    Smart sensor
    102 Posts 28 Posters 10.7k Views 27 Watching
    • N Offline
      Niko Hämäläinen
      Is there a way of telling Spartan Wrist HR to disconnect the Smart Sensor after a workout? Other than unpairing it? Seems like mine stays on for a good while even after unplugging it from the belt and placing the sensor on a table. While the connection is active, the watch refuses to measure HR with the optics. Optimal solution would be to have an option to select which HR sensor to use, or if any.
      • Ze StuartZ Offline
        Ze Stuart Gold Members @SlaSh
        @SlaSh that bug is also present in the watch; there’s a thread about it… somewhere!
        https://zulusierra.co
          Maybe it helps:
          When using the sensor in the water please:
          • Start the excersise when the sensor is connected and shows HR working. If not done like this it will use OHR and will not send the command to the HR sensor to record.
          • When ending the excersise do not do in water. Get out or make sure sensor + watch are out of the water and the watch has HR signal. For example when done, press pause, get out of the water, switch the screens on the pause to see the live HR. Then press end. The watch will pull the recorded HR from the sensor (also does it while paused).
          I hope this helps
          • SlaShS Offline
            SlaSh Platinum Member @Ze Stuart
            @Ze-Stuart this is your swim workout screenshot 🙂
              @SlaSh I know, I recognise the bad data…
              @Dimitrios-Kanellopoulos superb, basic steps.
              • SlaShS Offline
                @Ze-Stuart every your swim looks like this 🙂 so ohrm even works better than your chest strap 😄
                  @SlaSh only in the app… even when I threaten to bite it. (I think Mr. @Dimitrios-Kanellopoulos said it was fixed in an upcoming release, actually, and the whole thing is an interesting insight into how the two discrete data channels are bonded into one.)
                  SlaShS 1 Reply Last reply Reply Quote 1
                  • SlaShS Offline
                    @Ze-Stuart it is strange situation as swim with ohrm displayed fine…
                      I think @Ze-Stuart s data are shown wrong on iOS.
                      Here is what I see.
                      • SlaShS Offline
                        SlaSh Platinum Member @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos quite strange situation how same application on different OS is acting…But how come HR with OHRM is shown fine even on iOS app?
                        Dimitrios KanellopoulosD Ze StuartZ 2 Replies Last reply Reply Quote 0
                          Dimitrios Kanellopoulos Community Manager @SlaSh
                          @slash that is a good question I can answer.
                          Some belts and OHRs have the ability to send IBI data to the watch.
                          IBI stands for interbeat interval, known as R-R as well.
                          This is the time, usually in milliseconds, between to beats.
                          IBI is the mother of HR. All belts/etc that report HR ONLY so some processing on an IBI set buffer.
                          Good to know:
                          HR is actually a “stupid” value as it lets you see the value of Beats Per Minute but you update it every 1s. Now add to that that 1s can contain even one beat (60BPM) the more low you drop the more hard it gets as of time needed to calculate. If for example the HR is < 60 BPM, lets say 30bpm imagine that every 2 seconds you get a beat. Anyways you can take a look in this section to know more if youlike
                          To cut a long story short someone has to process the IBI and derive an HR for the user.
                          Since IBI is stored on the watch and not HR if not from OHR, then the app, fails to process that. Why I do not know.
                          I have implemented the IBI data in my app(quantify-self not Suunto ) and feel free to ask any questions about. Just for the record, I had to study and experiment for 2 weeks longs to be able to give a correct result.
                            @SlaSh said in Smart sensor:
                            Here’s what I think is happening with my swim: I record using a chest strap, which means that the two data streams - swim data from watch, and HR data from strap - have to be incorporated into one. The summary on the watch is always wrong, and mirrors what we see in the app, which makes me think the app pulls the watch’s summary. Movescount, on the other hand, shows correct data: I think because it either re-analyses the data from the watch, or, because there are two discrete files (HR and swim data) that it recombines and aligns.
                            When you record HR with the HRM in the watch, the data is recorded live, hence the data in the app is correct. Unless, of course, I misunderstood and the OHRM you’re talking about is an external one, and that would explain why @Dimitrios-Kanellopoulos has his comment about HRV (which he’s right, is the interesting, juicy, high-resolution HR data we truly want).
                            I have a ticket with Suunto about incorrect watch summaries, which they’ve sent off to Finland.
                              OHRM should stand for Optical Heart Rate Monitoring, so the watch
                              And it should be this case as the other sensor involved is the belt one … as far as I understood
                              SVTS - 2.40.38
                              Suunto App Android 5.4.5 beta
                              Suunto App IOs 3.0.0 (20152) beta on MBP M1
                                Dimitrios Kanellopoulos Community Manager @Ze Stuart
                                @Ze-Stuart if you have a belt paired ohr should not work. Can you double check that ?
                                • SlaShS Offline
                                  @Dimitrios-Kanellopoulos doesnt work I can confirm for baro.
                                    @SlaSh and what happens if the belt goes out of reach ?/
                                    • SlaShS Offline
                                      @Dimitrios-Kanellopoulos HR is not tracked 😞 same story with if belt battery is depleted ohrm is not engaged and you are left without hr tracking until you stop workout.
                                        @SlaSh yeah that is intentional since you are using the belt. I would never prefer the opposite.
                                        There were a lot of cases in the past that people complained about this behavior of switching to ohr.
                                        If you select the belt it should be the belt. You can leave the watch at the gym locker and go train without making it a mess.
                                        • SlaShS Offline
                                          @Dimitrios-Kanellopoulos Why not to leave option for user to use or not to use ohrm if signal with belt is lost?
                                            @SlaSh that is what it should have been like. But it’s strange it isn’t.
