    Firmware 2.20.28 Battery drain
    36 Posts 13 Posters 5.0k Views 13 Watching
      freeheeler @thibaut
      @thibaut
      did you empty the battery, fully charge the watch and then do a 12s soft reset?
      • Soylent YellowS Offline
        Soylent Yellow Bronze Member
        Just as a reminder, a couple of days after the last firmware update my S9B got stuck on a black screen, and I had to soft reset it. Not a problem at all (it hasn’t resurfaced) but after the soft reset I experienced tremendous battery drain during the day, but none during night, and also non in battery saving mode (when the watch is on its last %) . Turned out that somehow (probably when I was trying to solve the black screen issue) illumination was set to always on. Sometimes the solution is rather obvious, duh.
        • Set_218S Offline
          Set_218
          big battery drain until 2.20.30 (running 2h with 14% battery down) and no more WHR (because tattooed on both wrists)… unbelievable disaster work in 2022 from suunto.
          Ambit2
          Ambit3Peak
          Spartan Ultra Black Titanium
          S9B Black Titanium
          S9P Granite Blue Titanium
          S9PP Titanium Slate
          freeheelerF surfboomerangS 2 Replies Last reply Reply Quote 0
            freeheeler @Set_218
            @set_218
            but did it become better with 2.20.30?
            Set_218S 1 Reply Last reply Reply Quote 0
              surfboomerang @Set_218
              @set_218 Sorry, I can’t confirm.
              1 week since last charge, with 4 hrs of windsurfing and 3 hrs of running, and the watch is down to 51%
                freeheeler @surfboomerang
                @surfboomerang
                similar here… no wind, no surfin… but battery in a 3 year old watch is within reason 👍
                  thibaut @freeheeler
                  @freeheeler
                  I did not yet do the soft reset. I will do when it reaches 0% then and I charge it to the 100%.
                  Also the backlight is turned off.
                  I did go running this afternoon and the battery dropped down 10% for a 1:38 run. I never really paid attention before how much energy a run would take, but it feels much higher than before.
                  • Set_218S Offline
                    Set_218 @freeheeler
                    @freeheeler
                    no. also with the 2.20.30 update the battery status is a disaster. like the first big update years ago on the spartan series.
                    load the S9P on 99% yesterday 5pm. no sports or activity. just wearing it 24/7 with whr + sleep counter. Now -> 86%
                    Ambit2
                    Ambit3Peak
                    S9B Black Titanium
                    S9PP Titanium Slate
                      freeheeler @Set_218
                      @set_218
                      and did you empty the battery, fully charge the watch and then do a 12s soft reset?
                      • Set_218S Offline
                        Set_218 @freeheeler
                        @freeheeler
                        no… not now. i am reading this solution too late… hope it will work.
                        Ambit2
                        Ambit3Peak
                        S9B Black Titanium
                        S9PP Titanium Slate
                          freeheeler @Set_218
                          @set_218
                          🙂 ✊ I’m sure it will 👍
                          Set_218S 1 Reply Last reply Reply Quote 1
                            Let it dry out of battery and charge full.
                            Usually it should waste 20% per day max with backlight on (adaptive) many notifications and all 24/7 tracking on
                            Consumption per hour of gps + whr should be around 4%
                            T 1 Reply Last reply Reply Quote 4
                              thibaut @Dimitrios Kanellopoulos
                              I wrote before that my backlight was not on, but this was wrong. I just didn’t see it as it was set to low.The update must have changed my backlight settings. I turned the backlight off and the battery usage seems to have returned to normal usage
                              Thanks everyone for their help
                              • Set_218S Offline
                                Set_218 @freeheeler
                                @freeheeler
                                It just work now after full reload and reset. (MusicControl and Notification off) …
                                But the whr with my tattooed arm don‘t work anymore since the Update.
                                Ambit2
                                Ambit3Peak
                                S9B Black Titanium
                                S9PP Titanium Slate
                                  isazi Moderator @Set_218
                                  @set_218 Suunto is investigating the tattoo issue, hopefully they’ll find a solution.
                                  Set_218S 1 Reply Last reply Reply Quote 2
                                  • Set_218S Offline
                                    Set_218 @isazi
                                    thanks for the info. it is really disappointed, because i have tested with different watches and my girlfriend.
                                    my S9P dont work with the 2.20.30 on my tattooed wrist, but it works on her wrist without any tattoo. same story with her S9P on my wrist... dont work.
                                    But my old S9Baro without the new firmware works on my wrist… that is my output about this story…
                                    Ambit2
                                    Ambit3Peak
                                    S9B Black Titanium
                                    S9PP Titanium Slate
