    Suunto 7 Altitude Issues
    321 Posts 34 Posters 69.5k Views 35 Watching
    • Aleksander HA Offline
      Aleksander H Bronze Member @freeheeler
      @freeheeler said in Suunto 7 Altitude Issues:
      the general advice is to soak the watch in a glass of water over night and use a very soft
      Can the S7 handle being submerged in water 9vernight without risk?
        freeheeler @Aleksander H
        @aleksander-h
        yes, it should survive it… just don’t press any buttons when submerged 😉
          @freeheeler cleaned with unused toothbrush. Here is a new 1 hour balcony test.
          Not sure why it went up, but at least the suunto app says 0 m up and down.
          • BulkanB Offline
            Bulkan Moderator @Aleksander H
            @aleksander-h Why are you doing a stationary test?
              Aleksander H Bronze Member @Bulkan
              @bulkan because I can’t leave the office 😆
              Aleksander HA 1 Reply Last reply Reply Quote 2
                Aleksander H Bronze Member @Aleksander H
                10 m in 1 hour seems not to unreasonable to me. I’ll have to go for a few walks and runs, but I’m guessing things are actually good now! Which is an immense relief 😆
                  Mff73 @Aleksander H
                  @aleksander-h
                  looks better, indeed 🙂
                    Aleksander H Bronze Member @Mff73
                    @mff73 thinking about it. 10 m increase in altitude is more or less equal to the offsett I see on my SSU (I often get roughly 10 more ascent then descent despite starting and stopping at the same place). So it seems fixed!
                    Now all I have to do is spend the rest of the day tapping the update screen…
                      Well. After the update I did a 15 min short lunch walk to get out of the house/office. I’m happy to say the elevation graph looked beautiful! No wonky lines, ascent where I expect it to be, descent where I expect it to be!
                      Thanks for all the help forum posters!
                      Mff73M 1 Reply Last reply Reply Quote 3
                        Brad_Olwin Moderator @Aleksander H
                        @aleksander-h If the exercises have the exact same time the app may filter one out. Just make sure you start one 20-30sec before or after they other, then they will sync fine. I have had this happen as well.
                        Aleksander HA EgikaE 2 Replies Last reply Reply Quote 0
                          Aleksander H Bronze Member @Brad_Olwin
                          @brad_olwin said in Suunto 7 Altitude Issues:
                          I started them both at exactly the same time, and ended both at exactly the same time. So it is definitely no surprise if the Suunto App thought “nope, don’t need that one”.
                          Thanks for the tip. Hopefully though, my SSU can go back to being a reserve watch now 😄
                            Mff73 @Aleksander H
                            @aleksander-h said in Suunto 7 Altitude Issues:
                            Welcome (on behalf of other helpers also 😉 ) You are now officially knowledge repository of ascent/altitude issues 🙂 and official next helper 😂
                            Aleksander HA 1 Reply Last reply Reply Quote 4
                              @mff73 I look forward to telling people they need to stick a soft toothbrush carefully into the baro hole 😆 .
                              I’ve picked up a few cool tricks along the way. Extracting the zip file from the android app and uploading the samples.json file to qs gave me all sorts of cool stats I didn’t know I could view!
                                @aleksander-h
                                Suunto takes care that we grow with our challenges 😁
                                  Egika Platinum Member @Brad_Olwin
                                  @brad_olwin is this new?
                                  so far I have often recorded activities with both S7 and S9 and always have had duplicates in the app.
                                  Now on Sunday it was the first time that I ended up with only 1 activity in SA after syncing the two watches.
                                  • C Offline
                                    cesareluca
                                    Hi all,
                                    I have the same issue with altimeter measurement jumping high and low of about 12 meters. I tested the watch with Altimeter wear os app and the readings confirm the continuous wrong measurement.
                                    Moreover I noticed that gently squeezing the bezel or the back of the watch I systematically can change the altitude up and down.
                                    I think that there is a hardware problem…
                                    Someone can confirm?
                                    Brad_OlwinB Mff73M 2 Replies Last reply Reply Quote 0
                                      Brad_Olwin Moderator @Egika
                                      @egika No, but to be honest it seems random. I am now making sure my activities start or end 20s apart.
                                        Brad_Olwin Moderator @cesareluca
                                        @cesareluca contact support
                                          Mff73 @cesareluca
                                          @cesareluca
                                          With same problem, do you eventually try the solution a few post above ? Cleaning sensor is very first thing to do to be really sure.
                                          • C Offline
                                            cesareluca
                                            Solved with a very soft small brush… thanks!
