    Totalt ascent/descent doesn't seem to match elevation graph
    35 Posts 7 Posters 1.6k Views 8 Watching
    • Aleksander HA Offline
      Aleksander H Bronze Member
      Incidentally. What would be the correct procedure for cleaning the baro hole? User guide only states to wash the watch with soap and water. No special mention of the baro hole.
      • Fenr1rF Offline
        Fenr1r @Aleksander H
        @aleksander-h If soap and water don’t cut it on their own, several posters have had apparently gratifying results using soft toothbrushes on their holes.
        • pilleusP Online
          pilleus
          For me it’s a mystery why a watch with barometer cannot be calibrated manually in the main app (Suunto wear app).
          I use only Ghostracer on the S7 and never the Suunto wear app, because I don’t want an altitude which is not correct.
          If I am at 374 m above sea level I want a watch showing 374 m above sea level and not 396 m. That is the best result in several tests with the S7 running the Suunto wear app. 😕
          Good to have alternatives in WearOS. 👍
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
            Aleksander H Bronze Member @Fenr1r
            @fenr1r Thanks. I’ve given it a good rinse now without resorting to a toothbrush. I’ll see how it fares today.
              Aleksander H Bronze Member @Aleksander H
              Today’s run fared better. Some unexpected drops in elevation but not as bad as they’ve been earlier. Maybe I’ve not been cleaning it well enough.
              That said. I’m still confused how I managed to get 0 m ascent on activities where the elevation graph clearly shows me going up 🤔 .
                Mff73 @Aleksander H
                @aleksander-h said in Totalt ascent/descent doesn't seem to match elevation graph:
                as asked @isazi in the other post, do you also have 0m in the watch ?
                but i guess at this stage that we (just users) can’t go further into analysis with any Suunto insight 🙂
                fit files, QS import, etc…, are just what Suunto clould let export from your activities, not any raw informations (if they are some).
                if i had a S7 i would have searched in my android phone or in the watch itself if there are some of these raw data file after a workout, but i have not 😞 …yet 🙂 ?
                  Aleksander H Bronze Member @Mff73
                  @mff73 the watch doesn’t show ascent info at all in the diary for the activity with 0 ascent. Only elevation graph and descent information. I’m guessing its not showing data with no data to show.
                  Unfortunately I can only check this for one of the two activities I have with this problem. I got a new phone 1 February and therefore needed to reset the watch. The first activity with this issue was before the reset, so that one is gone from my watches diary.
                    Dimitrios Kanellopoulos Community Manager @Aleksander H
                    @aleksander-h I suspect this is due to slow ascent
                      @aleksander-h ill report this anyways
                        Aleksander H Bronze Member @Dimitrios Kanellopoulos
                        Going from 240 to roughly 350 in about 35 minutes is slow? I guess I must be in worse shape than I thought 😆 .
                        Dimitrios KanellopoulosD Aleksander HA 2 Replies Last reply Reply Quote 2
                          @aleksander-h there is a fix already done for that.
                            Incidentally, that graph is from a different activity that gave 0m. To avoid confusion, I’ll just post direct links to both here:
                            https://quantified-self.io/user/DUrrVK0qMVZO5TtAP0r6Ox2HVLD2/event/48100bfe1ddfeee6242d124cc67d4cbbff0fc13357bac4207d10f0b9d3bfb895
                            https://quantified-self.io/user/DUrrVK0qMVZO5TtAP0r6Ox2HVLD2/event/583f92a0b4ceb9d5406432cd03971f10e2ae5252eca6503191648ae1ef9ba1a0
                            And below is the activity which was posted by @mikulass in another thread:
                            https://www.suunto.com/sk-sk/move/mikulasstrelecky/6047bd0e148abc47025d3e17
                              @dimitrios-kanellopoulos oh really? In the app? Backend?
                                @aleksander-h needs watch update but yes its fixed and spotted beforehand.
                                  @dimitrios-kanellopoulos awesome. I guess there’s nothing to do but wait for it then :). Thanks for the help, and thanks for building such an awesome free tool (quantified-self).
