    S9P not showing water temperature during swimming
    25 Posts 11 Posters 2.1k Views 11 Watching
    • Theo LakerveldT Offline
      Theo Lakerveld Bronze Member
      Lately, the (water) temperature doesn’t show on the watch during swimming activities on my S9P. This accounts both for open water and indoor swimming. Additionally, measured water temperature sometimes shows up in the file/suunto app and other times it doesn’t.
      Can this issue be the reason for the inconsistent behaviour? https://www.dcrainmaker.com/2021/10/the-fascinating-reason-why-the-garmin-fr945-fenix-6-no-longer-shows-pool-temperature.html
      Previously used: Cyclosport HAC4, Polar S710, Ambit 2S, Ambit 3S, SSU, S5P, S9P Ti. Currently using: Race Ti.
      BulkanB EgikaE 2 Replies Last reply Reply Quote 0
      • BulkanB Offline
        Bulkan Moderator @Theo Lakerveld
        @theo-lakerveld Nope, nothing changed in this. It should show the temperature. I use S+ weather to have the temperature in a graph tho.
        • EgikaE Online
          Egika Platinum Member @Theo Lakerveld
          @theo-lakerveld it is a bug and known to Suunto.
          Whatever Garmin’s issues with this are - it is a different company with different products.
          • herlasH Offline
            herlas Silver Members
            so, S9P is not showing water temperature in either OW or pool swims, I´ve used S+ weather but temperature doesn’t stick to the after the fact summary in SA, does anybody know when this will be fixed?
            SRS Ti
            Galaxy Z Flip 3 / Galaxy S24+
            DMytroD W 2 Replies Last reply Reply Quote 0
              DMytro @herlas
              @herlas next watch update, this month probably.
              freeheelerF herlasH 2 Replies Last reply Reply Quote 0
                freeheeler @DMytro
                @dmytro
                or “maybe”, summer and vacation time 🤙 ☀ 🏄
                • herlasH Offline
                  herlas Silver Members @DMytro
                  @dmytro that’s good to know, also, S9P OW GPS issue had been fixed already? I’ve been doing OW freestyle with S9P and A3P to compare, and I’m getting very decent/good distances out of the S9P, could argue it’s giving better distance than ambit 3 🤔
                  SRS Ti
                    DMytro @herlas
                    @herlas I think not but I may be wrong. Neither do I have s9p, nor do I swim, so can’t say much. But maybe others could chime in.
                      freeheeler @DMytro
                      @dmytro
                      @herlas
                      I don’t know anybody who combines: S9P, A3P and open water swimming 🤔
                      • W Offline
                        wotus Bronze Member @herlas
                        @herlas After starting your swimming exercise with S+ W you have to switch through all the displays for one time, then the temperature will be recorded correctly. Because of the display lags it will take about 10 seconds minimum.
                        • W Offline
                          @herlas I do a lot of OW swimming and I used A3p for 7 years. Now I have S9p for 1 year and the comparable tracks are a bit better than with A3p.
                          • herlasH Offline
                            @freeheeler well, that’s not true you know me 😄 , it’s not that I’m combining them, I’m comparing GPS tracks and distances for OWS 🏊 , last Dec S9P was giving me way shorter distances than A3P, I think a couple of SW updates have happened since and I started OWS again, and S9P looks like now is giving better GPS tracks/better distances than A3P.
                            Pool swimming is a no-go for my S9P, I take my A3P all the time due small and relevant features like a must have drill mode or swim style teaching mode 😎
                            Back to topic, I guess this is the issue I was referring to, wondered if this was fixed?
                            https://forum.suunto.com/topic/6902/open-water-is-not-working-properly
                            @wotus I want to have the temperature in SA in my workout summary , are you saying that I need to swipe to the S+ weather app so that the temperature gets recorded to SA when syncing? Today I did select S+ weather but didn’t swipe to it, wondering if that’s the reason why I don’t have any temperature in SA for today’s swim ? Will try in my next swim and report.
                            SRS Ti
                            freeheelerF Piotr GrygielP 2 Replies Last reply Reply Quote 2
                              freeheeler @herlas
                              @herlas
                              …else… I don’t know anybody else… 😉
                              • Piotr GrygielP Offline
                                Piotr Grygiel @herlas
                                @herlas said in S9P not showing water temperature during swimming:
                                I reported this to Suunto, but the level of support is very low.
                                Suunto Race 2
                                Google Pixel 8 pro
                                • herlasH Offline
                                  Confirming, after swiping thru the weather Suunto + screen, I’m seeing the temperature graph in SA after syncing the workout, at least we have a workaround while the issue is fixed.
                                  Does anyone know if a similar workaround exists for S7? It’s lacking temperature in OWS also 🤔
                                  SRS Ti
                                  • herlasH Offline
                                    herlas Silver Members @herlas
                                    @wotus and everyone, so I use S+ weather on my S9P to workaround the temperature not being recorded while swimming ,which is supposed to be fixed in the next watch firmware.
                                    However, I’ve been noticing that temperature is captured only for some minutes and then it cuts completely.
                                    see below screenshot from 3 swim workouts, anyone else have seen this behavior? wonder if this will be addressed when the temperature bug is fixed or might it be a different S+ weather issue? thx
                                    SmartSelect_20220819-110220_Suunto.jpg SmartSelect_20220819-110136_Suunto.jpg SmartSelect_20220819-110117_Suunto.jpg
                                    SRS Ti
                                    • W Offline
                                      @herlas Mostly the temperature curve with S+ Weather looks like this:20220819_220210.png
                                      But sometimes in very few cases I had similar effects like you, a flat line for the rest of the exercise.20220819_220143.png
                                        Brad_Olwin Moderator @Piotr Grygiel
                                        @Piotr-Grygiel said in S9P not showing water temperature during swimming:
                                        Why is level of support low? This is a known bug and will be fixed. How does that make support level low?
                                        Piotr GrygielP 1 Reply Last reply Reply Quote 1
                                        • herlasH Offline
                                          herlas Silver Members @wotus
                                          @wotus Thx, I only switch screens once at the beginning of the workout, not sure it that’s the trigger for this behavior though
                                          SRS Ti
                                          • EgikaE Online
                                            Yes, the fix will make the temp recording be active permanently as one would expect.
