    Suunto 7: Breaks in Fit daily heart rate
    57 Posts 8 Posters 7.1k Views 9 Watching
      trinitao
      Hi everyone, new Suunto 7 user here from Germany. Sorry for digging out this old thread, but I have exactly the same issues that @NickK describes. The daily heart rate measurement in fit does’nt start automatically, and even after activating it once there are more gaps than graphs throughout the day. I guess it would be even more if I would’nt check it continuously. Even in the phases where it seems to work the interval varies between 2 measurements per hour and 1 measurement in 2 hours. Last week it worked fine for two days, but after a reboot it was all like before.
      I was wondering if there is any solution or workaround for that issue, since no posts came here anymore. Or did I just miss anything? I bought the Christmas special edition two weeks ago, so this should be a fairly new device and it runs on the latest software. I’m also not sure what @Dimitrios-Kanellopoulos means with battery optimization for fit. I just know the power saving mode of the watch and battery options in the Suunto wear app.
      Thanks for your help!
      Matt
      pilleusP 1 Reply Last reply Reply Quote 1
        Jamie BG Bronze Member @pilleus
        @pilleus updated last night again to 2.49.13-230
        • pilleusP Offline
          pilleus @trinitao
          @trinitao I deactivated the sync from Suunto wear app to Google and deactivated an overlay from Suunto on the watch. The heart rate is shown proberly in Google Fit, even if I use several watches over the day. So far, no problems with my special setup.
          You could use the app heart trace 2 to have a continously heart rate reading and export to Google Fit.
          This would be the easiest solution. 👍
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          T 1 Reply Last reply Reply Quote 2
            trinitao @pilleus
            @pilleus Thanks for your reply! I think your setup  doesn’t work for me as I still want the Suunto Data to be exported to Fit.
            Heart trace 2 could be an option, if it doesn’t drain the battery and sync works fast enough that I’m still able to use the Fit tile properly (left swipe section). Do you have experiences with this already?
            I wonder what could cause this behaviour with some devices. Doesn’t seem to be a hardware problem. Could anyone with this issue manage to get Fit work as expected or should I contact the customer service in this case?
            pilleusP 2 Replies Last reply Reply Quote 0
            • pilleusP Offline
              pilleus @trinitao
              @trinitao said in Suunto 7: Breaks in Fit daily heart rate:
              Suunto data can be exported to Fit via Strava and SyncMyTracks. You do not loose anything. But you will get steps and 24/7 hr in Google Fit natively instead.
              • pilleusP Offline
                pilleus @trinitao
                @trinitao
                Here my workaround.
                • Disable the sync of Suunto wear app to Google Fit.
                • Enable steps, 24/7 hr in Google Fit.
                • Connect Suunto phone app to Strava.
                • Disable salmon.overlay on the Suunto 7 via adb.
                • Use SyncMyTracks to sync activities recorded with the S7 from Strava to Google Fit.
                Then you will have:
                • Steps (all) and hr (of recorded activities) in Suunto phone app.
                • Steps and 24/7 hr in Google Fit.
                • Recorded activities in Suunto wear app, in Suunto phone app and in Google Fit in the phone app and the wear app even on other WearOS watches.
                That’s working flawlessly for me. No missing data in Google Fit and a continous heart rate graph in Google Fit.
                T 1 Reply Last reply Reply Quote 3
                  trinitao @pilleus
                  @pilleus Thanks a lot for your help. I read about your salmon workaround in another thread. Do you know if this will affect the warranty of the watch? And will a factory reset undo these changes in case this doesn’t work?
                  • pilleusP Offline
                    pilleus @trinitao
                    @trinitao activating developer options and enabling ADB to install or disable a service will never affect warranty.
                    The changes are made only in the settings of the actual user, because your device is not rooted and the changes can be undone at every time and of course with a factory reset.
                      trinitao @pilleus
                      @pilleus Thanks again! I think I’ll give it a try.
                        trinitao
                        Hey everyone, unfortunately still no solution here. Sync from hearttrace 2 to Fit App on Smartphone works, yet it doesn’t sync with the Fit App on the watch. Meaning I’m not able to see the heart rate graph in the Fit tile.
                        This is crucial for me, because I like the short look at the widget section with a left swipe. Not anyone having the same troubles? I’d really  like to get it to work as it should, without third party apps (except they can be implemented in the widget section).
                        • pilleusP Offline
                          pilleus @trinitao
                          @trinitao you disabled salmon.overlay?
                          T 2 Replies Last reply Reply Quote 0
                            trinitao @pilleus
                            @pilleus Not yet. Couldn’t find any time over the week. But l’m not sure how this would solve my problem. If I understand it right, you did this because of syncing interferences between Suunto wear and Fit on your different watches. But that’s actually not the relevant point for me. I just have the Suunto 7 and wouldn’t even need Fit, if the Suunto App had daily heart rate implemented (and a nice widget to have a short look at it over the day). But as this is not the case, I just want Fit to show me a constant 15 minute heart rate in the app and the widget. But it just does it once or twice per hour, sometimes with breaks of 2 or 3 hours, and has to be started manually every morning after airplane mode. No deleting of cache, data, updates or de- and reactivating could help so far. Don’t get me wrong, but I’d rather like to avoid downloading, signing in and syncing between 3 different apps that I don’t even use in general. Or did I just miss anything and the Salmon overlay is the cause to this behaviour?
                              trinitao @pilleus
                              @pilleus Does your fit tile work properly and shows the heart rate / graph from hearttrace 2 measurements immediately? Or don’t you use it? I switched the syncing options in the heart trace 2 app to immediately, which works just fine for the smartphone app, but not the watch. When I try to deactivate the heart rate measurements in fit, the tile doesn’t even work anymore.
                              • pilleusP Offline
                                pilleus @trinitao
                                @trinitao
                                • Google Fit doesn’t record heart rate in shorter intervals than once or twice per hour if there is no activity recorded.
                                • I have all data in Google Fit and on the screen opened via heart rate tile (a graph with daily heart rate, all listed activities of the current week with heart rate graph).
                                • I do not use heart trace 2.
                                • Heart rate data are shown in the Google Fit app and on the S7. It does not matter if the data are out of recorded activities or out of the heart rate measurement of Google Fit and it does not matter which WearOS watch is delivering the data.
                                pilleusP T 2 Replies Last reply Reply Quote 3
                                • pilleusP Offline
                                  pilleus @pilleus
                                  Here the heart rate graph of the Fit tile in the morning captured on the S7, recorded during the sleep with my Skagen Falster 3. The graph is available on all my WearOS watches and in Google Fit on the smartphone.
                                    trinitao @pilleus
                                    @pilleus said in Suunto 7: Breaks in Fit daily heart rate:
                                    @trinitao
                                    Okay, first time I hear this. When I did my research for the S7 most of the reviews told about a 15 Minutes interval.
                                    Unfortunately I can’t confirm this for myself. Seems that Fit on the watch just shows the data it recorded by itself and is not syncing the Fit data from the server. Strange, because the syncing to the server works.
                                    Thanks for sharing the graph. Can’t show you mine, because I don’t wear the watch overnight. But my graph is always full of gaps according to the ones that @NickK posted below.
                                    Could you please explain me in a few words what’s the main function of Salmon.overlay and what does the deactivation cause?
                                    • pilleusP Offline
                                      pilleus @trinitao
                                      @trinitao the question about the overlay can be answered by Suunto only.
                                      I used the S7 for a few weeks without any Suunto apps and services (all disabled via ADB). I just used Ghostracer to record my rides.
                                      In this time I recognised that the sync with Google Fit and the shown data are correct and nothing is missing.
                                      From a Mobvoi Ticwatch Pro 2020 I knew that there was an overlay too which can be disabled to speed up the watch.
                                      So I let the salmon.overlay disabled after reenabling all Suunto stuff.
                                      No problems and nothing is missing in the S7 functions up to the moment.
