    Turn-by-turn navigation in S9 series with Plotaroute
    30 Posts 12 Posters 2.0k Views 10 Watching
      A Former User @markytarky
      @markytarky just a newbie question what’s the difference between this and classic GPX you follow ?
      I’m interesting if it’s help to be more precise when you have many small path to follow.
      markytarkyM 1 Reply Last reply Reply Quote 0
      • markytarkyM Offline
        markytarky Silver Members @Guest
        @g287-sf well, here the plotaroute creates a waypoint on each turn a norifies you twice to make a turn. Once after you pass a WP (it tells you how far the next turn is plus the direction e.g. sharp right or keep left, etc.) and second when you reach the WP. That’s it. No other differences.
        Instagram
        Watch: S9B customized, S9P all black
        Suunto App: iOS beta
          Mike H. @omunoz
          Hello.
          Is Kamoot and Plotaroute the only choices to plan and upload to S9 turn by turn navigation? Do you know other possibilities?
          By the way. Visual indicator would be very useful.
          Suunto 9 Baro
          Suunto app beta at Android 11
          Derrick SpaffordD Mff73M 2 Replies Last reply Reply Quote 0
          • Derrick SpaffordD Offline
            Derrick Spafford @Mike H.
            So a quick question that I asked in another thread… turn by turn does NOT work on trail routes created but only on roads?
              Mff73 @Mike H.
              @mike-h said in Turn-by-turn navigation in S9 series with Plotaroute:
              Hello.
              All apps or Web services that enable to create routes gpx files including turn indications with WPs naming may work.
              I use Locus Map and it works (just gpx import need to be done through external service (not direct import in SA) like QS or Runalyze).
                isazi Moderator @Derrick Spafford
                @derrick-spafford it works on everything is routable.
                Derrick SpaffordD 1 Reply Last reply Reply Quote 0
                  Derrick Spafford @isazi
                  @isazi said in Turn-by-turn navigation in S9 series with Plotaroute:
                  Thanks. Will keep trying to figure it out as it hasn’t worked for me yet and trying to find why.
                    @derrick-spafford how do you import the gpx route in SA?
                      I pulled the GPX route from Strava. Uploaded it to Komoot and then sent it to SA to use in watch. Route shows but no turn to turn.
                      I tried this with creating a planned route but also a recently run route.
                      I have an old custom Movescount Sport mode that I use (with Optical HR disabled) that I was wondering if that was the problem, but used other default sport modes and still no luck. Did a master reset and will try reinstalling software to see if that helps.
                        Mike H. @Mff73
                        @mff73 Thank you for the hint 👍. I also plan my routes using Locus maps. I have to try.
                        Suunto 9 Baro
