    S9 Baro titanium not measuring VO2Max or fitness levels with 2.10.18 - is this a known problem?
    39 Posts 13 Posters 3.4k Views 13 Watching
      lost_today Bronze Member @ink357
      @ink357 that could be the problem
      I would do a hard reset. That’s what I did this morning then it basic run and got my fitness level
      • ink357I Offline
        ink357
        The watch is not a new, i wanted to try the new functions. Now i’ll make a hard reset with all new settings
          @ink357
          @Dimitrios-Kanellopoulos said in S9 Baro titanium not measuring VO2Max or fitness levels with 2.10.18 - is this a known problem?:
          To get VO2max you need good HR readings and a bit of effort (go to zone 2+ ) from my experience
          SVTS - 2.48.16
          Suunto App Android 6.4.7 beta
          • ink357I Offline
            ink357
            I think HR was good because there is no loses.
            I’ve made a hard reset… and lost my personalized exercises 😰
            How to add basic exercises in the watch ? Just make one and it will add ? Or i need to do that in SA ?
            Let’s try tomorrow !
              freeheeler @ink357
              @ink357
              it’s a great disadvantage that sport mode customization is not stored and backed up in SA!
              • ink357I Offline
                ink357 @lost_today
                @lost_today said in S9 Baro titanium not measuring VO2Max or fitness levels with 2.10.18 - is this a known problem?:
                @ink357 hi
                I asked suunto help centre about this.
                You need to do walk/run for calibration but after this your levels should change doing any exercise type.
                I have just done calibration today. So I have not tested this yet. But will let you know results mi week.
                Are you sure ? I finally got a vo2max estimated last thursday. But today after my ride in bike mode no changes. It was a 1 hour ride and i went in the 5 zone of HR.
                Someone can confirm that the vo2max estimated will change after every exercices in all sports mode ?
                • cosme.costaC Offline
                  cosme.costa @ink357
                  @ink357 said in S9 Baro titanium not measuring VO2Max or fitness levels with 2.10.18 - is this a known problem?:
                  @ink357 hi
                  I think only works with running activities.
                  • ink357I Offline
                    ink357
                    I just come from a walk exercise and the vo2max has changed…
                    Maybe that is just for for walk and run basic exercise. It make sense because the 2 exercises that gave me a vo2max estimated were with ascent, so the vo2max is so poor. To have good data the ground must be flat, no ?
                    sartoricS cosme.costaC 2 Replies Last reply Reply Quote 1
                      sartoric Moderator @ink357
                      Yes it is.
                      Correct. At least to have good/reliable estimation.
                      https://www.firstbeat.com/en/consumer-feature/vo2max-fitness-level/
                      SVTS - 2.48.16
                        cosme.costa @ink357
                        With Trail Running sport mode you will have also VO2 estimation, in my case it is pretty consistent with the flat runs, but maybe my trail runs are flattish for the algorithm (not for me), I do between 300-450m for 13-14 km and the VO2 only changes some tenths.
                        ink357I 1 Reply Last reply Reply Quote 1
                        • ink357I Offline
                          ink357 @cosme.costa
                          @cosmecosta i’ll try with this type of exercise next time. Maybe with bike exercise it need a power sensor to give data.
                          What about the custom exercises ?
                            cosme.costa @ink357
                            From what I have read bike exercise won’t give you VO2, am I right @Dimitrios-Kanellopoulos?
                            Regarding custom sport modes if they are based on running/walking sport modes you won’t have problems. Actually my running and trail running sports modes are custom ones.
                            • ink357I Offline
                              ink357
                              Somebody can tell me why my vo2max is so poor ?
                              https://image.noelshack.com/fichiers/2020/04/7/1580058503-0468bab2-ca4f-432b-be8f-718e7b3b0b9d.jpeg
                              surfboomerangS BulkanB 2 Replies Last reply Reply Quote 0
                                surfboomerang @ink357
                                @ink357 I think it is the combination of a pace of 7:30 min/km in combination with an average heart rate of 170.
                                What is your max HR?
                                • ink357I Offline
                                  ink357
                                  My HR max is actually 189
                                  • Anatoli AngelovA Offline
                                    Anatoli Angelov Bronze Member
                                    In order to have correct measurement of VO2Max you should run on flat terrain.
                                    Trail running with lots of ascent for sure will result in worse VO2Max.
                                    • BulkanB Offline
                                      Bulkan Moderator @ink357
                                      @ink357 is your weight correct in the watch? Check it out.
                                      VO2max is related with weight.
                                      ink357I 1 Reply Last reply Reply Quote 0
                                      • Václav KrálV Offline
                                        Václav Král
                                        Polar A360, Polar M600, Polar M430
                                        Suunto Spartan Trainer, Suunto Spartan WHR Baro
                                        Suunto 9 Baro
                                        Coros Apex Pro
                                        Google Pixel 2
                                        • ink357I Offline
                                          ink357 @Bulkan
                                          @Bulkan said in S9 Baro titanium not measuring VO2Max or fitness levels with 2.10.18 - is this a known problem?:
                                          That is Ok. I’m 73kgs to 1,8m
