    Running cadence only half most of the time. Running steps incorrect, too
    suunto 5runningcadencesteps
    50 Posts 6 Posters 9.6k Views 6 Watching
      Dimitrios Kanellopoulos Community Manager @juhis70
      @juhis70 I ll check the raw data sec
      juhis70J 1 Reply Last reply Reply Quote 0
        A Former User @juhis70
        @juhis70 said in Running cadence only half most of the time. Running steps incorrect, too:
        It may be a very rare problem, like 1/100 or 1/1000, people have different arm swings and running styles.
        That was my second thought too, when I read your issue. The sensors are not prepared for your arm swing style. šŸ™‚
        I’ve have run with default running sports mode, and a custom sports mode (based on running). And I’ve done that with two watches already, with same problem. The chances of both having similarly corrupted sports profiles are so slim.
        Not that slim if you consider, at least in my case when I sync my sport profiles with online Movescount service from and to my watch. Through I’m not sure how sport profiles are stored between Suunto 5 and Suunto app, it might not be your case.
        I did try walking with Running profile yesterday, and that was ok.
        Yes, but walking is a low cadence activity and you are having issue with high cadences. Hence, why I suggested you to do a running with your walking/hiking profile too.
        I’m curious what will @Dimitrios-Kanellopoulos find regarding this issue.
        • juhis70J Offline
          juhis70 @Dimitrios Kanellopoulos
          @dimitrios-kanellopoulos Thanks!
          When I’m saying it is a SW bug I don’t really mean it is a bug bug. There may be no faulty code in the watch. It is more like SW issue. It could be linked to borderline working sensor and/or borderline arm movement, and could be fixed by HW, too. But software could also correct the (maybe somewhat unusual, but still real) data. The current code just don’t take this into consideration.
          It is usually cheaper to fix things in SW than HW
            Ruling out some data parsing bug, these are your raw data for Cadence. Same issue exists in the raw data.
            What I will do is open a bug on the watch side. I cannot promise that it will get fixed and when but I ll be getting updates on the issue.
            I ll also ping support to see if there are more cases like this
            juhis70J 2 Replies Last reply Reply Quote 0
            • juhis70J Offline
              @dimitrios-kanellopoulos Thank you! Keeping my fingers crossed but not holding my breath!
                @juhis70 as a last request of ā€œtest in real lifeā€. What happens if you wear the watch on the inner part of the wrist? Also at the other hand.
                And I wonder what will the cadence field show during runtime. Does it also show these peaks?
                • juhis70J Offline
                  @dimitrios-kanellopoulos Actually the cadence graph for today’s run looks the worst, no locking to the correct cadence, just spikes. On previous runs there was always locking to the correct cadence, too, not only half cadence. Maybe the walk yesterday using Running mode did something. Maybe not.
                    @juhis70 I have to admit, this is the most interesting issue I have seen since quite some time (2016)
                      And if we cannot get to the end of it, I would really like to get you a new watch (no refurbished etc). I could help in this process just FYI
                      • juhis70J Offline
                        @dimitrios-kanellopoulos I’ve done some tests that may cover some of those.
                        In settings, I’ve run with setting ā€œwatch on right wirstā€ and ā€œwatch on right wrist, insideā€, and ā€œwatch on left wrist, insideā€. No notable change, same ā€œbarcodeā€ as cadence graph.
                        My wife run a 1 km test run with this second watch. Cadence graph was OK, just two little spikes down that did not affect average cadence.
                        I run 1 km test run with watch on my right hand. That gave me correct cadence with two somewhat larger drops down, to exactly the ā€œhalf cadenceā€. Here is the graph:
                        This would be almost ok, but I want to wear the watch on my left wrist, it is more natural to me and using the buttons with my left hand would be hard. I have multiple sclerosis, and the left side of my body, including my left arm, is partially numb. I don’t run ā€œusing armsā€, my arms mainly swing along for balance, although in the correct rhythm, of course, opposite to legs. Because of this numbness I want to use the buttons with my right hand.
                        During runtime the watch shows the same cadence values as the graph afterwards. I have made a custom running mode with a screen that shows the current cadence.
                        EzioAuditoreE EgikaE ? 3 Replies Last reply Reply Quote 1
                        • EzioAuditoreE Offline
                          EzioAuditore Gold Members @juhis70
                          I might be speaking b*it now but my sister has some sort of ā€˜energy’ that any watch she wears on her left hand something is happening. I.e.: swatch watches go faster or slower and sometime you can even see the date moving like she’s traveling in future or past. so the seconds hand move faster or slower. When she puts it on her right hand everything is normal. She owns fenix 5 and when we hiked she wore the watch on the left hand. guess what: no gps track was recorded. the watch works perfectly, but if she wears it on her left hand something goes ā€˜crazy’. You sure do not have the same? šŸ™‚
                            Egika Platinum Member @juhis70
                            Maybe this is the reason for the acceleration sensor in the watch to sense something wrong.
                            Could it be your arm movement is different from like 90% other runners?
                            • juhis70J Offline
                              juhis70 @EzioAuditore
                              @hristijan-petreski Wow that’s interesting. My left arm does feel ā€œfunnyā€ (it was terrible first), like I had slept on it, but the partial numbness ever goes away. So why not, maybe it has also other ā€œpropertiesā€. Devices like sports watches are packed with many sensitive sensors.
                              @andrasveres I forgot to answer you, but no, I don’t wear anything interfering near the watch. The HR belt (Suunto Smart Sensor) is nearest (and usually only) electrical device with me.
                              @Egika Yes that is probably true. But at least some have had same experiences with their (different) sports watches, I mentioned couple here https://forum.suunto.com/post/87271
                                @juhis70 not sure if the issue will be sorted out or not via software, but for the conditions you describe a footpod might be an option if cadence is important for you.
                                juhis70J 1 Reply Last reply Reply Quote 1
                                • juhis70J Offline
                                  juhis70 @Guest
                                  @andrasveres That is true, I’ve considered that option. But because I can get good cadence graph postprocessing the FIT data, so I’m not sure I want just another gadget. A little work after every run, or a little electronics device… That is the question.
                                  • juhis70J Offline
                                    juhis70
                                    Today’s shorter run, watch gives average cadence 55 rpm.
                                    Here’s my graph constructed from .FIT, including original (faulty) cadence in red. corrected in green, and smoothed corrected cadence (6s moving avg) in blue. Horizontal red dotted line is original (faulty) average cadence 55 rpm, horizontal green dotted line is corrected average cadence 87 rpm.
                                    Just posted this another run as an example that the data from accelerator/cadence sensor is not ā€œrandomā€, and can be used to construct a valid cadence graph. (And to show off my VO2max est šŸ˜‡ ) Wow og Android emojis, who remembers those anymore. In Finland we have a saying, that boys named Jonne won’t remember: ā€œJonnet ei muistaā€.
                                      Question.
                                      If you run faster ie a fast km or a couple of meters how does the cadence look?
                                      (It’s question from engineering )
                                      • juhis70J Offline
                                        @dimitrios-kanellopoulos I usually run at fairly constant speed, avg pace little under 6min/km. There are some hills, ascents, descents that affect the pace. I overlayed pace and cadence graphs from today’s run. I don’t get much out of it.
                                          Also just an idea. A pod for cadence / speed like stryd. Of course it’s pretty expensive.
                                          That said feedback is sent again.
                                          • juhis70J Offline
                                            Here’s longer run from Monday (same run in first post), with heart rate also overlayed. At about 10 minutes begins longish uphill, heart rate raises, pace drops slower than 6/km, and cadence locks more often to correct value.
                                            At about 20 minutes heart rate levels down, easy running, pace faster than 6/km, cadence locks to half value.
                                            Seems that when I ā€œpush itā€ for example up hill, the cadence is more often right. I probably swing my arms more then. When I’m running easy, and cadence is usually half. Probably my arm movement is smaller.
