    VO2 Max
    62 Posts 23 Posters 8.8k Views 22 Watching
    • Akos HajasA Offline
      Akos Hajas @ink357
      @ink357 yes I did…🤷‍♂️
      • Dušan KovićD Offline
        Dušan Ković
        Just did a first run, got VO2Max. Everything works well
        SR
        SA latest beta
        Polar Verity Sense
        Polar H10
        Pixel 6
        Akos HajasA 1 Reply Last reply Reply Quote 1
          Akos Hajas @Dušan Ković
          @dušan-ković okay
            isazi Moderator @Akos Hajas
            @akos-hajas are you using an external HR monitor, or the wrist one? Do you get any message at the end of the activity that HR or GPS was problematic? Everything looks fine in SA for your runs?
              Akos Hajas @isazi
              @isazi I I’m using a Garmin chest belt.If I set target now it doesn’t come the message that you got 50 % and also doesn’t show up the Autolap on the watch (it is on)
                @akos-hajas so there are various things that do not work on your watch 😕
                Maybe also contact support, they may know more.
                stromdiddilyS Akos HajasA 3 Replies Last reply Reply Quote 0
                • stromdiddilyS Offline
                  stromdiddily Gold Members @isazi
                  @isazi do you know why this isn’t stored and written back to the watch from the app? Same for resources, historical HR etc?
                  Personally, the V02 max is more realistic (read lower) than the 9B but it’s silly to me that they report different values at all.
                    isazi Moderator @stromdiddily
                    @stromdiddily because it’s computed on the watch, with the code licensed from Firstbeat. I hope that in the future the watches will be able to retrieve some info from the app (already the setup is simpler now), so that switching watches will become easier.
                      Akos Hajas @isazi
                      @isazi how can I install the Software new on the watch?
                        @akos-hajas https://www.suunto.com/fy-nl/Support/Product-support/suunto_9_peak/suunto_9_peak/getting-started/software-updates/
                        Akos HajasA 1 Reply Last reply Reply Quote 0
                          Egika Platinum Member @isazi
                          @isazi said in VO2 Max:
                          so that switching swatches will become easier.
                          ist that hoping or teasing?
                            Akos Hajas @isazi
                            @isazi I know that…but I want to install the Software what I have now on my watch new
                              isazi Moderator @Egika
                              @egika just hoping, if I knew something I would not comment 🙂
                                @isazi 🙄
                                  Akos Hajas @isazi
                                  @isazi I reset the watch and now is working everything normal…
                                    Sascha Domres Bronze Member @Richard Thygesen
                                    @richard-thygesen I get the VO2 worth but it is very different from Coros or Garmin Fenix ​​6. With the last two watches I usually have a VO2 of 44 to 45. With the S9 Peak I have 39 … I hope that I will adjust that
                                    Richard ThygesenR 2 Replies Last reply Reply Quote 0
                                    • Richard ThygesenR Offline
                                      Richard Thygesen @Sascha Domres
                                      @sascha-domres ok, I came from another brand before my S9 non baro and decreased my VO2max alot. It has slowly increased but it’s nowhere near the value I had with the other brand.
                                      S9
                                      S9 Peak
                                      Race
                                        @sascha-domres I can add that if i do intervall traning with high pulse the watch always increase my vo2max but decrease it on slower runs.
                                        S9
                                        S9 Peak
                                        Race
                                        • ChrisAC Offline
                                          ChrisA Platinum Member @Richard Thygesen
                                          @richard-thygesen same here… I have 40 to 42 with Garmin and other devices with firstbeat algorithms like the Huawei GT 2e,
                                          then comes polar with 39 and then Suunto with 381B2C223D-EA75-4905-B833-8400C3922FED.jpeg
                                          (and I am exactly as fit as my age is 😅) .
                                          But since it’s only an estimated value from your running metrics and not really analysed in a lab I find it quite close in average and on Suunto it reflects me getting fitter since I started running last year in summer, where I got 35
                                            surfboomerang @ChrisA
                                            I don’t know about other brands, but my values are pretty consistent across my Suunto watches (Ambit 3 peak, Suunto 9 Baro and Suunto 9 Peak)
                                            53-55
                                            I used the Ambit 3 and S9B with a HR belt and the S9P with OHR.
