    Add Strava Segments Guide
    12 Posts 7 Posters 1.6k Views 7 Watching
      smedberg
      Hi!
      I had some troubles with getting some starred Strava Segments synced to the Suunto app. Trying to solve the issue I messed around with multiple things and one thing I did was to remove the Ride Strava Segments Guide from the app. How can I add the guide back? I can’t find it anywhere… Only Run Strava Segments Guide is listed under Suuntoplus guides section now
      Br
      Markus
        isazi Moderator @smedberg
        @smedberg remove the bike segments from Strava, sync your watch, add some segments back, sync your watch, the guide should be back this way
          smedberg @isazi
          @isazi Great thanks! Worked like a sharm
            smedberg @smedberg
            But i still have my original problem where some segments doen’t sync to suunto. Have tried with a couple of different segments, some sync just fine but some just don’t show up in the suunto app. Testing with both run and ride segments, and only a few(<5) since i have a S9B. Any ideas of anything i can try?
            MdzOttM VylliV 2 Replies Last reply Reply Quote 0
            • Set_218S Offline
              Set_218
              I have the problem that i had remove my strava bike segments in the app. I have removed the segments in strava, synch the watch, put back the segments on strava… another synch of the s9pp and there are no strava guides in the app or on the watch
              Ambit2
              Ambit3Peak
              Spartan Ultra Black Titanium
              S9B Black Titanium
              S9P Granite Blue Titanium
              S9PP Titanium Slate
              • MdzOttM Offline
                MdzOtt @smedberg
                @smedberg same (similar?) issue. One segment does not want to come across. Three sync’d well ( and resynced, when I removed all of them in Strava and added them back), but one does not. It seems that i tried everything and still it is not there.
                R2
                S9 Baro
                SA on Android
                Ambit 3 Peak
                Ambit 2 Sapphire
                  isazi Moderator @Set_218
                  @Set_218 now that the feature is public, and you already tried the workaround we know, it is better to contact support and ask for guidance.
                  • VylliV Offline
                    Vylli Bronze Member @smedberg
                    @smedberg Strava does not allow live segments for downhill segments. You can star downhill segments but they do not show in Suunto app. The same is for Garmin and others. I think the limit is -0.5 degrees. Maybe this is why some show and others don’t?
                    S MdzOttM 2 Replies Last reply Reply Quote 3
                      smedberg @Vylli
                      @Vylli ah interresting! I checked the segments that would not sync to suunto - they all have a negative avg. grade.
                      Thanks for the info!
                        deserthike20 Bronze Member
                        Suunto should probably make this a little clearer as its not entirely obvious to the end user that negative grades are not synced to devices. I’m sure this has caused some user frustration.
                        This is directly from the Strava website:
                        We do not sync downhill segments to devices for Strava Live Segments. Please keep in mind that our system recognizes even the slightest negative grade so there may be segments that display a 0% grade that is considered downhill and therefore will not sync to devices.
                        Suunto 9 Peak Pro
                        • MdzOttM Offline
                          MdzOtt @Vylli
                          @Vylli How interesting. I guess it helps to read the manual 😊 . Thanks to @deserthike20 for finding the info.
                          R2
                          S9 Baro
                          SA on Android
                          Ambit 3 Peak
                          Ambit 2 Sapphire
                            sky-runner Platinum Member @deserthike20
                            @deserthike20 In my experience Strava does sync negative (downhill) running segments but perhaps not negative cycling segments.
