    Ongoing altitude problems with Suunto 9 Baro
    18 Posts 9 Posters 1.8k Views 9 Watching
    • reggerR Offline
      regger Bronze Member
      Does anyone else have the same problem during the last few week? In 9 out of 10 of my past workouts the altitude detection had huge mistakes (see example picture, the hard downs and ups haven’t been existing in reality). Tried to clean the watch but problem still exists. This is very annoying. Yesterday the watch told me that it was 1700 ascent meter. In reality it was around 1300…
      sartoricS isaziI 2 Replies Last reply Reply Quote 0
        sartoric Moderator @regger
        @regger
        It could very probably be an issue with. gps signal
        Did you try a soft reset ?
        SVTS - 2.40.38
        Suunto App Android 6.1.4 beta
        • isaziI Online
          isazi Moderator @regger
          @regger if it’s happening now and it didn’t before, could be environmental: if it’s very hot sweat may be blocking the baro holes. Soaking the watch in warm water, then rinse and maybe use a soft brush to clean the external part of the sensor (never the inside) could help.
          reggerR 1 Reply Last reply Reply Quote 2
          • reggerR Offline
            regger Bronze Member @isazi
            @isazi Thanks…will try that again.
            • reggerR Offline
              But doen’t look polluted anyway…
              sartoricS ? 2 Replies Last reply Reply Quote 0
                @regger
                Well, it doesn’t need to be muddy 😁
                Just a couple of dust particles stuck on the sensor’s membrane can generate faulty readings
                SVTS - 2.40.38
                  A Former User @regger
                  @regger had it once after 2-3 years with S9B. Before that I never rinsed it properly. After rinsing I never had it. From outside not recognizable. So recommendation, sometimes rinsing with water is good! Do not put anything in the holes.
                    freeheeler @regger
                    @regger
                    the graph looks a bit as if the holes where blocked few times and pressure was increasing, like @isazi said.
                    could be dirty sensor, too.
                    they soaking over night as suggested and also try to take care of clear baro holes.
                    it happens to me every now and then, too.
                    not much we can do about it, unless wearing the watch a bit looser…
                    • reggerR Offline
                      Thanks for your suggestions. I had the problem in the past very rarely, once in a few months but now its realy annoying.
                      I’ll try to clean it with warm water again. Usually the watch stays on my hand during showering…so it should get cleaned regularly 😉
                      sartoricS jjpazJ 2 Replies Last reply Reply Quote 0
                      • reggerR Offline
                        Here’s another example for a faulty recording…
                          @regger said in Ongoing altitude problems with Suunto 9 Baro:
                          And that could be a problem, as some residue of soap can stick inside the sensor housing
                          SVTS - 2.40.38
                          • jjpazJ Offline
                            jjpaz Bronze Member @regger
                            @regger What hand do you wear the watch? If you wear it in the right hand the baro sensor is highly exposed to wind and that can cause strange measures…
                              Brad_Olwin Moderator @sartoric
                              @sartoric said in Ongoing altitude problems with Suunto 9 Baro:
                              Agree, I never wear my watches showering. I do not have these issues and think that soap film eventually affects the sensor.
                              From the recordings it is either a dirty sensor, the sensor pressed against skin or wind (has to be very strong in my experience).
                              reggerR 1 Reply Last reply Reply Quote 1
                              • reggerR Offline
                                regger Bronze Member @Brad_Olwin
                                @Brad_Olwin
                                I’ll try everything to clean it and not to wear it during showering the next weeks (even if this would be an reason not to buy a Suunto in the future) and observe the tracks.
                                As I already wrote, this issue occured every few months in the past but within the last weeks it happenend in 90% of my usage.
                                • BulkanB Offline
                                  Bulkan Moderator
                                  Are you wearing the watch in the right hand?
                                  reggerR 1 Reply Last reply Reply Quote 0
                                  • reggerR Offline
                                    regger Bronze Member @Bulkan
                                    @Bulkan
                                    No, left
                                      Mff73 @regger
                                      @regger
                                      did you try the fridge test ?
                                      search the forum for more details, but baro altitude shouldn’t be influenced only by temp, except in case of dirty sensor or faulty one.
                                        Brad_Olwin Moderator @regger
                                        @Brad_Olwin
                                        This would happen with any brand, I personally would not shower, the sudden change in temperature and soap I don’t think are the best combination.
