    Battery and navigation
    25 Posts 7 Posters 2.7k Views 7 Watching
      Lesley Mackenzie @ActiveJiggy
      @activejiggy thanks
      • ChrisAC Offline
        ChrisA Platinum Member @Lesley Mackenzie
        @lesley-mackenzie ah I see - thanks for sharing your experience. I have no idea if that’s true but I would assume, that tracking would not have used up those remaining 60%.
          Brad_Olwin Moderator @ChrisA
          @chrisa I did extensive testing with a preproduction watch, as I stated below, on two long events I had 21h and 24h, respectively for predicted battery life. One was a long backcountry ski and the other a long run, both on Performance mode with OHR running.
          ChrisAC 1 Reply Last reply Reply Quote 1
          • ChrisAC Offline
            ChrisA Platinum Member @Brad_Olwin
            @brad_olwin thanks that’s awesome. Will have a longer hike in August (around 12h) so everything should be fine 😃.
            A 1 Reply Last reply Reply Quote 2
              ActiveJiggy @ChrisA
              @chrisa said in Battery and navigation:
              Using GPS and heart rate for your trip should probably use about 50% of the battery with the other power saving mode enabled.
              I use power saving mode and airplane mode when just wearing the watch, you’ll need to turn them off to sync.
