    Battery LIfe
    450 Posts 54 Posters 87.8k Views 55 Watching
    • Fenr1rF Offline
      Fenr1r @MeazzaS9
      @meazzas9 From OCR->Gtrans, those are some distinctly Chinese apps (& whatever “Suunto Dial” is):
      I vaguely remember hearing something about the last one … maybe as a Chinese Twitter …
        MeazzaS9 @Fenr1r
        @fenr1r but i never searched, installed these apps. does it happen to you too?
        • Fenr1rF Offline
          Fenr1r @MeazzaS9
          @meazzas9 It hasn’t, so far, but my phone tattles back to Cupertino.
          Some friendly Androidster(s) here may share their wisdom, tho’. Let ‘em know what phone you’ve got & how you acquired it, perhaps.
          • olymayO Offline
            olymay Gold Members @MeazzaS9
            @meazzas9 I’ve just had a look through my Suunto 7 and I can confirm I have all of those apps installed too. It looks like they are part of the system and can’t be removed (unless you start diving into some advanced methods, but that may cause more problems).
            I am getting an easy 48hrs battery life from mine, so I doubt these apps are the issue.
            It does seem your Bluetooth battery usage is very high.
            Right now my S7 is at 64% battery (fully charged at 1300 GMT yesterday, it is now 0913 GMT) and the Bluetooth usage is at 3%.
            Compared to your settings, mine are as follows:
            • Continuous heart rate ON
              *Bluetooth on with all notifications on
              *WiFi set to auto
              *Auto updates active
              *Sleep monitoring enabled
              *I never put my watch into aeroplane mode.
            I do put my S7 into cinema mode overnight, but that is purely to stop the screen lighting up and to put it into do not disturb mode, I don’t believe it would affect the battery much, if at all.
            You say you put it into aeroplane mode when not in use, what do you mean by not in use? When you are not wearing it?
              Those apps are there if you are in China. You know WearOs cannot have some Google software in China because of restrictions. Nothing weird.
                MeazzaS9
                Today activated from airplane mode at 7.15am 94% and 7.20pm was at 10% …
                I only use bluethooth, no GPS activity, my phone is Samsung A40.
                Granted that all Wear OS and Samsung apps are up to date. There have been days that the bluethooth has absorbed 3% in 3 days of single charge…what could have happened ??
                Shall I try to reset?
                  MeazzaS9 @MeazzaS9
                  @meazzas9 said in Battery LIfe:
                  the cell phone is always with me so always connected to the bluethooth
                    MeazzaS9 @olymay
                    @olymay said in Battery LIfe:
                    *WiFi set to auto
                    At home I don’t wear it so I put it in airplane mode
                    • olymayO Offline
                      For a day or two could you try wearing it whilst at home and therefore not putting the watch into aeroplane mode? I’m not sure why or how this could be causing the drain, but it’s worth ruling things out.
                      Honest question, is there a reason you don’t wear it home? By not wearing the S7 you lose out on much of the benefits of the health tracking - 24/7 HR, body resources, sleep tracking, etc. These all only work if the watch is worn for as long as possible.
                      I recently had random and sudden battery drain, but I am pretty confident mine was down to YouTube Music. Even after removing YTM I still had the issue, I had to do a full factory reset to clear it.
                      Have you had any other apps installed recently (particularly YTM or Spotify?) that you have subsequently removed?
                        MeazzaS9 @olymay
                        I do not wear it at home simply out of habit, even for sleep monitoring I am afraid of breaking it.
                        Yes, I tried to install you tube music but without success (it was an area with little field) so I canceled almost immediately, could it be enough to complicate things?
                        Which app should you use for offline music not have problems?
                        • olymayO Offline
                          I can one thing for certain, you will not break this watch whilst sleeping. The S7 is built like a tank and is very, very strong! I have clonked mine against brick walls, dropped it on the floor, bashed it on trees, fallen over wearing it, snagged it on clothes, and more. And the watch itself still looks almost brand new (the original strap however is now looking less than pristine!).
                          Please, do not worry about breaking this thing.
                          If you want to get the most of out the health monitoring - recourses and sleep tracking, etc. - then try wearing it 24/7 (although I recommend not wearing it in the shower/bath, as any soap that gets trapped behind it can cause skin problems - this is the perfect time to charge it instead).
                          Since you have tried YouTube Music and deleted it and are experiencing a similar issue to what I had, this seems a bit of a coincidence to me. I believe YTM is flawed (as is Spotify) and causes battery drain. The only way I was able to resolve it was to do a factory reset (although I didn’t have long to explore options, as I needed the watch urgently for a race).
                          Other apps for offline music - I can’t help here as I haven’t used any, sorry.
                          One thing I will say however, is that listening to music from the watch will rip through the battery, as it stops the watch entering low power mode during activity tracking.
                          I did some tests in the past (with offline music on Spotify, but it would be the same with any player) and was getting roughly 30% battery drop per hour. When I wasn’t listening to music I was getting roughly 10-12% drop per hour. Quite a difference!!
                          My recommendation is that if you want to listen to music then either take your phone, or a small mp3 player etc. Listening to music from a WearOS device is possible, but it eats through the battery.
                          Jamie BGJ M 2 Replies Last reply Reply Quote 0
                            judnoe
                            Buenos días.
                            Para escuchar música tengo instala la app WearMedia, tanto en el móvil como en el reloj.
                            Solo la instale para probar la transferencia de archivos de música del móvil al reloj y para probar los auriculares BT.
                            No te puedo decir como se comporta con la batería, ya que solo lo use para jugar con el reloj.
                            Normalmente llevo el móvil y escucho la radio.
                              @olymay @MeazzaS9
                              I found that NavMusic worked well for me in regards to playing my own offline music.Might get around 6-7 hours using this from what I remember. (Has a built in transfer system from phone to watch or you can use his NavExplorer app).
                              I will also confirm what @olymay says in regards to its durability - you have to try really, really hard to damage this watch, and normal use will not do it (even hitting the road hard barely marked the bezels flanges).
                              Will slightly disagree on the showering - in that while this was also my common time for charging, to tack advantage of sleep tracking & resources - you also do want to wash the watch semi-regularly (just remember to lock the touch screen) - especially if you have been sweating. I also recommend switching to opposite wrist when sleep tracking, to give your normal wrist a break and a chance to breathe.
                              • olymayO Offline
                                olymay Gold Members @Jamie BG
                                @jamie-bg said in Battery LIfe:
                                My comments on the showering are due to there being a chance of a small amount of soap residue getting trapped and staying in contact with the skin. This can cause skin problems which people usually then attribute to the watch.
                                Personally, I think it more important to remove the watch when showering, to ensure the wrist is thoroughly cleaned and rinsed off.
                                I always rinse my watch in fresh water after every exercise, and in 18 months of use there is no gunk or residue anywhere on the watch, not even in the smallest nooks.
                                  MeazzaS9 @olymay
                                  Even today 14% went away for the bluetooth, I will try the reset.
                                  I will wear it as much as possible
                                  It seems absurd that having wears os I am forced to keep the clock by default because any app gives problems, or am I wrong?
                                  I keep you updated
                                  • olymayO Offline
                                    That does seem very high. I have just charged mine to full, so can’t check what my Bluetooth usage is right now, but I will have look again tomorrow and Sunday.
                                    Make sure you have continuous HR, resources, and sleep tracking turned on. I think you’ll find the data quite interesting - and hopefully useful.
                                    I’m not sure what you mean? You can install many apps and use them happily on the watch. I’ve used Google Keep a few times with great success. I also use the assistant on my watch a fair bit.
                                    However, where this watch really shines is in the fitness tracking and health data.
                                    I keep you updated
                                    Please do 🙂
                                      MeazzaS9 @olymay
                                      I keep you updated
                                      Please do 🙂
                                      Even when I reset my S7 the battery problem remains.
                                      Loaded at 10 am to 8 pm it is 23% without particular use … some notification.
                                      It is objective that there is a problem
                                      He had a period that in 2 days absorbed 2/3% the bluethooth
                                      isaziI olymayO 2 Replies Last reply Reply Quote 0
                                        isazi Moderator @MeazzaS9
                                        @meazzas9 contact support.
                                        • olymayO Offline
                                          olymay Gold Members @isazi
                                          @isazi said in Battery LIfe:
                                          I echo this, something definitely isn’t right. My S7 is at 47% battery and the estimated life left is approx 1 day 2 hrs.
                                          • olymayO Offline
                                            @meazzas9 i promised an update on my S7 from Friday, sorry for the delay. I accidently put it on charge briefly on Saturday (it’s automatic for me to put it on charge when I have a shower), so it has lasted a bit longer then expected.
                                            During this time, I did no activity tracking (letting a knee injury recover) but did receive quite a large number of notifications.
                                            As you can see, the battery life is significantly more than yours, but what stands out to me is the Bluetooth battery usage. It does seem like this is where your battery is being drained. Maybe a setting is causing an issue? Either on the watch or the phone? Or maybe there is a hardware issue? Contacting support may be your best best, sorry 😞
                                            Side note, have you tried wearing it 24/7 yet? Have you got the body resources and sleep tracking data? If so, how are you finding it?
