    Customize "Run with power"
    12 Posts 5 Posters 777 Views 5 Watching
    • renton82R Offline
      renton82 Platinum Member
      Is it possible to customize data pages of, for example, run with power activity? I can only create custom activity starting with base profile.
      • Mff73M Online
        Mff73 @renton82
        @renton82 said in Customize "Run with power":
        not starting from base profile itself : you can “only” create a fresh new own custom mode for one sport/activity. Then change whatever is by default to your own needs.
        renton82R 1 Reply Last reply Reply Quote 1
        • renton82R Offline
          renton82 Platinum Member @Mff73
          @Mff73 So, if i select “running with power”, i can’t customize data pages…
            isazi Moderator @renton82
            @renton82 you start with customizing running. What matters is the sport type, other than that you design the screen as you want (and the starting point is the same for all sports I believe, with the difference of being GPS or indoor sports).
            renton82R 1 Reply Last reply Reply Quote 0
            • renton82R Offline
              renton82 Platinum Member @isazi
              @isazi Ok, but if i customize “run” for example, i can’t have a page with Distance, heart rate, power and timer like if i would select “run with power” activity like this : IMG_20221108_102720.jpg
                @renton82 of course you can, go to SA and just create the customized sport you want. I just did the same.
                • renton82R Offline
                  @isazi Which data field correspond to one in the middle? 3 sec? 10sec? Average lap power? max power? max lap power? average power?
                    @renton82 what you prefer. I would use 3 sec power to have something that changes rapidly.
                    • renton82R Offline
                      @isazi Thank you! I thought that power data fields were for cycling purposes only… So i suppose that default power data field is of curse 3 sec, isn’t it?
                        Dimitrios Kanellopoulos Community Manager @renton82
                        @renton82 correct. 3S . Some people also prefer 10s though
                        • renton82R Offline
                          renton82 Platinum Member @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos Thank you!
                            Brad_Olwin Moderator @renton82
                            @renton82 You can even select Power as a graph, it works well.
