Suunto 9 Baro - deteriorating battery life
35 Posts 10 Posters 2.5k Views 10 Watching
    Joohlin
    Since I updated my Suunto 9 Baro about three weeks ago the battery life has deteriorated. Before the updated I could use the watch every day 24/7 and work out three - four times a week and the battery would last for ca seven days. After the updated the battery only lasts about 4-5 days with out having done any work outs as I got a severe cold the day after making the updated.
    Has any one else experienced the same or is it just my watch that is giving up?
    /Johan
    G 1 Reply Last reply 3 Dec 2019, 05:43 Reply Quote 0
      GingerBeardMan Bronze Member @Joohlin
      @Joohlin Someone did suggest running the battery completely flat before charging it after the update but I think its a case of “more features less battery life”. I have been told that the battery life was not because of a big battery but from efficient use of power so I suspect that battery use during activities is unlikely to change but the first beat features will cause faster battery drainage.
      J 1 Reply Last reply 3 Dec 2019, 05:50 Reply Quote 1
        Joohlin @GingerBeardMan
        @GingerBeardMan Thanks for the answer.
        So one should expect to charge every three our four days from now on?
        G 1 Reply Last reply 10 Dec 2019, 06:54 Reply Quote 1
          My estimate is that with 24/7 hour battery tracking, standby backlight on, and syncing to SA the watch consumes about 1% of battery per hour, which is less than 5 days total. That isn’t counting any activities.
          • I Offline
            I did an experiment and got to five days with only a short activitity (without GPS), and still had battery for a sixth day left.
            F 1 Reply Last reply 3 Dec 2019, 09:57 Reply Quote 0
              freeheeler @isazi
              I could imagine it is premature wear on @silentvoyager 's watch
              ? 1 Reply Last reply 3 Dec 2019, 17:24 Reply Quote 0
                A Former User @freeheeler
                @TELE-HO said in Suunto 9 Baro - deteriorating battery life:
                I doubt that. Until recently I was charging my watch only once every two weeks. I see a high consumption like that only when 24/7 monitoring is on and syncing to SA.
                And you know what, I turned all features off last night when the watch battery was 51%. This morning after a run with GPS the battery is still 49% which means the background consumption was less than 1% for the entire night.
                F 1 Reply Last reply 3 Dec 2019, 19:57 Reply Quote 1
                  freeheeler @Guest
                  @silentvoyager
                  ok so you can at least exclude this.
                  I’m just draining my battery to recalibrate it amd then I’ll also go off for 24/7 HR again and see how this changes batterylife.
                    @Joohlin Sorry for the late reply.
                    Pretty much, unless you disable the 24h tracking.
                      Bogdan1921 Silver Members Bronze Member
                      It seems that in the last time (probably after the last update), the battery of my watch (Suunto 9 Baro) drain faster.
                      100% - 07.04. - 16:20
                      79% - 08.04. - 16:40
                      59% - 09.04. - 16:23
                      41% - 10.04. - 16:38
                      16% - 11.04. - 17:23
                      0% - 12.04. - 12:00
                      (No activity in this period)
                      I brough this watch in November 2018, and at the beggining the battery leastead almost 7 days (without activities).
                      From the beggining until now I keep the same settings:
                      Backlight Automatic
                      Standby - On
                      Brightness - 40%
                      24/7 tracking - On
                      Sleep tracking On
                      Notifications On
                      So if any setting was changed, what is wrong?
                      Many thanks
                      Bogdan
                      Suunto Race
                      Polar H10
                      Iphone 14 Pro
                      Suunto 9 Baro [sold]
                      I 1 Reply Last reply 12 Apr 2020, 10:19 Reply Quote 0
                      • I Offline
                        isazi Moderator @Bogdan1921
                        @Chindris-Bogdan battery consumption increased slightly after the fall 2019 update that brought body battery and other Firstbeat features.
                          Thank you for answer!
                          It’s possible maybe to have a better optimization of the battery with the new firstbeat features and maybe with other features that will come?
                          Best,
                          Bogdan
                          Suunto Race
                          Polar H10
                          Iphone 14 Pro
                          I 1 Reply Last reply 17 Apr 2020, 08:51 Reply Quote 0
                          • I Offline
                            @Chindris-Bogdan we’ll see what future brings us. So far I am OK with charging my watch every calendar week, exercising every day.
                            Of course battery life is never enough for some of us, and if the watch could last for two weeks I probably would want three 😄
                            F B 2 Replies Last reply 17 Apr 2020, 10:59 Reply Quote 2
                              freeheeler @isazi
                              @isazi said in Suunto 9 Baro - deteriorating battery life:
                              4 😁
                                Bogdan1921 Silver Members Bronze Member @isazi
                                And when it should be 1 week, in reality there are only 4 days and so on…I don’t want two weeks, three or four. It’s just annoying that from seven days now I’m at four.
                                Cheers
                                Suunto Race
                                Polar H10
                                Iphone 14 Pro
                                I 1 Reply Last reply 17 Apr 2020, 15:18 Reply Quote 0
                                • I Offline
                                  @Chindris-Bogdan 4 days without any exercise?
                                    Yes, in this period it’s impossible to make exercises…
                                    Suunto Race
                                    Polar H10
                                    Iphone 14 Pro
                                    I 1 Reply Last reply 17 Apr 2020, 16:02 Reply Quote 0
                                    • I Offline
                                      @Chindris-Bogdan well 4 days without any exercise seems too little. Have you tried a soft reset already?
                                        Yes, I’ve tried, but with the same result.
                                        From my older post, to see my settings:
                                        0% - 12.04. - 12:00
                                        Backlight Automatic
                                        Standby - On
                                        Brightness - 40%
                                        24/7 tracking - On
                                        Sleep tracking On
                                        Notifications On
                                        What is different in your settings?
                                        Suunto Race
                                        Polar H10
                                        Iphone 14 Pro
                                        I A 3 Replies Last reply 17 Apr 2020, 18:03 Reply Quote 0
                                        • GNZ ctG Offline
                                          GNZ ct
                                          Try standby backlight “off”
                                            consent.not_received
