    Suunto 9 baro adjust altitude during trackinghike
    suunto9baro
    10 Posts 4 Posters 657 Views 4 Watching
    • pcm_smeetsP Offline
      pcm_smeets
      Since one week I am using my new suunto 9 Baro watch.
      Before I had a Suunto Traverse Amber.
      With my previous watch I adjusted the altitude everytime during my hike. For example when I am at a mountainhut.
      But I can’t find the option on my Suunto 9 Baro. Who can tell me how I can adjust the altitude manually during tracking a hike?!
        FusedAltitude should help with keeping altitude in check during an activity, because I guess you can’t calibrate the altimeter during activities.
          pcm_smeets
          Too bad. I could adjust it with my suunto traverse amber
            freeheeler @pcm_smeets
            @pcm_smeets
            it adjusts automatically on the fly and if I understood it correct this will be improved with the next FW update
              pcm_smeets
              Okay. Today I was hiking in my town. Altitude is 22. But watch kept saying its 7
              So that’s why I would like to change it manually
              But okay. I understand the watch should do it by itself. And accurate?
              isaziI N 2 Replies Last reply Reply Quote 0
                isazi Moderator @pcm_smeets
                @pcm_smeets you can calibrate, either manually or with GPS, before an activity.
                • N Offline
                  nseslija Bronze Member @pcm_smeets
                  @pcm_smeets I always ajust the altitude if I known it before exercise… if I do that within 30 min before exercise FuseAlti will be disabled, if I understand that well…
                  Ambit 2S
                  Ambit 3 Peak
                  Suunto 9 baro
                  Suunto Vertical Ti Solar
                    freeheeler @nseslija
                    @nseslija
                    is it?! interesting, did not know that.
                    But I once asked if someone knows more details about fusedalti… no answer yet.
                    I also adjust alti frequently at home where I know the exact altitude.
                    When fusedalti activates it is sometimes up to 30m wrong.
                    that’s what I understood should be fixed with next FW update
                      pcm_smeets
                      So if I understand it well… I manually adjust the altitude BEFORE starting my hike.
                      And I can’t adjust it anywhere else during my hike?! The suunto 9 should do it automatically?!
                      Okay thanks
                        @pcm_smeets
                        yes
