    GPS POD doesn't sync with Suuntolink on PC
    3 Posts 2 Posters 1.0k Views 2 Watching
    • P Offline
      Penrynian
      Re: Very old GPS POD - can't see moves on app
      A year+ on from the last message, I bought a new USB charging cable for the GPS POD, and it worked fine.
      Now the POD isn’t recognised by the Suuntolink app, on either of the two PCs on which it is installed.
      I guess it’s possible that the new cable has failed; there’s a flashing green LED on the POD which suggests that it is being charged via the USB port.
      Should the POD still work with Suuntolink?
      Many thanks
      Phil
      • Raimo JärviR Offline
        Raimo Järvi
        SuuntoLink still supports GPS Track POD. If you’re using Windows, you could check if your device is shown in Windows Device Manager. If I select “View” -> “Devices by container” in Device Manager, it shows a “GpsPod” device.
        Pragmatic Programmer
        • P Offline
          Penrynian @Raimo Järvi
          Thank you @Raimo-Järvi
          It’s not showing up in DM, so given that it is the same situation on two different machines, I suspect that the cable is faulty, or the GPSPod itself has failed.
