    Firmware 2.20.28 Battery drain
    36 Posts 13 Posters 8.8k Views 13 Watching
    • Dirk MünsterD Offline
      Dirk Münster
      After Update my Peak 9 to 2.20.28, the battey consumption is much more higher, even when the watch isn’t in use or worn. Before it was much better. I tried a full reset but it’s not better.
        isazi Moderator @Dirk Münster
        @dirk-münster I believe to know what you are experiencing. In my experience this high battery drain only affect the time you are not wearing your watch, and not when you are wearing it (or at least in this case it is negligible).
        • H Offline
          halajos Bronze Member @isazi
          @isazi specific to S9P or affects the whole lineup?
            isazi Moderator @halajos
            @halajos S9P only, to my knowledge.
            • Theo LakerveldT Offline
              Theo Lakerveld Bronze Member
              I’m noticing the same. And I’m wearing it 24/7.
              Previously used: Cyclosport HAC4, Polar S710, Ambit 2S, Ambit 3S, SSU, S5P, S9P Ti. Currently using: Race Ti.
                Even when it happens only when not wearing the watch, this is really bad! What’s the reason for it? For me the “not-wearing-time” is very important!
                  I have only speculations about the reason, that I am not going to share. What I can share is that this is a known issue and it will be fixed.
                  surfboomerangS 1 Reply Last reply Reply Quote 3
                  • surfboomerangS Online
                    surfboomerang @isazi
                    @isazi Thanks for sharing.
                    Do you have any idea (if you’re allowed to tell us) if this will be fixed in a special bugfix release in the near future or do we have to wait until the next regular firmware update?
                      @surfboomerang nothing that I know.
                        The only case that battery consumption could be higher is if you are not wearing the watch and you have sleep tracking on.
                        That is because the watch is trying to check if it’s on wrist , and lights up a little the ohr lights with Minimal consumption.
                        So check if you have sleep tracking on for those that like to leave the watch at home etc.
                        • Piotr GrygielP Offline
                          Piotr Grygiel
                          I confirm a much shorter working time on a single charge. Sleep tracking on
                          Suunto Race 2
                          Google Pixel 8 pro
                            freeheeler
                            is this commonly known battery recalibration thing after updates history or still valid?
                            shouldn’t we still judge the drain after emptying completely, recharging and soft resetting?
                              @freeheeler correct
                                Brad_Olwin Moderator @Dirk Münster
                                @dirk-münster I just tested this with one S9P on wrist and one on the desk all night. On wrist from 99% to 91% and on the desk from 99% to 97%. I would definitely try a battery recalibration. This does not seem an issue from my tests. I will keep this running for a bit.
                                Vector/T6c/Vertical 2 Ti
                                  Piotr Grygiel
                                  I did a hard reset. I think it helped. 4% at night on a table with sleep monitoring.
                                  The ability to back up the watch settings is very much needed!
                                  Suunto Race 2
                                  Google Pixel 8 pro
                                    There was a new update “2.20.30”. Maybe the issue is already fixed 🙂 No info about what’s new with this update on the official web page.
                                    isaziI freeheelerF 2 Replies Last reply Reply Quote 0
                                      isazi Moderator @Guest
                                      @simon info is in the forum 🙂
                                        freeheeler @Guest
                                        @simon
                                        the changes don’t specifically describe the drain as I see it…
                                        https://forum.suunto.com/topic/7764/hotfix-release-2-20-30-5th-april-2022/13?_=1649233542942
                                          Ahh, very cool! Thanks! Didn’t know all the details were here. Nice 🙂
                                            thibaut
                                            I have the same issue with 2.20.30
                                            Not sure if it was related to me not wearing the watch, but before the firmware update I could wear it for more than a week, then I noticed that it lost more than 30% in one day without any activity at all from my side. I don’t have sleep tracking enabled.
                                            I have noted down the battery level for today and will see how it evolves over the next days and report back.
                                            Will this be fixed in a new firmware?
