problems with my S9B
54 Posts 15 Posters 3.1k Views 13 Watching
    Luis Duarte
    Hello
    bought my S9B last christmas
    in the first training sessions I had problems with the positive and negative accumulated.
    I sent it to the Suunto factory and they said everything was fine.
    I did some more mountain training and went back to having the same problems.
    I did everything they told me …
    Altitude ok
    Reset soft
    Reset factory
    I sent it back to the factory in February and they say again ir das every thing ok.
    Then came the Pandemic and i stop the mountains.
    Now I started training on the mountain again and I continue with same problems.
    I dont know what to do anymore.
    Can same one helo me?
    Last…
    S9B - 1400D+
    Ambit peak - 450D+
    Sorry for my English
    S P 2 Replies Last reply 31 Oct 2020, 11:27 Reply Quote 0
      sartoric Moderator @Luis Duarte
      @Luis-Duarte
      To be honest, I didn’t understand what’s the problem.
      I suppose it has something to do with altitude, but, can you link a move or make an example?
      Did you try to search the forum for a similar issue ?
      SVTS - 2.40.38
      Suunto App Android 5.3.5 beta
      • P Offline
        pilleus @Luis Duarte
        @Luis-Duarte 450 vs 1400 looks like meters vs feet? 🤔
        Suunto Vertical Black Lime
        Suunto 9 Peak Pro Black
          Luis Duarte
          the problem is the accumulated positive and negative.
          always gives more in long workouts.
          today for example I ran with my 2 watches.
          S9B and ambit 3
          and gave the difference the s9B 1400 with positive accumulation and the ambit 3 450 with positive accumulation.
          B 1 Reply Last reply 31 Oct 2020, 13:24 Reply Quote 0
            Brad_Olwin Moderator @Luis Duarte
            @Luis-Duarte There are two issues that could be causing this. First, if the holes on the S9B are being covered by skin or something else that blocks the baro sensor. I can have this problem if I wear on my right hand, when I flex my wrist it covers the holes and I get wrong readings ±D. Second is wind, if it is very windy and directly hits the baro sensor the ±D can be wrong.
              Luis Duarte
              some days I caught wind, but it happened on sunny days and good weather.
              I can try to wear it on my right wrist.
              I did factory reset again.
              if covering the watch with the waterproof can be a problem?
              Thank you for help
                Luis Duarte
                  Luis Duarte
                  I M M 3 Replies Last reply 31 Oct 2020, 15:42 Reply Quote 0
                  • I Offline
                    isazi Moderator @Luis Duarte
                    @Luis-Duarte can you try to have your watch under your sleeve and see if anything happen? Or switch position of S9 and A3 next time (so that the baro opening will be blocked for the A3 and not for the S9)?
                    L 1 Reply Last reply 31 Oct 2020, 17:02 Reply Quote 0
                    • M Online
                      Mff73 @Luis Duarte
                      @Luis-Duarte
                      Are you syncing your S9b activities to SuuntoApp with Android smartphone?
                      L 1 Reply Last reply 31 Oct 2020, 16:58 Reply Quote 0
                        Luis Duarte @Mff73
                        @Mff73 yes
                        M 1 Reply Last reply 31 Oct 2020, 17:24 Reply Quote 0
                          Luis Duarte @isazi
                          @isazi ok thanks
                          I’m go to try it
                          • M Online
                            Mff73 @Luis Duarte
                            @Luis-Duarte said in problems with my S9B:
                            @Mff73 yes
                            So.
                            there are raw data files you may use and import them in QS, maybe you could see something interesting (registered altitude vs GPS altitude for example)
                            See here where to find this file.
                            https://forum.suunto.com/post/33052
                            L 1 Reply Last reply 31 Oct 2020, 19:08 Reply Quote 0
                            • M Online
                              Mi_chael Bronze Member @Luis Duarte
                              @Luis-Duarte
                              As I see. You use a rain jacket for you’re workout.
                              Sadly the hole of barometer sensor of S9 is not at the same place of A3 Peak.
                              I think you’re jacket came to touch the S9 hole during you’re run.
                              Try to use S9 over the jacket. Or on the left wrist but try to don’t touch it with your hand.
                              L 1 Reply Last reply 31 Oct 2020, 19:11 Reply Quote 2
                                The problem is here
                                The sensor, comes into contact with the jacket and pushes the sensor.
                                ? L 2 Replies Last reply 31 Oct 2020, 18:39 Reply Quote 2
                                  I believe that @Luis-Duarte has the watch since christmas maybe he has runs without jacket and that this issue may be recurrent.
                                  If S9B is so sensitive to jackets how runners do?
                                  C 1 Reply Last reply 2 Nov 2020, 07:49 Reply Quote 0
                                    Luis Duarte @Mff73
                                    @Mff73 thanks 😉
                                      Luis Duarte @Mi_chael
                                      @Mi_chael 👍👍
                                        Luis Duarte @Dimitrios Kanellopoulos
                                        @Dimitrios-Kanellopoulos I don’t remember training without the raincoat but it is possible that it happened.
                                        I will have attention in the future…
                                        since March I have not run on the mountain again.
                                        now I came back and the problem happened again
                                        But if that is the problem it is a big mistake for a top suunto watch.
                                        I hope to solve the problem
                                        thank you all
                                          Luis Duarte
                                          Running_2020-01-24T08_08_12.fit
                                          I think this was the first with problems
                                          M 1 Reply Last reply 1 Nov 2020, 07:03 Reply Quote 0
                                          20 out of 54
                                            consent.not_received
