    GPS track with straight lines - allow location Android 10?
    5 Posts 3 Posters 922 Views 3 Watching
    • J Online
      jw cou Silver Members
      My wife keeps getting strange GPS tracks with her S3, ok at the beginning but after a while only a couple of gps points recorded (see below)
      It happens all the time, not just a one-off issue.
      I checked the location permission on her phone (Xiaomi mi10t pro, Android 10 ), and it’s set to ‘Only while using the app’. I guess that’s the problem and should be set to ‘Always’, but the option doesn’t seem available for the Suunto app.
      Is there a known issue with Android 10 and S3, or am I looking at the wrong place to allow the watch to properly use the GPS of the phone all the time?
      I found a coupe of similar questions on the forum but without answers I could understand or try…
      Thanks!
      • J Online
        jw cou Silver Members @jw cou
        Just found a battery saver setting activated for SA… Removed it, will check this afternoon if that was the problem 🤷🏻‍♂️
          Jamie BG Bronze Member
          Would also probably suggest that your wife turns off wifi and wifi scanning when tracking as I have noticed that sometimes wifi hits can cause the position to show up incorrectly.
          • J Online
            jw cou Silver Members @Jamie BG
            I confirm that the following solved the issue :
            settings
            battery and performance
            manage apps battery usage
            choose apps - Suunto app
            set to no restrictions
            michel Oude VoshaarM 1 Reply Last reply Reply Quote 4
            • michel Oude VoshaarM Offline
              michel Oude Voshaar @jw cou
              I have the same problem with my S3f. I did all things mentioned here but every run i get straight lines. My phone is an Samsung S9. Is there an solution for this
