    Suunto 9 Peak maximum battery life
    54 Posts 13 Posters 7.9k Views 13 Watching
      surfboomerang @isazi
      @isazi I’m 6 days after the last charge. Recorded only 3 hrs with the watch this week, but battery level is at 65% at the moment.
      Well done Suunto!
      • I Offline
        ist-1973 @Simon
        @simon How to completely turn off the clock?
          surfboomerang @ist-1973
          @ist-1973 Settings -> General -> Power Off
          (S9P only if I’m not mistaken)
            surfboomerang
            For the record.
            8 days after the last charge and I am down to the 50% mark, 6hrs of GPS activity (best performance)
            • babychaiB Offline
              babychai Silver Members
              As advertised S9P can last for 25 hours when choose Performance for battery mode when turn on GPS.
              How to achieve 25 hours battery life when turn on GPS for my hiking activity?
              Few days ago i noticed the battery consumed 16% battery life (from 99% dropped to 83%) in 3 hours.
              It means that 1 hour it consume about 5.33% battery (16% / 3hrs).
              By calculation 18.76 hours x 5.33% = 99.99%
              Therefore, the battery only can last for about 19 hours.
              My setting was below when i turn on GPS:
              Notification: On
              Sleep tracking: on
              24/7 HR: On
              Theme: Light (i think it doesn’t matter whether it’s Dark or Light?)
              Battery Mode: Performance
              Any advice how to achieve 25 hours when turn on GPS for my hiking activity?
              Which setting i need to turn it off in order to achieve it.
              I need the Best GPS accuracy so please do not ask me change it to Endurance, Ultra or Tour battery mode.
              Thanks.
              Suunto 9 Peak All Black
              freeheelerF isaziI 2 Replies Last reply Reply Quote 0
                freeheeler @babychai
                @babychai
                battery life in activity is independent from the daily basic settings like 24/7 HR, notifications etc… of course if you receive frequent calls during a hike (hopefully not), then it wears down the battery.
                there are few things you can do:
                turn off backlight (small impact IMHO)
                turn off auto laps
                use the GPS settings with only few different systems (GPS and QZSS afair)
                and last but not least, use an external HR sensor over the internal OHR if you have one or don’t mind buying one.
                at least in my S9B I’ve got 32h instead of 25h predicted battery life.
                Never tested if it really gets to these amount of hours since I usually don’t have so long consecutive hikes.
                And my S9B battery testings are over 2.5 years back, so I don’t remember anymore the consumption per hour that I could calculate linearly.
                what you can also do is taking a power bank with you and charge while hiking?
                and last but not least: maybe it’s just a momentary issue. Similar to S9B in the beginning.
                  DMytro @freeheeler
                  @freeheeler If I recall correctly s9p has actually better battery life with Ohr than with a belt.
                  Regarding battery consumption: I think battery consumption is not linear, maybe try testing it for a longer hike to deplete a third or even a half of the battery charge, this might be more representative.
                  freeheelerF EgikaE 2 Replies Last reply Reply Quote 1
                    freeheeler @DMytro
                    @dmytro
                    oh, true! sorry for my misleading comment… and thank you for correcting me!
                    in S9B it’s the other way around.
                    OHR must have become more efficient 👍
                    • EgikaE Online
                      Egika Platinum Member @DMytro
                      @dmytro not sure about this one.
                      It is true for S7 - S9(B/P) series has super low power BT…
                      Is there an official statement about this somewhere?
                        isazi Moderator @babychai
                        @babychai if you use navigation, S+ apps, or guides, battery life can be shorter than 25 hours. Battery life is also reduced if you receive many notifications or autolap is very frequent (the screen lights up). I consistently have an estimated battery life between 24 and 30 hours (measured after activity).
                        I even plotted estimated battery life over the past year for the S9P (and other watches) and found consistent results.
                        babychaiB 1 Reply Last reply Reply Quote 1
                          Spree Bronze Member
                          The main item anyhow is GPS systems. Using Galileo or Glonass alone immediately reduces battery life (even the expected one shown by the watch) to 21 hours instead of 25.
                          Also, hiking - because you go slow and therefore GPS reception is more difficult, leaving along the possibility of being in the woods or other difficult conditions - tends to have slighly lower battery life than e.g. running.
                          Considering batetry consumption is not entirely linear (i.e. you cannot take the first hours of consumption and think that the consumption rate will be the same for the remaining 20 hours), 16% in three hours is essentially in line with what I would expect if Galileo or Glonass were in use.
                          Also, of course, notifications and backlight are a great point. If checking the watch often is not that important, using the “display timeout” battery saving feature will definitely increase battery life significantly
                          isaziI babychaiB 2 Replies Last reply Reply Quote 2
                            DMytro @Egika
                            @egika I don’t think there’s an official statement. And I might be wrong of course, I think I either read it in the forum, or saw in a video. Don’t have s9p myself.
                              isazi Moderator @Spree
                              @spree said in Suunto 9 Peak maximum battery life:
                              The official battery life of 25 hours is with Glonass, not with GPS only.
                                Spree Bronze Member @isazi
                                @isazi I was actually using the 9 Baro stats, thanks for pointing that out; it’s true that the 9 Peak actually (when using OHR) has longer battery life than the 9 and 9 Baro.
                                Glonass and Galileo do use more battery compared to not using them, but the official (and exepcted, in fact) battery life is still 25 with them on so I was wrong.
                                  @spree indeed for the 9B 24/25 hours is with GPS only. The 9P with GPS only gets closer to 29/30.
                                  • babychaiB Offline
                                    babychai Silver Members @isazi
                                    @isazi Ah i see. i did turn on S+ Features
                                    Although my notification is turned on but i did not receive any notification because i already turned off my mobile phone Bluetooth.
                                    Besides that, I also use setting below for my 3 hours hike:
                                    Autolap: Off
                                    GPS System: GPS+QZSS+GLONASS
                                    Backlight: Off
                                    Brightness: Medium
                                    Standby: Off
                                    Raise to wake: Off
                                    Since battery consumption is not linear, next time i will try again for the longer hike.
                                    Thanks everyone for the reply and provide very useful informations.
                                    • babychaiB Offline
                                      babychai Silver Members @Spree
                                      Is there any way to turn on “display timeout” without using Custom setting threre?
                                      Brad_OlwinB L 2 Replies Last reply Reply Quote 0
                                        Brad_Olwin Moderator @babychai
                                        @babychai No, you must set up a custom battery setting to use display timeout.
                                        babychaiB L 2 Replies Last reply Reply Quote 1
                                        • babychaiB Offline
                                          babychai Silver Members @Brad_Olwin
                                          @brad_olwin Alright, got it. thanks.
                                            loopylou72 @babychai
                                            @babychai
                                            Hi can you set a custom battery mode on the Peak 9? The manual says you can but I read somewhere else that you can only do it on the 9 and I can’t see an option in the app. Thanks!
