    Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak
    311 Posts 81 Posters 79.5k Views 79 Watching
      @Dimitrios-Kanellopoulos said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
      — New weather data available for SuuntoPlus (=visible during training)
      What’s this about? S+ Weather? If so, I don’t see any change.
        @Ilya-Sul soon
        • runomaticR runomatic referenced this topic on
        • MdzOttM Offline
          MdzOtt @Guest
          @twekkel it seems that it was fixed. I reconnected to Strava and synced a new activity. All is well in the world (:-).
          R2
          S9 Baro
          SA on Android
          Ambit 3 Peak
          Ambit 2 Sapphire
          • althaea35A Offline
            althaea35 Bronze Member
            Just experienced a mid run crash.
            S9P
            Guide on
            ~1h 6min
            Lost some data but not all.
            Started a new exercise immediately after, no guide. ~32min. No issues.
            Should I send logs?
            Suunto M5, Quest, Trackpod, A2S, SSU, S9B, S9P, Race
            Garmin 305, 60, 405, Fenix 2, 945, 955
            Polar M430, Vantage V
            • Łukasz SzmigielŁ Offline
              Łukasz Szmigiel
              S9PP
              Sadly, the dnd bug is still there:
              • have auto dnd enabled
              • disable it before the automatic time hits
              • enable it manually past the automatic time
              • it’ll get disabled the next full minute
              S9PP 2.44.52
              isaziI zhang965Z 2 Replies Last reply Reply Quote 2
                @Łukasz-Szmigiel same for Vertical, I’ll report it.
                  zhang965 @Łukasz Szmigiel
                  @Łukasz-Szmigiel said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
                  S9PP
                  S9PP might never get vertical’s watchface, but at least S9PP gets vertical’s bugs.
                  We are very even
                    Łukasz Szmigiel @zhang965
                    @zhang965 nah. It’s the other way around.
                    S9PP 2.44.52
                    • Umer JavedU Offline
                      Umer Javed
                      The Mermaiding UI on the new 9PP firmware has some fields improperly sized. The became really small. I couldn’t take a photo in the water but note here how the numbers become tiny compared to the original UI (website screenshot).
                      Not sure what other modes this would be on.
                      Piotr GrygielP 1 Reply Last reply Reply Quote 1
                      • Piotr GrygielP Offline
                        Piotr Grygiel @Umer Javed
                        @Umer-Javed The same in snorkeling.
                        Suunto Race 2
                        Google Pixel 8 pro
                        • W Offline
                          wakarimasen Silver Members
                          Anyone found a problem with their recovery time not counting down after installing this beta?
                          Suunto Race Titanium
                          Suunto Ambit3 Peak
                          Polar H10
                          Polar OH1
                          inkognitoI ? Richard ThygesenR 3 Replies Last reply Reply Quote 0
                          • inkognitoI Offline
                            inkognito Platinum Member @wakarimasen
                            @wakarimasen If I remember correctly, it doesn’t count down when you’re stressed (or at least your watch thinks you are :D). Cannot this be the case?
                            EDIT: Actually, I might be wrong about that.
                            Anyway, it seems quite close to this topic, doesn’t it? https://forum.suunto.com/topic/8728/recovery-time-not-working-properly?_=1687723005755
                            SV: fingers crossed :D
                            • MdzOttM Offline
                              MdzOtt
                              I think this was reported before, but just in case - the coloured ring for HR zones is no longer coloured (it is grey with the exception of the first one (yellow)). I did not look during the activity, so i cannot say if the colour changes as you progress through the zones or not.
                              R2
                              S9 Baro
                              SA on Android
                              Ambit 3 Peak
                              Ambit 2 Sapphire
                              • jthomiJ Online
                                jthomi
                                When Compass widget is active on the S9PP I can’t wipe in the menus, seems like the touch screen is off for the compass menu? I can swipe to the Navigation Options, but then touch screen doesn`t work anymore.
                                  Łukasz Szmigiel @jthomi
                                  @jthomi same here. Also, when “down”, it’s impossible to get back with press and hold middle button.
                                  S9PP 2.44.52
                                    A Former User @wakarimasen
                                    @wakarimasen It’s a Suunto Vertical bug that got ported to the other watches (edit: or maybe just the 9PP). Recovery Time doesn’t work on the Vertical right now.
                                    This has nothing to do with Resources btw.
                                    W 1 Reply Last reply Reply Quote 1
                                      A Former User @Guest
                                      @gi0vanni after about a week I installed the beta wohr seems a little better (just curious: has anything been addressed in this direction or it’s a placebo?)
                                      • Richard ThygesenR Offline
                                        Richard Thygesen @wakarimasen
                                        @wakarimasen said in Suunto Beta Release for Suunto 9 Peak Pro, Suunto 9 Peak, Suunto 9 Baro, Suunto 9 and Suunto 5 Peak:
                                        Not for my S9P. My recovery time is counting down.
                                        S9
                                        S9 Peak
                                        Race
                                        • W Offline
                                          wakarimasen Silver Members @inkognito
                                          @inkognito Yes - thanks!
                                          Suunto Ambit3 Peak
                                          Polar H10
                                          Polar OH1
                                          • W Offline
                                            wakarimasen Silver Members @Guest
                                            @Ilya-Sul Thank you!
                                            Suunto Ambit3 Peak
                                            Polar H10
                                            Polar OH1
