    Suunto 9 Baro quick discharge problem
    85 Posts 28 Posters 15.3k Views 28 Watching
      Atlen
      Hello everyone,
      I am not sure it is the right forum to post that kind of messages. I do appreciate if someone will share the link to elated forum then.
      My suunto 9 baro are everyday usable and the problem i recently faced with is getting me frustrated.
      SA and firmware were everytime updated once the notification received. I mainly focussed on almost every day either pool swimming or outdoor running, 1-1,5 hours workout per day in average.
      A week ago strange things started to happen. My battery drains unnaturaly fast. Means 100% in approx 24 hours. What have i noticed since such symptome appears:
      1. The power consumption while running/swimming is still the same as before.6-10% per hour of intensive workout with HR and GPS.
      2. The power optimization measures recommended by Suunto guide are not giving any relief, means the same fast discharge.
        Taken the abovementioned into account i could summarize that there is no battery issue but software instead.
        The official service center asks me to bring the watches for check and leave for upto 45 days what is too long for me.
        Therefore i would like to know whether someone solved same issue and ready to explain.
        Thank you for any support and Happy New Year!
      Suunto S9 Baro
      Suunto Ambit3 Sport
      Suunto smart sensor
      IPhone 12, iOS 14
      • surfboomerangS Online
        surfboomerang
        First thing to try: soft reset
        Press upper right button for 12 sec until it reboots
        Second thing to try: hard reset
        Connect the watch to your PC and reflash the firmware
        Third thing to try: wait 45 days
        Send the watch back to Suunto and wait for repairs
        A 1 Reply Last reply Reply Quote 2
          A Former User @Atlen
          @Atlen said in Suunto 9 Baro quick discharge problem:
          I don’t have an answer for your super fast discharge while outside of activity, but wanted to mention that 10% per hour is definitely not normal during an activity. The watch is rated for 25 hours with GPS and optical HR, which means 4% per hour. Adding Glonass and standby backlight may add a bit (I think it is 5% per hour with GPS+Glonass), but the numbers you mentioned are still too high.
            Atlen @surfboomerang
            @surfboomerang thanks for advise. Points 1,2 done a while ago - no effect.
            Point 3 I would like to avoid, therefore post on forum.
            Suunto S9 Baro
            Suunto Ambit3 Sport
            Suunto smart sensor
            IPhone 12, iOS 14
              Atlen @Guest
              @silentvoyager thank you for feedback, 10% per hour as per my previous experience is suitable for most power consuming mode while running, GPS + HR on watches activated.
              If you think that even in such conditions it is higher then should be then I had to address the point much-much earlier.
              Suunto S9 Baro
              Suunto Ambit3 Sport
              Suunto smart sensor
              IPhone 12, iOS 14
                isazi Moderator @Atlen
                @Atlen it is way higher than it should be, please contact support and send your watch in for repair/swapping.
                  Atlen @isazi
                  @isazi I did it. The watches have been replaced. The same issue.
                  After playing with different features i would conclude that Mobile notifications consume enormously big amount of power. Once switched off the watches’ life back to regular behaviour.
                  On the other hand i am not sure the reason the service provider replaced my watches with new ones))
                  Suunto S9 Baro
                  Suunto Ambit3 Sport
                  Suunto smart sensor
                  IPhone 12, iOS 14
                  jseguirJ 1 Reply Last reply Reply Quote 0
                  • jseguirJ Offline
                    jseguir Bronze Member @Atlen
                    @Atlen I think that some combinations (watch+phone) have issues with BT connection and drains battery. In my case, Suunto Spartan Sport + Android BQ Aquaris Xpro, with BT activated in phone, battery drains very quick
                    Suunto Spartan Sport blue 2.8.32
                    Suunto App (Android) 4.35.2 beta
                    Suunto Ambit 3 Peak 2.4.17
                    Footpod: Stryd & Milestone Pod
                    From lost to the river…
                    cosme.costaC A 2 Replies Last reply Reply Quote 1
                    • cosme.costaC Offline
                      cosme.costa @jseguir
                      @jseguir said in Suunto 9 Baro quick discharge problem:
                      I had the same with a BQ Aquaris X (No Pro)…, I’ve changed the phone for a Motorola One Vision and looks quite better now, but I’m using the “test” apk shared by @Dimitrios-Kanellopoulos, are you using this apk too?
                        Good point @cosmecosta
                        we have a special Android app version to test if needed. Would you want me to share this?
                          Atlen @jseguir
                          @jseguir may be the combination is causing such issue. I do not know how to enforce my combination work with full range of needed features on and reasonable power consumption. Nevertheless i would recommend to develop the soft tool to monitor power consumption by various modes on Suunto watches. It could be helpful to indicate the problematic point in-house. And it could also bring useful stats to Suunto developers’ team.
                          Suunto S9 Baro
                          Suunto Ambit3 Sport
                          Suunto smart sensor
                          IPhone 12, iOS 14
                          • DurriD Offline
                            Durri
                            Three hours a week I run, something on the treadmill or outdoors (depending on the weather). I use Stryd and HR belt. My watch lasts 11-12 days.
                            I only use the watch in energy save mode, without HR measurement.
                            Suunto Race Titanium, Suunto 9 Baro Titanium, Polar V800, Vostok Anchar Europe Titanium, Hoka One One, Focus Atlas 6.8, Rose Pro SL, Giant Roam 2
                            • Cuba1hrC Offline
                              Cuba1hr
                              @Durri I hope I will get similar (or near) times when I get back to both outdoor running and treadmill in 2-3 weeks for about 4 hours a week + circuit/gym training. I would be glad with once a week charge if there’s less GPS activity. I would like to use daily and sleep HR.
                              It should be noticeable difference in battery usage with treadmill vs outdoor performance gps+galileo or other positioning system.
                              I just mentioned in other topic - The battery on S9B (almost) without touching buttons and about 5 minutes of total backlight time lasted for 16 days (it is at 9% now), every tracking off (daily HR and sleep) in airplane mode and I was complaining. This is fine.
                              BTW, off topic - my couple of years old miBand 2 is on 38th day since charge (now at 3%) with daily and sleep tracking, calls/notifications ON and everyday alarm (it has much better and noticeable vibration than S9) with few times a day checking time/date, steps and battery, always connected with BT. That is impressive. 🙂 Specs say 30 days.
                              I was hoping to replace it with S9, especially during the night for wake up alarm, but vibration on S9 is so weaker. Also the step counting I mentioned… 🙂
                              • Jonathan NewbyJ Offline
                                Jonathan Newby
                                Just to add my Penny’s worth. Charge my S9 last night from 2% to 100% went to bed with it on. When I woke up it was on 88% .
                                  zhang965 @Jonathan Newby
                                  @Jonathan-Newby
                                  The HRV detector needs a lot of battery
                                  Jonathan NewbyJ 1 Reply Last reply Reply Quote 0
                                    Jonathan Newby @zhang965
                                    @zhang965 don’t get me wrong. Not complaining just making an observation.
                                      @Jonathan-Newby don’t get me wrong. Not complaining just making an observation.
                                      • Cuba1hrC Offline
                                        Cuba1hr
                                        Observation - lost 50% in exactly 3 and a half days (charged just before midnight on sunday). Daily activity and sleep HR ON, Notifications OFF, Flight mode ON.
                                        No other usage (including syncing or touching buttons), light OFF all the time. I had about similar percentage after the first night. That should be one week battery life as in specs, but I don’t know if they count in backlight and notifications. If they do, there’s no way to get 7 days battery life.
                                        BTW - I just saw reviews of Huawei GT2 (and Honor Magic 2), as a sort of competitor to Suunto 7 (and 9 in a way) for daily watch with sport features, and they get impressive battery life of 2 weeks with daily and nightly tracking, accurate GPS and OHR…at much lower price.
                                        zhang965Z isaziI 2 Replies Last reply Reply Quote 0
                                          zhang965 @Cuba1hr
                                          @Cuba1hr
                                          Before the HRV firstbeat feature (body resources) has been delivered, S9 could definitely go for a week or longer, but the HRV takes too much battery,
                                          Have you tried to turn off the daily HR and see how it goes?
                                            isazi Moderator @Cuba1hr
                                            @Cuba1hr said in Suunto 9 Baro quick discharge problem:
                                            Daily HR and sleep tracking consume quite some battery. There is a thread about this in the forum.
