    Suunto 9 with the recent GPS firmware was among least accurate GPS watches in today's 25K trail race
    221 Posts 34 Posters 40.9k Views 32 Watching
      Dimitrios Kanellopoulos Community Manager @Łukasz Szmigiel
      @Łukasz-Szmigiel I didn’t know about what you just said but yeah it sounds possible because I can think about a reason behind it, that actually has many times caused a headache.
      When the “GNSS lock” / “SOLID Green arrow” happens it means that the signal is quite good for you to go on. It aint perfect. Depending on the environment it will vary.
      Now consider that a quick start (for running mainly) means arm movement, a lots that is, and a “good” GNSS lock.
      I think we can all agree it can drop the “signal strength”/“lock quality” quite easily, as in contrast to cycling with little arm movement. Why would it then?
      Here is an extra case: Hard conditions (eg canyon) to get a lock, and after a weak lock, you go run in the forest in the canyon. … You might loose GPS.
      I hope it makes a little sense. What I wrote above applies to all brands, and is less/more effective depending on the antenna position. I hope it helps
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @Dimitrios Kanellopoulos
        @Dimitrios-Kanellopoulos thanks for explanation. I was suspecting fusedspeed and the way firmware interprets GNSS signals to avoid zigzagging between readings.
        Here’s a run from today, fresh, for reference. I’ve started running right after obtaining GNSS lock (GPS + Beidou) but pressed start after ~50 meters. Conditions were meh at best - it was raining all day and it’s still overcast. QS link.
        I’ve marked actual path in pink:
        1. Here you can see start and finish (~35 minutes later). Start is offset while finishing path is spot on, I’d say up to 3 meters.
        2. Continued from last screenshot.
        3. And right before I’ve entered the park when it auto corrected after a short path on embankment. This is interesting as I’ve entered a wooded area but nevertheless the accuracy improved and the offset was gone from that moment.
        Just to be clear - I’m not complaining, I just find this behavior fascinating and I’d like to dig deeper into it and perhaps know how to reduce it when accuracy may be more important than on a regular “everyday run”.
        S9PP 2.44.52
        O 1 Reply Last reply Reply Quote 2
        • O Offline
          ollemelin Bronze Member @Łukasz Szmigiel
          @Łukasz-Szmigiel
          Yeah, I think a Quick start is one reason behind the issues im having. My wifes garmin 735 takes a good bit longer to aquire gps signal. Ideal i would like to have a big screen before I press start reling me how good signal is from 1 to 5 :).
          With that said, I still have a lot more spikes in my data compared to others in same conditions. Maybe garmin have an algoritm that smooths over those spikes. I don’t know.
          I did order a stryd yesterday so hopefully that will lower my blood pressure. I live in Sweden and there are trees and forests everywhere so GPS-readings are never going to be that precise anyway.
            Łukasz Szmigiel @ollemelin
            @ollemelin if you can, try waiting for a little bit longer on a start screen before you actually hit “Start”. I used to stand in place where sky visibility is good and slowly rotate with my arm in front but I no longer do it since the firmware that introduced Beidou is good enough to begin the workout without any extra rituals 😉
            Some extra data about GNSS quality on a start screen would be a nice addition but I doubt it honestly. Suunto seems to be on a “don’t bother users with too much data” side and I think it’s wise.
            I did have a glimpse on my last workout on QS and Runalyze and it really seems that Suunto is doing its magic with fusedspeed which results in those strange offsets in recorded paths. This is pretty logical - if GNSS is poor and the path would be wobbly but the pace takes priority, the line has to be straight. So the error at the beginning of a turn will persist until the direction changes above certain threshold.
            1. This is the start area - you can see that GNSS quality was poor by looking on altitude diagram. It should be around 120 meters but is way higher and dropping as I run (I have an S5, so there’s no baro). But the pace is rock steady regardless of poor GNSS readings. Also, after enabling “Show points” in QS, it seems that the actual points on the map are more spread apart in this area than in the open - so the watch must behave differently if it’s unsure of it’s position.
            2. Now take a look on the same area on Runalyze and its pace chart - it oscillates like mad between 5 and 8 min/km.
            So it really seems to me that Suunto is doing good job to provide as accurate data as possible during the run but since it’s impossible to do this without sacrificing something, it chooses to do a recorded track offset in order to provide more accurate tempo and speed readings.
            I have never seen anything like it before with different hardware - it’s more common to have a zig-zag pattern when GNSS reception is poor, as the path is constantly drifting and it’s being reflected on the record.
            But if you think about it - it’s better to have more accurate predictions about pace and speed than a GNSS path that is constantly wobbling from right to left. But the effect is a constant offset until something dramatic happens (I assume it’s either a sudden change in direction, speed or GNSS precision increase).
            Neat and practical programming.
            Btw. @Dimitrios-Kanellopoulos, kudos for “Show points” in QS - it’s great for analyzing such events. You can clearly see that the watch has two modes of saving data where the dots are either more or less condensed - I assume it’s related to GNSS reception.
            S9PP 2.44.52
              freeheeler
              I think something went bananas today… some segments were right to the point and some completely off
                @TELE-HO COROS + VANTAGE + SONYS had issues yesterday. Logically SOny chip issue. If you need links …
                Mff73M surfboomerangS 2 Replies Last reply Reply Quote 4
                  I had bad GPS yesterday as well, but no Sony in my Spartan 🙂 GPS Fix was long, need to sync again AGPS, and track is bad
                  But no complain, i enjoyed my almost nighty, and totally rainy workout 😉
                    Only Sony? Can this be chip specific? GPS errors affects all chips right?
                      @surfboomerang not sure, but for sure I saw sony issues.
                      Check the COROS group. They had huge offsets and also our fieltest team
                        @Dimitrios-Kanellopoulos this is pretty crazy how it affects whole range of products that use the same chip. But on the other hand it shows how much can still be done with GPS firmware to optimize it.
                        S9PP 2.44.52
                          @Łukasz-Szmigiel typically this can also be caused by a combination of wrong AGPS + FW
                          For example one time one Galileo Sat was down, aka should not be used, Sony forgot to update the AGPS to include this change and voila. I was steady at a spot locked to that orbiting sat going with crazy speeds around my house.
                          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 3
                            @Dimitrios-Kanellopoulos cool story. It seems that the chip relies heavily on AGPS data. I wonder how much really and what will happen in the event of AGPS malfunction (ie. system outage on Sony side).
                            S9PP 2.44.52
                              sartoric Moderator @Łukasz Szmigiel
                              @Łukasz-Szmigiel
                              In the ol’times 😁 getting a fix on an handheld gps took a lot
                              Usually you had to turn it on when you almost reached the location, just to start looking the sky, so you had to wait only 5/10 minutes before having a good readings 😁
                              … then phones started using agps …
                              Suunto App Android 6.3.3 beta
                              freeheelerF Łukasz SzmigielŁ ? 3 Replies Last reply Reply Quote 2
                                freeheeler @sartoric
                                @sartoric
                                I remember that time… when I carried a backpack for the gps device 😉
                                  sartoric Moderator @freeheeler
                                  @TELE-HO
                                  … and external cabled antenna 😁
                                    @sartoric
                                    that was possible with mine, but I did not invest in that 😉
                                      A Former User @Guest
                                      In general for me GPS on S9 is very good and reliable. Some days ago I meassured a typical route via google maps. S9 said exactly the same distance after running. Also very much important and outstanding is FusedAlti. It went so incredible accurate! Wow!
                                        Łukasz Szmigiel @sartoric
                                        @sartoric I remember that too. But A in AGPS should mean assisted, right? Not Absolutely useless untill on LTE 😉
                                        Jokes aside, things like this year’s february bug or offline Galileo sat that @Dimitrios-Kanellopoulos mentioned shouldn’t interfere with GPS receiver more than with a longer fix.
                                        S9PP 2.44.52
                                          A Former User @sartoric
                                          @sartoric said in Suunto 9 with the recent GPS firmware was among least accurate GPS watches in today's 25K trail race:
                                          @Łukasz-Szmigiel
                                          I don’t know how they manage it, but on the garmin etrex 30x which has no connection to internet the fix is quick.
                                          That is something that sometimes puts me off into newer devices…you seem you can’t get that “pick it and go” you had with old ones like etrex 30x and ambit 2/3.
                                          I remember when I got the ambit 2 even without same days sync it was blazing fast to catch gps signal.
                                          With the polar rc3 I had before, not as fast but max wiating 1min-2min.
                                          Today I hear about continuous resets, having to wait sometime after sync so agps files can do this and that on the watch, plus gps firmware.
                                          Ok, so what is the added value that this new devices bring in order to compensate all the trouble (sincerelly asking)
                                          • BulkanB Offline
                                            Bulkan Moderator @Guest
                                            @André-Faria said in [Suunto 9 with the recent GPS firmware was among least accurate
                                            How many resets did you have? Just curious.
