggling to keep Baro data flat and on a flat route I seem to have climbed half a km.
                                In any case with high wind gusts Baro data is almost useless.
                                  DMytro @lexterm77
                                  @lexterm77 yeah, actually combining the data of motion sensors to adjust the filtering sound interesting, not sure how well it can be implemented though. One may even try to write an algorithm that recognises periodic noise and adjusts just that part - exactly for arm swings or something similar.
                                  lexterm77L 1 Reply Last reply Reply Quote 1
                                  • surfboomerangS Online
                                    surfboomerang @freeheeler
                                    @freeheeler I can show you some tracks of windsurfing
                                    Both water and wind are no friends with the baro sensor 😄
                                    I guess that’s why Suunto decided to shut it off for those kind of sports.
                                    lexterm77L freeheelerF 2 Replies Last reply Reply Quote 1
                                      @dmytro
                                      Its all about power and whether you need to design a small FPGA that can process data. I don’t deal with watches but with hydraulic transducers and I have one nano second bit operation processing time. In the world of watches, things are different and your imagination quickly outruns budget.
                                        lexterm77 Bronze Member @surfboomerang
                                        @surfboomerang
                                        Exactly. Imagine two Suunto units sharing Baro data. One you leave at base camp and one you go for the peak. At the end you come to the peak and back, you stop, it sync Baro data from your activity AND from watch at base camp. Then you compare it all. Winds will NEVER match, and if you didn’t travel 100km, atmosphere region pretty much share similar pressure. That way you can have much more accurate shots at the real altitude. Wind or no wind.
                                          freeheeler @surfboomerang
                                          @surfboomerang
                                          …and maybe because you will not do so high climbs in windsurfing… maybe jumps 😉
                                          surfboomerangS 1 Reply Last reply Reply Quote 2
                                            @freeheeler True. It took a while until Suunto realised it though. Altitude was recorded for a long time in windsurf activities (it still is, but it’s not shown in SA)
                                            Now that I’m thinking about it, I’m not sure if this means storm alarm isn’t also working. That’s a metric I’m interested in during the activity
