    Smart sensor
    102 Posts 28 Posters 14.2k Views 27 Watching
      Guys stop worrying about how to update the sensor. It has not been updated in years now and if is needed as said before it will be available for you to do so.
      • suzzloS Offline
        suzzlo Moderator
        Thank you all guys, I’ll buy one in Amazon, and update with MC app 😉
        Garmin: FR745, Edge 530
        SA topics:
          borgelkranz Bronze Member @fleshymutant
          @fleshymutant @Brad_Olwin My problems with the Suunto belts were history once i started to clean them as described here.
          Basically, after each excercise you put the belt in a sink, fill the sink with warm water while washing your hands and let the belt soak for a while. Rinse it off and let it dry.
          Cleaning the belt in the washing machine worns it out. Killed one in roughly six month doing this…
            A Former User @borgelkranz
            @borgelkranz said in Smart sensor:
            This is absolutely true.
            I leave it overnight in a small bucket with 2 drops of dish washing detergent and just leave it to dry when I wake up.
            Washing in the washing machine has mixed results due to stronger detergent and potential use of softener.
            Brad_OlwinB ? 2 Replies Last reply Reply Quote 1
              Somehow I am happy to hear this article has contributed finally.
                Brad_Olwin Moderator @Guest
                @yannis-belouris said in Smart sensor:
                I agree cleaning them works but…i noticed that the new belt had a much stronger snap connection to the sensor. I think that removing and snapping the sensor in many times can loosen the snap connectors. No matter how I washed mine it wasn’t working well. The new belt is flawless so I think the belts do wear out as well. I put a lot of hours on mine.
                ? suzzloS 2 Replies Last reply Reply Quote 1
                  A Former User @Brad_Olwin
                  @brad_olwin are we supposed to remove the connector after each move?
                  Does it use energy when connected?
                    From my observation it can but not always. For that I always remove it when I remember todo so
                    • suzzloS Offline
                      suzzlo Moderator @Brad_Olwin
                      @brad_olwin said in Smart sensor:
                      I’m confused. New belt? Is there any new Suunto Smart Sensor?
                      SA topics:
                      Frédéric FiandinoF Brad_OlwinB 2 Replies Last reply Reply Quote 0
                        @yannis-belouris I remove it to wash the belt. But I have heard it can use some energy when connected.
                        • Frédéric FiandinoF Offline
                          Frédéric Fiandino @suzzlo
                          A “new belt” is just after purchase
                          you can buy it separately
                          Race
                          S9P with a firmware too
                          SSSWHR with a firmware inside
                          Ambit 3 Run
                          https://runalyze.com/athlete/Fred13270
                            Brad_Olwin Moderator @suzzlo
                            @suzzlo said in Smart sensor:
                            No, the sensor is the same, but I replace my belt every 9 months on average, they just don’t last more than that for me.
                            • suzzloS Offline
                              @Frédéric-Fiandino @brad_olwin ahhh men… I’m a bit slow today…
                              Thanks!
                              SA topics:
                                Michał Muszyński
                                Hello, I am writing through the translator googel, sorry for mistakes. I bought Suunto 9 with the hope that the problem with the HR sensor will disappear. Unfortunately, the problem still exists. I replaced the elastic strap with a new one, I used it for 7 days and now erroneous readings have appeared during running. The heart rate jumps as if it’s twisted. Tomorrow I am sending the HR sensor to Suunto with the complaint. We’ll see what they’ll do. I will be using the HR sensor from Decatlon for 30 USD with my new Sunnto 9. 😞 I am tired of this situation, I swim in the pool and the lake irritates me that the HR sensor is defective and other sensors do not work while swimming.
                                Ze StuartZ Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                  A Former User @Guest
                                  @Michał-Muszyński
                                  @Yannis-Belouris said in Smart sensor:
                                  • Ze StuartZ Offline
                                    Ze Stuart Gold Members @Michał Muszyński
                                    @Michał-Muszyński said in Smart sensor:
                                    Hi Michał: I swim with my 9 and the Suunto Smart sensor and it’s fine, as long as I don’t drive incredibly hard at the beginning of the length (all belts have this problem). I wet the strap before I put it on, as they stretch by ~30% when wet, and just before I start swimming it feels very tight. After that, it’s fine, and I get good, clean HR data. I blogged about it a bit here: https://t.co/KOJhi6CQlb
                                    Regarding the optical sensor, the consensus is that if one is serious about HR data, one uses a chest strap. Optical isn’t good for applications where there’s movement, and the water buffeting the watch with each stroke definitely counts as movement. I really like optical for background monitoring - sleeping, for example, or perhaps hiking - but for everything else I always use a chest strap, or an optical that’s not on my wrist (Wahoo TICKR FIT, or the Schosche (sp?) Rhythm 24, or the Polar OH1, for example).
                                    Smooth swimming!
                                    https://zulusierra.co
                                    SlaShS 1 Reply Last reply Reply Quote 1
                                    • SlaShS Offline
                                      SlaSh Platinum Member @Ze Stuart
                                      @Ze-Stuart but your hr looks really funky if it is belt…
                                        Ze Stuart Gold Members @SlaSh
                                        @SlaSh said in Smart sensor:
                                        It corresponds to when I’m swimming front crawl, which for me is a lot like trying not to drown, and when I’m swimming breast stroke, which is a lot more comfortable. The big gap is when I’ve decided to stop drowning simulations, and take in the view of the pool… Here’s today’s swim, which I think is easier to interpret:
                                        I think the initial drop is the mammalian reflex (drop in HR upon face immersion), and then I swam 6 lengths of crawl, 6 or so of breast stroke, then alternated for the rest of the swim, until the end when I did two of crawl. I was using a PowerBreather snorkel today, so no drowning simulation!
                                        • SlaShS Offline
                                          @Ze-Stuart below graph is from SA and looks terrible, I don’t see value from Powerbreather when doing breaststroke as breathing is quite easy in that style, but in freestyle it would benefit.
                                            Brad_Olwin Moderator @Michał Muszyński
                                            @Michał-Muszyński Suunto has acknowledged a software issue with the sensor. I am not having issues but some are. Fix hopefully soon
                                            johan6504J 1 Reply Last reply Reply Quote 0
