    Offline Map outside of Activity?
    12 Posts 5 Posters 756 Views 5 Watching
    • StorzS Offline
      Storz
      Is the offline map available outside of an activity on the S7? Does Google Maps work offline on the S7?
      Elementum Terra
      Vertical Titanium Solar
      Brad_OlwinB 2 Replies Last reply Reply Quote 0
        Brad_Olwin Moderator @Storz
        @Storz Yes. Suunto maps are available offline as are ViewRanger but not Google.
        StorzS 1 Reply Last reply Reply Quote 1
        • StorzS Offline
          Storz @Brad_Olwin
          @Brad_Olwin said in Offline Map outside of Activity?:
          Outside of an activity?
          Elementum Terra
            @Storz Yes
              you can just open the app, (on the watch and go up) that should do it .
              You can also use the Suunto app on mobile for example
                @Storz The downloaded map area as well as all heatmaps are available offline. Quite useful for navigating when traveling. The Suunto Outdoor map shows businesses as well.
                giulioG 1 Reply Last reply Reply Quote 0
                • giulioG Offline
                  giulio @Brad_Olwin
                  @Brad_Olwin
                  Hi…
                  I bought sunnto 7…
                  I have some problems, about offline maps my s7 dont save on watch…i already try on charge and with wi.fi (router phone).
                  S7 say me always download suspended…
                  Can you help me?
                  Yak ImaY 1 Reply Last reply Reply Quote 0
                  • Yak ImaY Offline
                    Yak Ima Bronze Member @giulio
                    @giulio The process is:
                    • Configure WiFi on the watch
                    • Go into Suunto App and click on map options
                    • Select offline maps
                    • Select your area and confirm
                    • Put the watch on the charger and wait
                    I’ve always had successful results downloading maps
                    • giulioG Offline
                      giulio @Yak Ima
                      @Yak-Ima
                      I have already do…for hours on charge and wi-fi
                      Doesn’t download…
                        Dimitrios Kanellopoulos Community Manager @giulio
                        @giulio reboot the device
                        • StorzS Offline
                          Storz
                          Thanks all. How do I recenter the map on my location once I start panning around?
                          Elementum Terra
                            @Storz just press/touch the center of the map and it will center on your location.
