    Suunto 9 Baro AGPS n/a
    61 Posts 20 Posters 8.1k Views 19 Watching
    • paataP Offline
      paata Bronze Member
      I have the same problem - no AGPS last few days in my S9B. Maybe bug in beta SA? I haven’t check it with previous version.
        freeheeler @paata
        @paata
        Suunto is informed about it…
        I personally don’t see it very critical, but it is a disadvantage… I was also standing for some time in the street on a saturday morning, waiting for satellites to be locked 😉
        Since we all expect “june”, soon, I assume it could be solved then ✊
        • BulkanB Offline
          Bulkan Moderator
          This is solved today I think, check it in your watches.
          Mitch9M 1 Reply Last reply Reply Quote 5
          • Mitch9M Offline
            Mitch9 @Bulkan
            @Bulkan Yes, the fix was unusual fast this morning and I checked the AGPS data.
            Great that this problem was solved!
            SA: Android (beta)
            HRS: Polar H10
            • MiniForkliftM Offline
              MiniForklift Platinum Member
              Yep all good and fixed for me, well done with the speedy fix 👏
              SV Titanium Solar Forest
                Keep reporting if this happens, we need to keep Suunto informed to find a permanent solution.
                • PrenjP Offline
                  Prenj
                  Happened to me again today. 😞
                  Suunto Race
                    freeheeler @Prenj
                    @Prenj
                    confirmed… sunday is the new friday then…
                      Tieutieu Platinum Member
                      N/A value too on my S9B today. Too bad, it was a race, and gps recording was very bad and interrupted…No problem on my wife’s S9P wife and on a friend’s A3P…
                      Nevertheless total distance and pace where strangely accurate…
                        freeheeler @Tieutieu
                        @Tieutieu
                        AGPS helps to lock satellites faster.
                        it’s now too late… but if you have waited until the arrow is steady and not searching anymore, it should not have a negative effect on your track recording and values.
                        I’m sorry your race hasn’t been recorded properly…
                        anyhow, Suunto knows and it looked like it was solved. let’s observe more and please report here if you notice again AGPS: N/A
                          Tieutieu Platinum Member @freeheeler
                          @freeheeler : I had prepared my watch few minutes before the race, and had no reason to check (It usually takes less than 20sec to get GPS signal). Discovered the signal was off when the race started 🤣
                          Not a big deal anyway.
                            Shrek3k @Tieutieu
                            @Tieutieu said in Suunto 9 Baro AGPS n/a:
                            … and the “mysteriously” accurate speed etc should be the (in)famous “fused speed” feature, that uses more or less all available sensors in the watch to estimate (quite nicely for me, too) speed and distance … even without GPS reception and thereby without nice track on the map.
                            OS - Android 16/Pixel Pro 7
                              Tieutieu Platinum Member @Shrek3k
                              @Shrek3k said in Suunto 9 Baro AGPS n/a:
                              Exactly what I tought ; had the issue during another race last September, and same “accuracy”.
                              Works pretty well so !
                              • Mouse CruiserM Online
                                Mouse Cruiser Bronze Member
                                It happens again. So it’s not solved yet.
                                Suunto 9 Baro
                                Suunto Spartan
                                Suunto Ambit3 peak
                                  freeheeler @Mouse Cruiser
                                  @Miš-Kan
                                  obviously and unfortunately not… but Suunto is aware and if you wait for the satellites to be locked properly it is a minor issue IMO
                                    Bradleyd Bronze Member @freeheeler
                                    @Freeheeler, out of curiosity and true seriousness, how does a person properly “wait for GPS lock” before starting a real race? Should I start running when the race begins and press “start” on the watch when the GPS has a lock? Another alternative for a time only race ( not place ) is to stand to the side, letting others pass, until the watch is ready, then start the race and the watch at the same time.
                                    freeheelerF isaziI 2 Replies Last reply Reply Quote 1
                                      freeheeler @Bradleyd
                                      @Bradleyd
                                      I did “races” when I did not have a gnss watch… but to me it is obvious: you warm up and you can already put your watch in start screen. this can be around 30mins or more before the start.
                                      I know somebody who tracks warmup and cooldown at race days, too
                                        isazi Moderator @Bradleyd
                                        @Bradleyd the easiest way is to go to the start screen well in advance. I usually open the screen already in the waiting area.
                                        This doesn’t mean Suunto shouldn’t solve this issue with AGPS on weekends, it’s weird and bad, but it’s a good idea anyway to go on the activity start screen in advance.
                                        B Milan ŠádekM 2 Replies Last reply Reply Quote 2
                                          Bradleyd Bronze Member @isazi
                                          @isazi and @freeheeler, this makes logical sense: get HR and GPS locked and confirmed well before going to the starting line.
                                          On a side note, “fused-speed” is an unbelievably cool feature and great backup for flakey GPS.
                                            AGPS is back this morning on my S9B
